![]() Drives: 2015 SE HB Join Date: Jun 2007
is he still under his car? this sounds like a good idea...
11b1p
Ok I put the pump in today. As I suspected I had a couple of minor issues. First the belt was too short. So I will try a 425k4 tomorrow. I cut the original radiator hose and inserted the pump pulling water away from the engine. I piggypacked a relay switch to a green wire in the under hood fuse block. It is only on when the key is in the run position.
Problem number one. The thermostat works too well. Water will not go past it. This causes the radiator hose to collapse while engine is cold. I will cut 1/4" weep hole in the thermostat to allow some constant flow.(I am thinking about getting an electric thermostat that will control the pump.) For now the belt is back on and the pump is not impeding flow so the obd2 reads around 180 I wish I had better news. Thank you for your attention. |
Why would you install a pump to pull water away from the engine??? Is it in the top hose? You could have avoided the collapsed hose if you installed it in the lower hose pushing water INTO the engine.
Your electric thermostat sound like a good idea if you want this set-up to work properly. Good luck. |
#4 | |
Clean and (dis)Functional
Drives: Yaris 2dr--Black Betty Join Date: Mar 2007
Did you remove the water pump so it doesn't restrict the flow? Edit: Sorry, see you will be removing it later. Hope it doesn't restrict too much, or you have another vehicle until you're done!
____________ Old School Cobble Jockey
11b1p
It's like with a straw. If you suck too hard the straw collapses. The thermostat is literally water tight. I initially removed the upper radiator hose at the filler tube and started the engine there was no flow. Since the cooling system was not pressurized I did not get any flow. I was amazed. I have it set pulling away because the thermostat is down there. Every diagram i have seen has the water leaving the engine at the thermostat
I am still not sure if the water leaves the engine at the thermostat. Anybody Know for sure? |
#6 | |
After many minutes the top hose get very hot to the touch at the radiator(thermostat opening allowing flow), then after a couple minutes the warm coolant warms the lower hose (finally arrives there). The coolant flows into the top of the radiator....absolutely. Every radiator has the heated coolant flowing into the top...no matter where the thermostat is.
11b1p
churp, I am glad that I checked here this morning, before I warm up that engine I will flip the pump the other way. I will go get the new belt, and maybe i will have new news, or similar problems giong the other way. And I will try to take a pic. Maybe this afternoon.
11b1p
Just a head's up. I have the pump hooked up. I had to take the thermostat out. The OEM pump circulates water through the block while the thermostat is closed. So I would not recommend the current set up to daily drivers.
The coolant temp runs between 150 and 170 degrees. so it is no constant with this set up. My next plan is to get an oem wp gasket and try to make a plate that I can mount a wp118 from an LT1 engine to. |
![]() ![]() ![]() Drives: 07' Yaris Liftback - silver Join Date: May 2006
cool, any power gains? thats what its for in the long run, right?
11b1p
It definately feels better on acceleration. I wish I knew where a dyno was here. Closest one I can find is Bowling Green It is so easy to throw the stock belt back on that I could do before and after runs.
Id love to see the #'s, Glad it has more powa!
![]() ![]() Drives: 06 yaris AT Join Date: May 2007
mandriu, what sort of belt did you use? Are you running stock crank pulley?
#14 |
![]() ![]() ![]() ![]() Drives: 2008 yaris, stripped, red Join Date: Jan 2009
every thermostat produced after about 1970 has a weep hole in it. it prevents thermal shock. idk where you got your tstat from, but i'd put an aftermarket in it. one with a hole.
i'd love to see this lt1 adapter...i have 2 laying around, and an extra CSR ewp....so........if it's not too much to modify i'll have a cheap waterpump...yay. the ltx is a direct swap, easy to fix, cheap ewp mod. you take out the 8 bolts holding the pulley to the pump housing, replace it with the ewp and new gaskets (provided with csr, dunno bout mezerie), put on some teflon/loc-tite and top off with coolant... easy. about 2 hours worth. either way, i havent looked at the yaris wp, and if it's one solid unit, or it has a separate bearing/pulley/impeller. this could be really easy if it's separate. |
#15 | |
#16 |
speaking of.....how'd you do your pump cali? did you do something similar as here or what? if you can talk CSR or mezerie into a yaris/corolla/camry/tacoma pump i'd be interested.
#17 |
mandriu, i have bought the EWP kit and just wondering if the 425k4 belt fits (with WP pulley removed). The kit basically contains the EWP and electronic controller with other bits and pieces. I'm hoping to have a similar setup like yours..
#18 |
![]() Drives: Future Yaris! Join Date: Oct 2009
Why don't you make this A LOT easier on yourself ....
Simply add an electric motor on the stock water pump? That way you don't need to change anything and you already know which way the pump is spinning? (by looking at it when the belt is on) why wouldn't you do this instead of changing everything? |
| Drinking from the black pump | XOG | Performance Modifications | 1 | 04-20-2007 05:49 PM |
| sum dude asked if my car was electric... | Blenjar | General Yaris / Vitz Discussion | 17 | 01-12-2007 10:39 PM |
| what water temp does cooling fan turn on | gonzo452001 | General Yaris / Vitz Discussion | 10 | 11-07-2006 05:50 AM |
| [Detail] [as to make ] Auto Laudering | Sérgio Barros | Wash, Wax, Detailing, Exterior Repairs | 4 | 08-22-2006 03:56 AM |
