![]() ![]() Drives: 07 YARIS Automatic/LiftBac/Red Join Date: Jan 2007
(2 post before me....) Read the TSB where it shows/says at the bottom, "oil recommended for these engines". If Your engine code falls in the list, then I do not see a problem using the 0-20 from what I understand after reading static808 TSB.
I will look at my "code" and if it is in the list I will try the 0-20 weight on my next oil change. static808, I'm curious on the warranty part. There is nothing there. Does this mean NO WARRANTY if you use/change over to the 0-20?? Also, how did you obtain this TSB; something You found online; work for TOYOTA??? thnx., sambo42xa Southern, NH
#2 | |
Engineer/Artist/House-Dad
Drives: 2006 Toyota Sienna XLE Join Date: Aug 2006
with regards to using 0w-20, instead of 5w-20, amsoil only carries an 0w-20, and they state that it is intended to replace conventional 5w-20 as well. they also mention how honda, toyota and gm are starting to recommend using 20 weight oil. its just like their series 2000 0w-30 oil; it is intended to replace 5w-30 oil also. same viscosity characteristics as the 5w's, just better cold weather start-up. an 0w designation also simply means a synthetic formula, since i cant find a conventional-dino 0w oil. its odd how this tsb actually "unofficially" has toyota endorsing synthetic oil use. i dont want to start another convetional vs synthetic debate, but i just wanted to post this thread out there for people who had heard of this tsb but actually could never find it. now we can all start getting better mpg without wondering whether using this weight oil will adversely affect our engines... hope this helps! --B
His: 2006 Toyota Sienna XLE Arctic Frost Pearl, FC Package, 2007 Solara Nav unit, Spoiler, Running Boards & Auto-dimming rear mirror Hers: 2007 Toyota Yaris LB Black Sand Pearl, Auto, Power Package, Side Airbags, VIP security, USDM center armrest, and accessory 7 spoke 15" alloy wheels |
| TSB for steering pull? | vst | DIY / Maintenance / Service | 12 | 06-09-2007 03:40 PM |
| Finally! | KittenRD | New YARIS Purchase Forum | 6 | 01-01-2007 10:16 PM |
| Finally installed oem ebay fog light for hatchback | Adriaan | General Yaris / Vitz Discussion | 6 | 12-27-2006 05:24 PM |
| finally found a good product to clean al plastic parts | Adriaan | Wash, Wax, Detailing, Exterior Repairs | 4 | 12-01-2006 03:45 PM |
| It's finally here! | Cathy | New YARIS Purchase Forum | 10 | 08-29-2006 11:08 AM |
