![]() Drives: Black 07 Liftback Join Date: May 2007
Word of caution. If you're using the constant 12v as the remote signal your amp will never turn off, even when the car is off. Try to find a switched power signal from somewhere that only turns on when the car is running.
There is a grey wire off the stock head unit harness that is a switched 12v, you could use that or find another one. |
#2 | |
Not sure if it's bad for your amp to never turn off. Depending on how much power the amp uses when it's on but not pushing your sub, it might drain your car battery. Remote wire is dirt cheap, pretty much any 18 gauge wire will work, even some old speaker wire, so I think it would be well worth it to throw a turn on line in there.
#4 | |
| Keep your vehicle protected! | sqcomp | In Car Entertainment + Electronics (audio / video / alarm) | 17 | 09-10-2009 02:02 AM |
| Intake Systems Decision Maker.. | Blenjar | Performance Modifications | 25 | 09-15-2007 10:07 PM |
| Working at Volkswagen | elsteverino889 | Off-topic / Other Cars / Everything else Discussions | 22 | 05-07-2007 07:29 PM |
| Immobilize and security system. | Meow | In Car Entertainment + Electronics (audio / video / alarm) | 19 | 04-18-2007 05:40 PM |
| Indonesian Yaris stereo cheap sound system | ex-jazz lover | In Car Entertainment + Electronics (audio / video / alarm) | 0 | 04-05-2007 10:43 AM |
