Old 04-28-2009, 09:29 AM   #1
suiller
Drives: Yaris Sol 1.3 dual VVTi 101hp
so this will work also on the new 2009 model?? (motor bay of course)
Yaris Sol 1.33 dual VVTi model 09 - 5dr
1. full ZX1 additive treatment: oil + cooler + fuel
2. NB treatment: motor oil
3. K&N panel air filter (part num. 33-2211)
4. Fuchs Silkolene Pro SRG 75 gear oil (the best!)
5. UltraRacing 19mm rear sway bar
suiller is offline   Reply With Quote
Old 04-27-2009, 05:32 PM   #2
Mouse
Drives: 2007 MX5
Well this weekend I installed the engine bay kit and I was only able to get the pin that you guys supply with the kit. I could not get the OEM pin on. Either way I installed it and amazed what a difference it made together with the 3" extension.
I also installed one of the cable bushings(the one that goes on top of the SSK). The problem with the smaller bushing is that I could not remove it from the OEM piece. I tried to pry it out like I did with the other but no luck. It looks like I would have to cut the rubber bushing out to install the new one. I do have an 09' liftback.
Mouse is offline   Reply With Quote
Old 06-01-2009, 12:35 PM   #3
regal
Drives: 09 Yaris 3 Dr White LB
What are the odds of this NST I ordered fitting my 09 3D LB and if it doesn't fit can I send it back to micro-image for the in-cabin version?
regal is offline   Reply With Quote
Old 04-28-2009, 10:40 AM   #4
Mouse
Drives: 2007 MX5
So far mine seems to be working good....really good actually.
Old 04-28-2009, 11:04 AM   #5
suiller
perfect thx
Old 05-01-2009, 12:42 AM   #6
White Yaris
Broke Tuner
White Yaris's Avatar
Drives: White Yaris
Hi, im not sure where to ask. I bought SSK 2 and it didnt come with plastic thing removal thing. Is there other ways to take it out?
EVERYTHING YOU KNOW IS WRONG
White Yaris is offline   Reply With Quote
Old 05-07-2009, 08:59 PM   #7
NonStopTuning
Both versions of the NST SSK are again in stock and ready for immediate delivery via USPS Priority Mail with Delivery Confirmation...
http://www.nonstoptuning.com/pShiftNST.htm
Come and get 'em!!!
Old 05-11-2009, 03:52 PM   #8
suiller
dear NST... does the item NSTSSK09 will fit on 1.33 dual VVTi (the new 2009 1.3 engine AKA NR-FE1) ?? thx
if not which item should I get?
Old 05-12-2009, 04:50 PM   #9
NonStopTuning
Unfortunately we have not tested with this engine. You are welcome to place an order with us (SSK, SSK-2, or both) and return them if they do not fit.
Please feel free to contact us by phone, 281-917-0221 ... or look for me on AIM at the screen name "NSTonAIM" should you wish to chat further.
Thank you
MIKE @ NST
www.NonStopTuning.com
Old 05-16-2009, 10:59 AM   #10
NonStopTuning
Anyone else?!
MIKE @ NST
Old 05-16-2009, 07:49 PM   #11
lammy29
Drives: Yaris
uk 1.3 (2sz-fe) for in cabin and short shifter
lammy29 is offline   Reply With Quote
Old 05-17-2009, 05:02 PM   #12
NonStopTuning
I'm not sure I follow you on this one...
MIKE @ NST
Old 05-17-2009, 07:13 PM   #13
lammy29
Drives: Yaris
just wondering will it fit 2007 1.3 yaris?
Old 08-21-2009, 02:09 AM   #14
aucorium
AKA Samurai Racer
aucorium's Avatar
Drives: Yaris 2006
it should fit if you have the 2NZFE 1300 , i have a NST crank pulley made for the 1,5 on my 1.3 , fits and works 100% next i need the short shifter setup ;-)
JDMtuner
Import Performance Tuning
www.jdmtuner.co.za
Old 06-06-2009, 01:55 PM   #15
d1nzfe
Drives: 1NZ-FE
i know i needed to mod it to fix onto 1.5 sedan :(
d1nzfe is offline   Reply With Quote
Old 06-18-2009, 06:19 PM   #16
NonStopTuning
For anyone who may be concerned...
Order an NSK SSK from NonStopTuning for your Yaris, and if for any reason it does not fit, we would be more than happy to authorize a return and offer a full refund. All you would have to do would be to call us up or send us a quick email.
I'm pretty sure MicroImageOnline has a very similar/same policy.
99% of our customers that I am aware of, have had no issues to speak of.
NST FTW
MIKE @ NST
Old 07-01-2009, 07:03 PM   #17
NonStopTuning
Anyone else?!
MIKE @ NST
Old 07-02-2009, 12:51 AM   #18
tk-421
tk-421's Avatar
Drives: 5D-07-LB
So far I've installed the SSKv1, SSKv2 and shifter cable bushings. Along with some Redline MT90 tranny oil and some WD40 here and there, it's the best economy-level setup you can have on the Yaris IMO. Short throws, and almost no effort when shifting gears.
Can't wait to see what other goodies you have in store for us, Mike... NST FTMFW!
NST (NonStopTuning) Pulleys. Info, Specs, User Data... NonStopTuning Performance Modifications 636 12-13-2013 09:47 PM
NEW GROUP BUY: NST Short Shift Kit (NonStopTuning) NonStopTuning NonStopTuning 245 08-28-2007 03:53 PM
short shift: NST or TRD? cali yaris Performance Modifications 21 07-07-2007 03:38 PM
