Old 11-11-2019, 07:46 PM   #1
Niki Knuckles
Drives: RS
Cooper 205 45 CSA 16 x 7
Niki Knuckles is offline   Reply With Quote
Old 11-11-2019, 08:21 PM   #2
myfirstyota
3 Yaris and counting..
That your truck?
No one suspects the Yaris.
Xd/2zr-fe Swap/Build Thread
Old 11-14-2019, 11:21 AM   #3
Niki Knuckles
Drives: RS
Nope... My 2006 parked in front.
Old 11-14-2019, 01:56 PM   #4
myfirstyota
Cause if it was I'd have said we similar taste in vehicles hahah
Old 11-20-2019, 07:08 PM   #5
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
-Greg...the Exhaust Freak.
-82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe/4.31
-96 Tercel 4dr
Old 09-02-2020, 07:43 PM   #6
Pinchlite
Drives: 2007 yaris HB
XXR 17 8.25 25mm
Nankang 205/45/17
5mm spacer rears only
No rubs back on Tein Stechs.
Front rub.
Cut metal piece that holds front plastic bumper cover.
Basically the clip is know half length with another screw that I made into metal.
Holding well so far.
I do get scrub on fender lip directly top dead center of wheel area.
I may shave or roll(Just bought a fender roller)
https://i.imgur.com/TGTV6Db.jpg
https://i.imgur.com/V3BOkQ1.jpg
https://i.imgur.com/3YR2oAf.jpg
https://i.imgur.com/zRaTg0H.jpg
https://i.imgur.com/mh48Pgy.jpg
I like these nankangs way better then the neogens.
The ride is softer even though these are 45 and the neos were 50 sidewall.
The neos were kinda hockey puckish.
These probaly wont last aslong but well worth the $360 CAD all in delivered to door.
https://i.imgur.com/EP1xdkB.jpg
Pinchlite is offline   Reply With Quote
Old 09-07-2020, 04:46 PM   #7
Mister
Drives: Yaris T1
I am struggling to find compatible rims :(
I really want to spoil my Yaris T1 2007....
Mister is offline   Reply With Quote
Old 09-07-2020, 08:57 PM   #8
Pinchlite
Plenty of compatible wheels.
Lots of 4x100 in variable widths and heights.
Take a look at rota.
If you want to play it easy,no modding of fenders etc then 16x7 40 offset is a good choice.
Old 10-09-2020, 11:17 AM   #9
Cheukie
Drives: Yaris white 2008
Yaris TS
17x7 JR28 wheels 205/45r17 et45 front et35 in the back with 5 mm spacers, bilstein b14 coilovers
File Type: jpg 98804340-9015-4685-9C7A-99FA26CCD461.jpg (200.0 KB, 244 views)
Cheukie is offline   Reply With Quote
Old 11-09-2020, 12:55 PM   #10
Jiv3tky
SIMP GOD
Jiv3tky's Avatar
Drives: 2007 Yaris HB
Man that looks clean. Thought its was a Golf at first glance.
Jiv3tky is offline   Reply With Quote
Old 10-09-2020, 02:53 PM   #11
ern-diz
ern-diz's Avatar
Drives: 2007 Liftback
Looks great!
On Instagram
On Wheelwell
Old 11-10-2020, 11:41 AM   #12
Lokusta
Unleaded fuel only
Drives: 1.33 Dual VVT-i (1nr-fe) 100HP
Ronal R42 15x6 et43
on winter michelin alpin 4 185/60r15 (only legal tyre dimension for my Yaris here in Italy)
Lokusta is offline   Reply With Quote
Old 11-12-2020, 02:46 PM   #13
ern-diz
ern-diz's Avatar
On Instagram
On Wheelwell
Old 11-13-2020, 01:11 PM   #14
lani100
lani100's Avatar
Drives: Yaris T sport TRD turbo
Enkei RPF-1 15x7
2004 Yaris T-Sport
1NZ-FE with TRD Turbo
lani100 is offline   Reply With Quote
Old 11-14-2020, 10:20 AM   #15
Niki Knuckles
Drives: RS
Exclamation Winter is coming...
So sorry, but these are not aftermarket, they're genuine Toyota steel wheels.
Old 11-14-2020, 05:08 PM   #16
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
Looks great! What type of paint did you use for the wheels?
Old 11-16-2020, 10:44 AM   #17
Niki Knuckles
Drives: RS
I used Rust-Oleum Universal Advanced Formula Metallic paint and primer in one.
I cleared coated with Rust-Oleum clear. Both were from Home Depot.
Old 11-17-2020, 02:45 AM   #18
mitch9521
Gen 3 > Gen 2
mitch9521's Avatar
Drives: NCP131, F-150, Focus ZTS
Those look a hell of alot better than my winter steelies. Mine are nice and crusty.
2014 NCP131 5 Speed
2007 F150 4.2L 5 Speed
2002 Ford Focus ZTS 5 speed
