Old 06-04-2007, 03:33 PM   #1
Spades
The Hated One
Spades's Avatar
Drives: 07 White Manual Sedan
alot of foam/fabric air filters DO allow dust and grime into the engine...pull your intake off and look at the throttlebody after 10k miles...
Old 06-04-2007, 03:47 PM   #2
RogueYaris
Drives: 2015 Abs Red
foam/fabric air filters? is there any other kind?
RogueYaris is offline   Reply With Quote
Old 06-05-2007, 02:28 AM   #3
Spades
The Hated One
Spades's Avatar
yes...good ol fashioned paper. some foam filters are ok, most are not though because while they offer excellent air flow the material isnt as dense so more particles get through. most mechanics i have talked to and myself are in agreement that while you will notice improved hp and sound with such an air filter, it can be harmfull to your engine.
like i said, drive 10k miles and pull the intake off. if the butterfly on the trottlebody has grime on it switch air filters.
Old 06-05-2007, 05:23 PM   #4
Toyotech
Your Toyota Technician
Drives: 06 Cobalt SS/SC, 06 Rolla S
Send a message via AIM to Toyotech
most of that grime is for other reasons. having a paper filter won't stop carbon build-up on the throttle body. almost all the technician's i know run k&n type filters and i have put over 90k on a vehicle without an issue. you do know how small the amount of particles are correct? (i have even seen foam filters implode pc by pc into the motor)for that 10k most of the grime caused is by the oil from the filter sitting on the butterfly...but you could easily run a dryflow.
Toyotech is offline   Reply With Quote
Old 06-18-2007, 07:40 AM   #5
Katana
Katana's Avatar
Drives: Yaris LB 1.3lt 06
I think there is a liquid that cleans it up.
Any Aftermarket Intakes Yet?!?!?!?! silverRS Performance Modifications 120 12-07-2011 06:44 PM
air intakes? SLIK4 General Yaris / Vitz Discussion 16 05-21-2007 09:34 PM
Install a Yaris deck into a Matrix... bad idea?? Help needed!! SimmZ In Car Entertainment + Electronics (audio / video / alarm) 4 12-17-2006 01:01 AM
REALLY BAD CAR ACCIDENT! MacMaster761 General Yaris / Vitz Discussion 25 11-30-2006 11:20 AM
