Old 06-17-2007, 10:06 AM   #1
churp
Clean and (dis)Functional
churp's Avatar
Drives: Yaris 2dr--Black Betty
Originally Posted by hystria View Post
no need to change the front sway bar, as the car gets lowered, the stock bar bends more thus being more stiffer - this significantly improves the handling.
How does a sway bar get stiffer??????? (not that stiffer is needed) only way is larger diameter, or change the distance/length between attachment points....research.
____________
Old School Cobble Jockey
churp is offline   Reply With Quote
Old 06-17-2007, 01:52 PM   #2
Black Yaris
der Zeck
Black Yaris's Avatar
a picture tells a 1000 words
Old 06-17-2007, 01:58 PM   #3
Vanderkitten
Vanderkitten's Avatar
Drives: 2007 Yaris Hatchback
Or, technically, the material will also make a big difference. Think of mild steel vs. 4130 cromoly in the same diameter. Also shape (box v. oval v. round for example).
Because there is no ltd. slip, and not much power, more sway would only increase the likeliness of the inside wheel lifting under hard cornering...
I can tell you the coil-overs made such an improvement, it might be all you'll ever need. Also, the rear end is huge for a car this size, it looks pretty damn beefy.
Check out the TEIN project car, it has some interesting mods to it.
Dave V- Creator-Vanderkitten- Clothing for Women Who Kick Ass!
Many thanks to our sponsors:
Weapon-R http://weapon-r.com
Megan Racing http://www.meganracing.com
Les Schwab Tires http://www.lesschwab.com
317 graphics http://www.317graphics.com
Vanderkitten is offline   Reply With Quote
