The Hated One
Drives: 07 White Manual Sedan Join Date: Sep 2006
yes...good ol fashioned paper. some foam filters are ok, most are not though because while they offer excellent air flow the material isnt as dense so more particles get through. most mechanics i have talked to and myself are in agreement that while you will notice improved hp and sound with such an air filter, it can be harmfull to your engine.
like i said, drive 10k miles and pull the intake off. if the butterfly on the trottlebody has grime on it switch air filters.
#2 | |
Your Toyota Technician
most of that grime is for other reasons. having a paper filter won't stop carbon build-up on the throttle body. almost all the technician's i know run k&n type filters and i have put over 90k on a vehicle without an issue. you do know how small the amount of particles are correct? (i have even seen foam filters implode pc by pc into the motor)for that 10k most of the grime caused is by the oil from the filter sitting on the butterfly...but you could easily run a dryflow. Last edited by Toyotech; 06-05-2007 at 05:34 PM. |
| Any Aftermarket Intakes Yet?!?!?!?! | silverRS | Performance Modifications | 120 | 12-07-2011 06:44 PM |
| air intakes? | SLIK4 | General Yaris / Vitz Discussion | 16 | 05-21-2007 09:34 PM |
| Install a Yaris deck into a Matrix... bad idea?? Help needed!! | SimmZ | In Car Entertainment + Electronics (audio / video / alarm) | 4 | 12-17-2006 01:01 AM |
| REALLY BAD CAR ACCIDENT! | MacMaster761 | General Yaris / Vitz Discussion | 25 | 11-30-2006 11:20 AM |
