Old 06-13-2007, 02:44 PM   #1
ROCKLAND TOYOTA
TRIM HUNTER
ROCKLAND TOYOTA's Avatar
im also getting ready this saturday to install the same setup. CHRIS or someone else can you tell me how much you cut your bumpstops and do i really need to if i use the stock struts.....
Old 06-13-2007, 03:41 PM   #2
Toyotech
Your Toyota Technician
Drives: 06 Cobalt SS/SC, 06 Rolla S
Send a message via AIM to Toyotech
normally cut about 2 ribs off
Toyotech is offline   Reply With Quote
Old 06-13-2007, 04:12 PM   #3
ROCKLAND TOYOTA
TRIM HUNTER
THIS IS GOOD FOR BOTH THE TRD AND STOCK STRUTS????
Old 06-13-2007, 07:18 PM   #4
churp
Clean and (dis)Functional
churp's Avatar
Myself I wouldn't cut them for the stock struts...they are designed to keep the strut cylinder from bottoming out. The bump stop bottoming is much softer and less damaging that having the cylinder bottom out. Aftermarket struts are probably different, but I can't imagine any car manufacturer engineering their products with more clearance than needed....it usually costs money!
Has anyone actually checked how far down the strut can go, with and without the bump stops....would be easy to do with the spring off. Then you could tell how much distance the bump stop has to compress before the cylinder bottoms. Of course then you'd have to decide how much you think the bump stop would compress under a severe load. No matter what...the longer the bump stop is the softer the 'thump' will be when it hits.
____________
Old School Cobble Jockey
Finishing my suspension ChinoCharles Wheels, Tires and Suspension Forum sponsored by The Tire Rack 11 10-15-2011 09:26 PM
question about radio install misfits9095 In Car Entertainment + Electronics (audio / video / alarm) 8 06-06-2007 03:08 PM
NorCal: Suspension install The Stig California 12 06-05-2007 12:51 AM
Suspension Setup Question Ran Kizama Wheels, Tires and Suspension Forum sponsored by The Tire Rack 27 04-28-2007 02:05 PM
n00b question... djfuji Cosmetic Modifications (Exterior/Interior) 9 01-29-2007 10:47 PM
