turbo intake manifold
Hey guys, I figured it has been a while since I have posted, been busy working and all. Anyways, this has been my lastest mod, and it is nearing completion. The only thing left is to weld on to vacuum nipples for the brake booster and for the pcv hose. I'm hoping to be done soon and get some dyno time for a retune and all and I will post up on the results. A few mods need to be done still, i did the throttle body water jacket removal, and i have to reroute the radiator hose. Anyways, here it is.
Whats that TB off of?
Great work BTW.
No SHiT!!!! Props on the fab work. Looks great!!!
scion tc same bolt pattern actually, the difference is our stock TB are 2" inlet (filter side) and around 1 5/8" on the manifold side. This one is 2.5" inlet side and almost 2 1/4 manifold side.
Lurker supreme!
Drives: old and boosted! Join Date: Nov 2006
So pardon my n00bishness... this will be to replace the stock plastic intake manifold? Which I'm guessing is the other one on the right. Since the individual outlets are in a different place now (i.e. not curved), how will the throttle body connect to whatever it is that it connects to? I'm guessing the turbo. Anyhow, any explanation would be appreciated (not just by me, but I'm sure there are a few others of us willing to learn!)
Looks great, btw!!
2006 Red Blitzed RS 5-door |
you can see the throttle body installed on the new manifold.
the throttle body does not connect to anything inside the manifold, is just a "butterfly" that lets air get into the intale manifold and then the engine. so if you can find a way to mount it on the new manifold and wire it normally, you have a working unit. |
nice work btw. now if you ever decide to do another manifold would you consider having the inlet tubes at an angle?
meaning as the air travels into the manifold it doesn't have to take a 90* turn but instead kind of flows at a curved angle. do you get the idea, or did i lose you? |
Your Toyota Technician
nice work but have you tested the throttle body? i have done this route before with failure and throttle codes. any pictures of the stacks?
![]() Drives: 07 Corolla Join Date: May 2007
dont u need velocity stacks in the inside of the tube?
and i think u'd have to narrow the inside of the tube down as it goes to the last cylinder... |
#10 | ||||
Are you planning to run more than 7 lbs. of boost?
one word: WOAH
well thats good...guess i'll try a different throttle body. 1st half of the sweep it was fine, second part of the sweep it through the codes...
hope you get good flow through the cylinders because i'd be worried bout running poor on cylinders. |
#14 |
37HSSV
Looks great IMHO. Hope it works out, Actually looks like a good DIY!
07 Toyota Yaris Hatchback -sold- 11 Mazdaspeed 3 -SRI/TIP, 3 inch TBI, Custom FMIC, Tuned by Cobb Accessport, HKS ssq2 BOV, Upgraded HPFP- Clean stock look... Killer performance. |
#15 |
![]() ![]() Drives: Yaris 3 Door, 04 WRX, 69 Lotus Join Date: Apr 2007
Velocity stacks are never needed. However, they usually will make a little more power, especially NA. But they can also cost power if they suck.
#16 |
Awesome.
Drives: 07 Meteorite Metallic Hatch Join Date: Jul 2007
Any updates? I am curious to see how this works out. Gl...
#17 |
none yet, I'm on vacation in atlanta should be done soon, I have just been real busy you know with summer and all.
#18 |
![]() Drives: 95 volvo 850 (saving my cash) Join Date: Jun 2007
thats a sweet DIY fab job on the intake manifold. great to see people are already breaking out the welder on a new(er) car.
the last car i worked on was a 91 crx, so it had a ton of parts out there for it... With all the diy thats going on the after market should pick up fast for the yaris... you know other then shift knobs and tail lights.... |
| Intake Systems Decision Maker.. | Blenjar | Performance Modifications | 25 | 09-15-2007 10:07 PM |
| Thinking about making a full Intake Manifold Replacement | YogiYaris | Performance Modifications | 26 | 06-07-2007 10:26 PM |
| WR Secret Weapon Intake Dyno Tested.. | WRLEO | Performance Modifications | 70 | 05-17-2007 03:00 PM |
| Intake VS modified filter housing | Spades | Performance Modifications | 19 | 03-30-2007 12:30 AM |
| Vitz Rs turbo vs U.S. Yaris add turbo? | weaponrcamry | Performance Modifications | 18 | 08-09-2006 08:45 PM |
