Old 06-09-2007, 08:06 AM   #16
kimona
kimona's Avatar
Drives: 2014 White VITZ
The following wheel and tire vendors list wheel offset:
Tirerack.com (with tirerack, once you view a wheel on your car, click on wheel name in left hand column to get the specs).
Discounttiredirect.com
Buywheelstoday.com
Please check them out to get some more ideas.
The OEM wheel specs above are for 15" steelies which I assume you have, and for the 16" alloys. The 16" OEM wheel isn't available here in the States. I'll try to find a photo and post it for you.
I think the highest offset you'll find Stateside (in a one-piece wheel) will be 45mm.
If you're not lowering, I'd probably go with a 16x7, ET45, and either 195/50's or 205/50's.
