![]() ![]() ![]() Drives: 07 Join Date: May 2007
I started with the front since I figured it would be the most tough.
Tanabe DF's. |
#2 | |
![]() ![]() ![]() ![]() ![]() Drives: 07 Bayou Blue Liftback Join Date: Apr 2007
BTW, Where are you located at in PA? |
Lonesome Cowboy
Drives: 2007 WHITE HATCHBACK Join Date: Feb 2007
I put mine up on jack stands
Front was a little time consuming for me all that goddamn turning and spring compressing, won't be so bad putting in the coilovers.
SPONSORED BY
The only thing I hate about unibody is the lack of a frame! I always worry about crunching body work even though I use the designated jacking points.
Lonesome Cowboy
I always try and push the car off the stands before I start.
Of course with this car you kind of feel like you will dent or break something whaling on it as mentioned by others.
SPONSORED BY
#6 | |
| tanabe nf210 vs. TRD lowering springs?? | static808 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 37 | 01-23-2012 11:00 PM |
| Lowering Springs - Questions ~ | jaspie | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 16 | 01-10-2007 08:21 AM |
| TRD lowering springs' and/or shocks' Ride Quality?? | static808 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 28 | 08-29-2006 12:42 PM |
| HOLEY COW 674.75 to install TRD lowering springs | dbaxter | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 11 | 08-09-2006 12:40 PM |
| Will putting new lowering springs damage original shock absorbers in the long run? | Joel Leong | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 20 | 06-07-2006 08:30 AM |
