wa do dem
what if you get a loose wire bad fuse or just what to adjust your amp if you are going to do it i would fit it with the seat on then off at this point i would make some type of bracket or plate and then fasten it down and you should be good to go i would get a piece of wood for the plate and router the edges nice and secure the amp to that it will help from connections shorting and will be better that just self taping screw in your floor
#2 | |
![]() ![]() Drives: 07 Yaris Join Date: Mar 2007
OK, I understand better now. I have a bunch of 1/2" MDF left over from making the front spacers and was thinking of making a mounting board for the amp and putting velcro on it plus some straps that hook to the seat bolts. *EDIT* The only problem is that raising it that 1/2" puts the connection for the seatbelt sensor and airbag in the way, so I will have to cut out those mounts and move them. |
| DIY - Sparco Race Seat Install | Idjiit | DIY / Maintenance / Service | 16 | 08-14-2017 09:15 PM |
| Bucket seat install | aucorium | DIY / Maintenance / Service | 11 | 12-08-2012 06:23 PM |
| How to install seat covers that require... | IsLNdbOi | Cosmetic Modifications (Exterior/Interior) | 13 | 09-23-2007 07:57 AM |
| Anyone know how the passenger seat detection system works? | rage2 | DIY / Maintenance / Service | 5 | 05-12-2007 07:22 PM |
| PASSENGER SEAT AND THE AIRBAG LIGHTS | mrrock | DIY / Maintenance / Service | 0 | 04-02-2007 09:24 AM |
