Old 06-09-2007, 06:51 PM   #1
Shroomster
'07 to '12:2 wipers to 1?
Shroomster's Avatar
the rubber is there in the middle to prevent rubbing of the spring where the compression points (can't think of how to say it right) would normally touch. kind of like a bushing.
the eibach name is upright on the spring, therefore the name should be readable if the spring is installed correctly.
and yes get an alignment. even if you don't feel anything that doesn't mean the wear of the tires is correct or the suspension is geometrically sound.
tanabe nf210 vs. TRD lowering springs?? static808 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 37 01-23-2012 11:00 PM
Lowering Springs - Questions ~ AGAIN ~ jaspie Wheels, Tires and Suspension Forum sponsored by The Tire Rack 9 01-16-2007 12:23 AM
Lowering Springs - Questions ~ jaspie Wheels, Tires and Suspension Forum sponsored by The Tire Rack 16 01-10-2007 08:21 AM
HOLEY COW 674.75 to install TRD lowering springs dbaxter Wheels, Tires and Suspension Forum sponsored by The Tire Rack 11 08-09-2006 12:40 PM
Will putting new lowering springs damage original shock absorbers in the long run? Joel Leong Wheels, Tires and Suspension Forum sponsored by The Tire Rack 20 06-07-2006 08:30 AM
