Old 06-09-2007, 01:10 PM   #1
falkor_99
falkor_99's Avatar
Drives: 07 Yaris Blue HB
Send a message via AIM to falkor_99
good to know
falkor_99 is offline   Reply With Quote
Old 06-16-2007, 12:33 AM   #2
Pavel Olavich
Drives: 2007 Yaris LB
It seems that most of those mods for the Yaris are a super big waste of $$...doesn't anyone find out first, if a mod is going to increase performance, or does one just like the braggin rights of having a CAI, or mod exhaust?
Pavel Olavich is offline   Reply With Quote
Old 06-09-2007, 01:09 PM   #3
grampi
Drives: Corolla
Pars, I'm sure it could. Usually the first thing that disappears when they start souping up these little belnder motors is the bottom end torque. Peak HP will increase, but at the cost of power in the lower RPM range. That's why I wouldn't even consider any engine mods unless they increase power across the entire RPM range.
grampi is offline   Reply With Quote
Old 06-09-2007, 02:18 PM   #4
ChinoCharles
Drives: LB
How many of you guys talking like you know something have ever been in the same room as a dyno? 2000 RPM is a perfectly acceptable engine speed to start a dyno run at. The fuel economy thread is there for anyone that wants to hop on a soap box about granny driving.
Old 06-09-2007, 02:37 PM   #5
grampi
Drives: Corolla
I've seen plenty of dyno runs and it's been my experience when peak HP is gained, power is lost on the bottom end.
Old 06-09-2007, 10:29 PM   #6
Pars
Drives: 07 Yaris Liftback
Starting off at 2000rpm is all well and good on the dyno. But on the streets, if I was always starting off at 2000rpm, I'd be on my third set of tires (instead of my second set).
If the mods were able to increase initial torque without taking away from the higher rpms, then I'd be truly impressed and quickly drop my hard earned money for the add-ons. That kind of upgrade would not only make the car faster, but actually improve fuel consumption. It might not make you kind of the racetrack, but it would make you king on the streets.
Pars is offline   Reply With Quote
Old 06-10-2007, 03:03 AM   #7
lostmind
Drives: 06 STi, 07 rav4, 07 yaris
Sadly I gotta agree here. I want to go from 0-60km/h faster in the yaris. Not from 60-100km/h faster... you know what I mean?
Not knocking those of you after gains up top... just not what I want... and I bet the majority of people would probably want 0-60km/h acceleration as opposed to 60-100km/h... cuz we're not tracking it, we are driving in traffic...
lostmind is offline   Reply With Quote
Old 06-10-2007, 03:14 AM   #8
tk-421
tk-421's Avatar
Drives: 5D-07-LB
+1
Mods like the NST pulley set should increase power throughout the whole RPM range. I'll be getting that as soon as it becomes available (July apparently).
http://www.nonstoptuning.com/pKitToyYaris.htm
Old 06-10-2007, 10:37 AM   #9
churp
Clean and (dis)Functional
churp's Avatar
Drives: Yaris 2dr--Black Betty
Did I miss something? Seems like people are assuming low rpm power went down.....does anyone have the dyno graph of the stock setup to compare before trashing the modifications (in a lot of peoples minds improved mod's)
____________
Old School Cobble Jockey
churp is offline   Reply With Quote
Old 06-10-2007, 11:31 AM   #10
pathetiq
pathetiq's Avatar
Drives: yaris sedan aero
i dont get it, dont the yaris have 105hp and 106torque by factory default and with mod youre under 100?
pathetiq is offline   Reply With Quote
Old 06-10-2007, 01:03 PM   #11
lostmind
pathetiq, it's 105/106 at the flywheel? and then you have the losses getting that power to the ground. The dyno shows HP/TQ actually put out at the wheels...
A stock yaris dyno's around 90hp? I think I read that on this site somewhere.
Hey churp,
It's not that I think low end was lost, it's that the gains are mostly in the higher rpm's. To me, that's a part of the power band I won't be driving in the majority of the time...
Although I do think it'd be killer to see someone take a yaris and lighten the crap outta it, toss in a turbo or just spend $5-10k and go NA and beat the snot out of it at the track :)
Old 06-10-2007, 01:29 PM   #12
churp
churp's Avatar
pathetiq, ....
I understand what you're saying....just want to make sure everyone understands that power on the low end isn't necessarily lost. Cubic inches and turbo or super will give more torque at the cost of gas.
BTW I'd rather see a T-Rex in my garage than a souped up Yaris....it may get better milage!
____________
Old 06-15-2007, 08:23 AM   #13
nsmitchell
nsmitchell's Avatar
Drives: LB-Auto-PWR-ABS-Cruise-Springs
The ZPI Turbo kit said it actually increased MPG by 2-3MPG, but you must use high octane fuel, so it all evens out. Now if you go stompin' the gas everywhere you will probably get no better than 30MPG... probably a lot less.
Other car is a 2005 Mustang Convertible 4.0L V6 Manual - Legend Lime
Get YarAss in gear!
RIP - Casey Tatum
nsmitchell is offline   Reply With Quote
Old 06-15-2007, 09:00 AM   #14
largeorangefont
Break'em off some.
largeorangefont's Avatar
Drives: 07 Yaris LB, 04 Cobra
WTF are you guys talking about lack of low end power?
First, there is no stock chart to compare these numbers to so it shouldnt even be discussed.
Second, The dyno chart shows the car has 90% or more of its peak torque from 2000 to 5000 RPM. What more do you want??? That is a pretty broad powerband for a little motor.
Look and the numbers compared to the Fit. The Yaris hits peak torque at about 4000 RPM, the Fit 5000. The Fit started out at a higher RPM and still looks like it had NOTHING on the bottom end. It is just starting to wake up at 3000.
Old 06-10-2007, 04:17 PM   #15
dngz
dngz's Avatar
Drives: black yaris sedan
http://yarisworld.com/forums/showthr...=weapon-r+dyno
Weapon-r dyno says stock 76 tq and 77 hp at the wheels.
So 100whp is not too shabby!
edit: okay, i just saw the other recent dyno chart. 90whp?! wtf, now im so confused...
dngz is offline   Reply With Quote
Old 06-10-2007, 01:06 PM   #16
lostmind
And to the OP I just want to say thanks for investing your time and money into your car and then sharing with the community. Without people like you, the rest of us wouldn't be able to make informed decisions on upgrades...
Old 06-10-2007, 05:15 PM   #17
lostmind
Different brand of dyno maybe? I am no expert on this though...
Old 06-15-2007, 02:15 AM   #18
mojoyaris
Ecurie Snoopy Lives
mojoyaris's Avatar
Drives: Jojo
Nobody talks about the big throttle body kit and the Blitz RVit that can adjust the fuel and air mixtures. I'm curious how much extra hp this would bring on top of the intake, exhaust, header setups.
Sponsors and Organizations:
Toyota Rally Canada
Yokohama Tire Canada
Western Canada Rally Association
Ecurie (Team) Snoopy Canada, racing since 1966
mojoyaris is offline   Reply With Quote
WR Yaris Intake Picture & Dyno. WRLEO Performance Modifications 37 04-05-2007 07:02 PM
Looking to buy a header and an intake for my Yaris. nevermorez Performance Modifications 2 01-04-2007 02:35 AM
