![]() ![]() Drives: Yaris Join Date: Oct 2006
FRAM Tough Guard+Mobil 1 Synthetic 5W-30
Just got Fram Tough Guard Filter+Engine Oil from autozone today.
Can anyone tell me the advantages of Tough Guard Filter and synthetic? Never changed oil and filter before. I am a learner:) My Yaris Sedan has 10000miles. |
I drive a yarrrris
Drives: 07 Sedan Polar White Join Date: Sep 2006
Synthetic = more miles between changes + less wear on engine (please correct if I am incorrect)
and also if I'm not mistaken the Fram Tough Guard is ment for higher millage oil changes (5-7,000)
![]() Docotrs say all the drikning has mesesd up my seplilng and radieng will work for parts |
![]() ![]() Drives: 2007 Yaris Liftback Join Date: Sep 2006
Mobil 1 is a good choice that is widely available. You will see some profess their love for pure synthetics, but those are somewhat harder to come-by, usually online only. As for the Fram filter, i used a couple times in the first few changes, no problems with it, but I have read reports that they are not the best out their. I have since been using the OEM filter from Toyota which I get at the same price as a Tough Guard about 5 bucks.
Thanks a lot!! I am just wondering if it is OK if I use this Tough Guard Oil Filter with the Mobil Synthetic Oil? Someone told me I should go for Mobil Filter+Mobil Oil.
Another question is that my car got 10000miles now and when should I change the filter and oil next time if I use synthetic oil? Thanks a lot!! |
![]() ![]() ![]() ![]() ![]() Drives: LB-Auto-PWR-ABS-Cruise-Springs Join Date: Aug 2006
Fram and Mobil-1 are fine together. Fram is not my first choice though. I would reccomend NAPA Gold Filters which are made by Wix. Mobil-1 is a great oil and I would change my oil every 7500 miles, or once a year, whatever comes first.
Other car is a 2005 Mustang Convertible 4.0L V6 Manual - Legend Lime Get YarAss in gear! RIP - Casey Tatum |
Thanks! What about the Tough Guard Filter? Can I change the filter every 7500 miles as well?
The Fram Toughguard has a synthetic media with cellulose as well, good for absorbing moisture that makes its way in the oil. Our reccomended oil change interval is 7500 miles, so I think you are safe.
Here is a good read. http://www.automedia.com/Oil/Change/...cr20030901oc/1
#8 | |
der Zeck
another advantage to synthetic is better gasmilage
You can also switch to 5w-20 mobil 1 if you want improved mileage. Toyota put out a Toyota Service Bulitin (TSB) about that oil being a good choice for our cars.
![]() ![]() ![]() ![]() ![]() Drives: 07 Bayou Blue Liftback Join Date: Apr 2007
I use Amsoil 5w-30 and Wix filters. Every 5K I replace the filter and top off. Every 15K complete oil change.
Modded Moderator
I will never again use a FRAM oil filter. On my old ford I put the one that has teflon it it on. A few thousand miles later it wouldn't run anymore.
#12 | |
![]() ![]() Drives: 2007 silver yaris sedan Join Date: May 2007
also: wal-fart's supertech filters are allegedly good quality ( worked on my fleet so far) ----------- they're made by mobil 1 just my $ .02 kd |
Really, Supertech filters are made by Mobil??? Can someone confirm this?
#15 | |
der Zeck
I drive a yarrrris
i'm all about mobil1
The old black label Mobil 1 is Tri-synthetic and good stuff IMO, but I wouldn't push it out to long drain intervals like the Mobil 1 Extended Performance which is advertised for 15K intervals. As far as filters are concerned I have yet to read anything that would lead me to believe there filters are anything more then average.
| best synthetic oil and m/t oil?? | doodoo | DIY / Maintenance / Service | 122 | 04-03-2017 09:43 PM |
