Old 06-16-2007, 09:14 AM   #3
earljail
earljail's Avatar
Drives: 07 Yaris Hatch 5speed
Originally Posted by Lafiro View Post
I was looking into some subs that dont handle to much power but they can do like 10hz to like 1000hz in sound. Most subs only do 25-100.
Please help! I don't know anything else about other companies and need to know what to get based on your experiences/knowledge.
I don't have a recommendation about which brand to buy.
However, at least you admitted your ignorance. You do not want your subs to actually put out anything over 80-100hz. If you had a crossover set to 1000hz, then you'd be hearing male vocals from behind you, mixed with the normal guitar, keyboard sounds from up front. It would sound like crap. Also, allowing your subs to play so high will make the bass all muddy. At high power levels, you would destroy your subs.
Also, be realistic about the lower end. A sub that is set up, i.e. in a box tuned really low, to play down to 10hz, won't be playing any of the important bass sounds, like bass guitar. Also, some amps even have a "sub-sonic filter to block out anything below 25hz or so.
Instead, aim to have a bass setup that plays all the bass sounds from 40-100hz, but evenly.
earljail is offline   Reply With Quote
Looking for Subwoofers? Free-Air capable? JustYYaris Items for Sale by private party 1 04-17-2007 01:41 PM
