anyway duty with usps are not expensive.. if u go with fedex or ups.. u add 55$ + dutie.... and at canada post they only charge 5$+ duties
![]() Drives: 2005 Toyota Echo Hatchback Join Date: Aug 2007
How about for Echo hatch?
Does anybody know if this will work in the Echo Hatch (i.e. the previous generation Yaris)?
Thanks! |
![]() ![]() ![]() Drives: '07 Yaris S Sedan M5 Join Date: Jul 2007
This will be in my to buy/ to do list.
I saw one at eBay for $96 + $8 shipping. NST NonStopTuning Toyota Yaris Short Shift Kit
Riceman43
this thing doesnt fit on a 2009 3dr LB...It doesnt rest far enough down so you put the cotter pin in...
The one with cheese on it
Drives: '10 Corolla S Join Date: Oct 2008
Small cars are a big deal
Drives: 2007 Yaris Liftback Join Date: Feb 2006
I wonder why Toyota would change something like that mid-cycle?
Subcompact Culture: The Small car blog |
Riceman43
Ok guys Upon Cali's request Iam posting what i did to make this work...Sorry my camera is screwed so no pics but dont think they are needed..
Basically from stock there is absolutely no way the device will sit far enough down so the cotter pin can slide in...So i put my toyota cap on and thought for about 2mins' (as long as can without getting a headache) I pulled out my dremel and put the following bit on it..(I know but it was the only one i had to work with) http://www.dremel.com/en-us/Attachme...l.aspx?pid=562 I basically cut down the bottom side of the blk until i couldnot see any red left..I also had to cut a little off the edges..So now the blk is completely silver on the bottom...I did have to test fit about 4 times until i got it just right..Once i had enough cut down I had to press down on the blk pretty hard and it slid all the way down for the cotter pin to slide..Tested a short drive everything seems fine..took me about 20mins to do this...Maybe NST can look into this and make a ver.2 for us 08-09 owners... Also 1 thing to point out...I dont think it is the depth of the channel on the blk its the edges that are stopping the thing from resting flat...so someone might try just fileing the edges down instead of the whole bottom side. |
Thanks for the write up -- glad you got it to work.
Maybe a thinner version with and without a washer would fit both versions?
Riceman43
![]() ![]() Drives: Yaris Sol 1.3 dual VVTi 101hp Join Date: Apr 2009
hi all plp... perhaps I missed something... does this actually work on the new yaris 1.33 (100hp) model 2009??
thank you in advance kind regards, davide
Yaris Sol 1.33 dual VVTi model 09 - 5dr 1. full ZX1 additive treatment: oil + cooler + fuel 2. NB treatment: motor oil 3. K&N panel air filter (part num. 33-2211) 4. Fuchs Silkolene Pro SRG 75 gear oil (the best!) 5. UltraRacing 19mm rear sway bar |
Caw?
I don't like the idea of spending close to $100 on something thats made for my car and having to shave it down to make it fit. But thats just me. I'll buy one if the fitting problems get fixed.
![]() ![]() Drives: 07 Yaris 3DR Join Date: Apr 2007
$98 for a little piece of aluminum? wtf?
やりすぎだ~
I love my full NST kit.
If anyone needs additional instructions, here's my how-to: http://subcompactculture.com/NST_Dri..._Products.html
![]() ![]() ![]() ![]() Drives: Yaris HB Join Date: Jul 2007
Where was the install moved to? Looks like I scored one, and will need installation instructions.
#16 | |
http://www.subcompactculture.com/200...nst-short.html
Links to http://www.subcompactculture.com/NST..._Products.html which ... does not exist.
Found this http://scionlife.com/forums/showthread.php?t=124859 instead -- usable! Last edited by swidd; 03-29-2011 at 09:35 AM. |
#18 | |
| NEW GROUP BUY: NST Short Shift Kit (NonStopTuning) | NonStopTuning | NonStopTuning | 245 | 08-28-2007 04:53 PM |
| short shift: NST or TRD? | cali yaris | Performance Modifications | 21 | 07-07-2007 04:38 PM |
| Paddle Shift Kit | drell42 | Performance Modifications | 17 | 04-14-2007 04:44 PM |
| Feb Shift Knob Sale From TWM! | TWM Performance | Sponsors Classifieds Area | 2 | 02-18-2007 11:15 PM |
| Having Trouble with TWM Short Shift Install. Need Help | xfatefailsx07 | Performance Modifications | 3 | 10-10-2006 02:38 AM |
