Old 05-20-2007, 10:58 PM   #1
PetersRedYaris
PetersRedYaris's Avatar
Drives: 2005 Scion xB
Stock 15 inch steel with 185/60/15 weighs 33 lbs.
Stock wheel diameter = 23.9 inches
215/40/17 = 23.9 inches (exact replacment)
205/45/17 = 24.4 inches (too tall)
205/40/17 = 23.5 inches (good choice for 1.9 inch drop)
21.4 lbs is fairly heavy. Your set-up will probably weigh ~42 lbs when mounted and balanced. Not a huge loss of power; mine is the same.
PetersRedYaris is offline   Reply With Quote
Old 05-20-2007, 11:12 PM   #2
Eurostar
hello
Drives: Yaris
hey peter, how much do ur springs drop? ur set up loos perfect
Eurostar is offline   Reply With Quote
Old 05-21-2007, 10:22 AM   #3
PetersRedYaris
I'm on Tanabe NF210 springs (1.1 front, 1.3 rear). My tires are 205/40/17. Wheels are 7 inches wide with 38mm offset.
Old 05-21-2007, 04:11 PM   #4
Eurostar
hello
Drives: Yaris
Can you tell me whats the size of ur caps right now, after the drop and with the 205/40R17.
Old 05-22-2007, 12:39 AM   #5
PetersRedYaris
Do you mean fender gap? Here are some pics I already had; measurement is from center hub.
Front-
Rear-
Old 05-22-2007, 02:08 AM   #6
Eurostar
hello
Drives: Yaris
perfect, so the set up with ur tires and wheels, with the set up of a 1.9in dorp with be a perfect set up for me, thanks again peter
