Old 09-23-2026, 07:41 AM   #1
dagiv
Drives: Yaris 1.3 Sport
Instrument Cluster not working on Yaris Hatchback NCP90L
Hello World, newbie here!
Coming for some advice been facing a problem with my Yariz 2NZ-FE Engine MT
Long Story Short, car went for clutch replacement then somehow the original computer got shorted and had to replace it with a new one. Same part numbers, etc.
After installing new ECU and programming the key the car starts and the digital cluster turns ON but it doesn't work, it doesnt show RPM or Speed. Cool light is blinking, ABS and other lights are on. The only working lights would be oil, engine and battery (alternator). The car works fine and the ABS module is working, I've noticed it while driving the car. No DTS at all, motor is running fine.
I'm wondering if you can give me some piece of advice, to me, seems like something is disconnected as when I connect the scanner thru ODB port I can read everything, speed, RPM, temp, etc.
Thank you so much in advance, I hope to get some help to fix this issue
dagiv is offline   Reply With Quote
Is headlight reminder buzzer behind instrument cluster & easily accessible? RMcG DIY / Maintenance / Service 9 08-24-2022 11:57 PM
2012 Yaris SE Hatchback Instrument Cluster diode stuck on 2012YariSE In Car Entertainment + Electronics (audio / video / alarm) 0 07-12-2022 07:14 PM
2015 yaris driver window not working Welshpear DIY / Maintenance / Service 7 05-23-2022 04:15 PM
