![]() ![]() ![]() Drives: 07' Yaris Liftback - silver Join Date: May 2006
Has this happened to anyone else? when I stay near redline, over 6000 rpm, for more than a few seconds my check engine ligh starts to flash. today it started to flash and I didnt see it since someone was on my butt and I was trying to stay ahead, and then it just stayed on solid... I shut off the car and started it but it stayed on. its VERY weird too because I have a scanguage II and it logs codes, but it said there wasnt one... I kept trying to read a code but it said no codes found.. but the check engine light was on. HOW could the light be on but no code?? I ended up pulling the battery terminals off and waiting 10 minutes and then the light went off... very weird! if it had thrown a code I should have been able to read it. the light hasnt come back on.
anyone else see the flashing check engine light? it happened to me the first time when the car was bone stock, just flashed when I was racing my brother and stayed at 6k for 3 seconds. now I have 1/2 of my airbox removed, but I dont see how that would affect it since it did it even before I removed the box. |
![]() ![]() Drives: Yaris LB Join Date: May 2007
How and why were your rpms over 6,000? That's just asking for trouble. If someone's on your rear, let them pass, pull over, and just slow down. Just my opinion.
a flashing check engine light usually indicates a dangerous misfire is occuring. sometimes depends on how many cylinders are misfireing etc. if it stays on afterwards then there is definitly a problem. bring it to the dealership next time it comes on (dont delete it). just dont tell them you were reving the shit outta it
. it also could be a cat restriction or a/f sensor reading incorrectly and putting too much air in the engine at high rpm. etc etc etc. just remember the ecu records rpm at the time the DTC is set. isnt there a TSB for our cats having an egg smell? if so maybe your cats defective, rsx's have the same TSB . if your cat is "too" hot it can cause problems at hi rpm esp.
07 Yaris LB 5spd AE86 Corolla GTS 5spd http://microimage.ning.com/ http://www.microimageonline.com/store.html Last edited by drifto; 06-01-2007 at 08:24 PM. |
#4 | |
![]() ![]() Drives: 2007 silver yaris sedan Join Date: May 2007
and i'm not planning on going anywhere over that figure......if you need a performance car, why not get yourself A FERRARI...............
omg.. I gues I posted this in the wrong forum. I do occasionally playfully race people on the highway; nothing like drag racing or anything. jeez
#6 | |
07 Yaris LB 5spd AE86 Corolla GTS 5spd http://microimage.ning.com/ http://www.microimageonline.com/store.html |
thats the thing, it didnt throw a code. unless I take it to toyota or something, im not sure what it means. probably just letting them know I beat on the car or something! I didnt have it up there that long.... I mean your supposed to keep the RPMs high when your racing, since over 3K is where all the power is. I take it to 6.6K and shift when im racing, that is the rev limiter, I mean if you shouldnt take it that high then why did they make the limiter 6.6K??
#8 | |
If it does it again, I will have it checked.. hope it doesnt though.
![]() ![]() Drives: 2007 Yaris Liftback Join Date: Sep 2006
A friend of mine has a Mustang. When he gets near the rev limiter, the engine light flashes. If you are too close for too long, at will stay on and if you hit the rev limiter, engine light stays on.
His Dad has got some type of diagnostic head made by snapon. It didn't show the code (rev limiter) even with the engine light still on. When he took it in, he was warned about abusing the engine and further abuse, may void the warranty. It seems that those type of codes that may report abuse are secret and you must have the right diagnostic head to read them. I can not confirm or deny.. This is just what I was told. |
![]() ![]() ![]() ![]() ![]() Drives: Yaris Sedan Join Date: Sep 2006
You should chek that out cause I really rev mine hard everyday and no check engine light comes on.
I Drive a 129whp Yaris ;) |
#12 | |
11b1p
I noticed in the owners manual that the car has an EDR system. That system would record information before an "event".
#14 |
Patient: Doctor, it hurts when I do this...
Doctor: Then stop doing it... |
#15 |
#16 | |
#17 |
Drives: 2007 Yaris LB Join Date: Mar 2007
Not true....you can keep your Yaris at 6,000 RPGM all day long...the engine is nearly bullet proof, and it will take a beating plus more....that engine will not blow up at high RPM...it will last 300,000 miles of abusive use so long as it is maintained properly....no need to baby your Yaris...drive the hell out of it, if you must....it will not hurt it.
#18 | |
besides that i say go crazy
| Check Engine "Injector failure Code" | YarisPR | DIY / Maintenance / Service | 14 | 03-04-2007 08:13 PM |
| higher octane fuel | KSIbucky | DIY / Maintenance / Service | 37 | 01-14-2007 07:17 PM |
| service engine light @ 9000 mi? | dandj | DIY / Maintenance / Service | 21 | 01-03-2007 12:30 AM |
| High compression engine | flow-vitz | General Yaris / Vitz Discussion | 1 | 11-15-2006 01:03 PM |
| Check out my new light ( SEDAN )) | mariosuper | Cosmetic Modifications (Exterior/Interior) | 5 | 09-22-2006 09:06 AM |
