Old 07-05-2010, 09:05 PM   #1
darkMINI
Drives: 08 hatch
WILCO, thanx
darkMINI is offline   Reply With Quote
Old 07-12-2010, 10:45 PM   #2
darkMINI
Drives: 08 hatch
Ok, next question, got the tach mounted and hooked up. Its an 8,000 rpm tach and it for reads perfectly up to 3,500rpm, but it for some reason won't budge any further. Ant ideas? Thanks
Old 07-13-2010, 01:13 AM   #3
fmicle
fmicle's Avatar
Drives: 2007 Yaris LB
Defect? Can you see any obstruction that would prevent the needle from moving?
5% Tint Rear | Micro Image LED Ignition Light Kit
fmicle is offline   Reply With Quote
Old 07-13-2010, 02:27 PM   #4
darkMINI
Drives: 08 hatch
I guess it could be a defect. I have everything hooked up except the Illumination wire, and I don't believe that matters.
Its a 4,6,8 cylinder model and the switch is set on 4.
Old 07-15-2010, 01:13 AM   #5
fmicle
fmicle's Avatar
Yeah, if it doesn't want to move past 3500 rpm, there must be something wrong inside...
Old 07-16-2010, 01:37 AM   #6
darkMINI
Drives: 08 hatch
Yep, went back to the auto parts store and borrowed a brand new one to compare it right in the parking lot. It turns out I had a bad tach, so they swapped me for the good one on the spot. Now I'm in business!
'08 3dr HB, Black Sand, AEM, 16x6.6 Mini-Cooper wheels, DynoMax, Cruise, de-TPMS'ed.
Old 07-16-2010, 02:01 PM   #7
RedRide
RedRide's Avatar
Glad you got it workin'.
Where did you mount your tach? Is is a panel mount or a pedestal mount?
Old 07-16-2010, 01:45 AM   #8
fmicle
fmicle's Avatar
Haha, sounds familiar, I had the same problem with my tach, got a new one, worked fine, so I returned the bad one.
Old 09-22-2010, 02:38 PM   #9
CueBall
Ruler of the free world
Drives: 09 Yaris 2D HB
Fmicle, did you mount your tach in the glovebox? I cant see the pics.
CueBall is offline   Reply With Quote
Old 09-23-2010, 01:13 AM   #10
fmicle
fmicle's Avatar
OK, try to click on the links directly...
http://public.blu.livefilestore.com/...720.jpg?psid=1
http://public.blu.livefilestore.com/...723.jpg?psid=1
http://public.blu.livefilestore.com/...724.jpg?psid=1
Old 09-22-2010, 02:42 PM   #11
sleey0
Drives: 2008 Yaris LB
Wish some company would come out with a nice A pillar guage pod already lol.
I am not a fan of drilling thru the driver's side compartment like that.
I suppose even using guage pedastals and drilling them into the A pillar would work (garm had a pic and he did this with his tc IIRC).
sleey0 is offline   Reply With Quote
Old 09-22-2010, 03:10 PM   #12
maxxman420
prop215.
maxxman420's Avatar
Drives: Toyota Yaris LB
i really need to do this. i have the same tach but in white. mine is just sitting where that johnson and johnson thing is sitting in the side cluster. haha
maxxman420 is offline   Reply With Quote
Old 10-15-2010, 12:14 PM   #13
metalshark
MetalShark
Tach dreamer update: I've finished the 33 LED analog display installed in the display trim similar to my earlier BS2 tach. Those of you from the LA basin may have seen the only operational prototype of the gen 1 tach. I've finished the firmware (with the help of Prallax.com forum members) on a breadboard for a digital readout. It's running in my Yaris today. I'm changing the 4x7 segment display from red to green. I had a setback learning to solder surface mount chips for the analog display.
I'll have to do a version 1.1 layout before it's kit ready. I love the headrest video camera mount I found here. When success is apparent watch for the video coming soon to a forum near you.
Absolutely red, Drawtite hitch, CAI, Insulated Header, Amsoil 5w-30, Mag-drain plug, Red-Line MT-90 tranny oil, Scotch-Guard, Window Tint, Dash rug, Custom short throw shifter, Lowered OEM arm rest, Super-Turbo muffler/w chrome slash cut tip., TRD rear sway bar, sticky pads, front shock tower bar, RS grill badge, VVT-i emblems, Second tire set from Tirerack.com, DISABLED DAY TIME RUNNING LIGHTS, platform- style locking custom bike rack. 86K miles so far. 5 years use now on ceramic wrapped insulated stainless-steel header.
metalshark is offline   Reply With Quote
Old 01-07-2011, 12:27 AM   #14
jrsyaris
Drives: 2007 toyota yaris
putting a stock cluster,w/tach in a 2007 HB.
i would like to put the instrument cluster w/ tach, in a us spec, 2007 hatch back.
will the cluster physically fit, and how much of the wiring to the cluster would
have to be re done? has any body tried this before? thanks for any help in this
area. bob smith, ohio
jrsyaris is offline   Reply With Quote
Old 01-07-2011, 06:37 AM   #15
It is plug and play, as long as you purchase one from a comparably equipped car (i.e. if you have ABS it has ABS, if you don't it shouldn't). There are many threads on here about people having done so, or desperately searching for one to do so. The hardest part is finding one, since so few Yaris in the US have had them.
Old 02-21-2011, 03:43 PM   #16
dumb0
dumb0's Avatar
Drives: '07 Yaris 3dr LB
Send a message via Yahoo to dumb0
hey guys! i just installed my tachometer yesterday!
special thanks to mr. CTSCOTT for the wiring suggestions!
will post pic soon. orayt!
next stop, suspensions! :))
Live, Laugh, DRIVE!
dumb0 is offline   Reply With Quote
Old 04-08-2011, 03:16 PM   #17
Ron Powley
Drives: Yaris lift back, red
Tach is important to me. Hearing aids, and excess road noise make it impossible to hear the little hum of the engine.
Ron Powley is offline   Reply With Quote
Old 04-09-2011, 04:07 PM   #18
Brianr4
Drives: 2008 Yaris 3dr Hatchback
RPM check
Just installed my tach and wanted to compare RPM's to make sure it is accurate.
2008 3dr, 5 sp manual.
Turning 3000 at 70 mph.
2500 at about 60.
Brianr4 is offline   Reply With Quote
Liftback Spoiler Installation Toddhata Cosmetic Modifications (Exterior/Interior) 25 08-09-2009 01:26 AM
