![]() ![]() ![]() Drives: Toyota Yaris 1.3 vvti cvt Join Date: May 2007
What octane number is standard in the USA for example?
Here in the Netherlands for petrol it's 95 and 98, anyway not lower than 95. |
g_man
Drives: Yaris 5 Door Join Date: Aug 2007
octain #
I believe standard Octain in the States and Canada is 87 for regular fuel.
![]() ![]() ![]() Drives: Black Yaris YRS 3dr Manual Join Date: Aug 2007
![]() ![]() Drives: Yaris LB Join Date: May 2007
My most recent tank: 95% city, 5% hwy = 34.23 mpg!
Spool'd
Drives: 07 yaris, 16 gen coupe rspec Join Date: Aug 2007
In Toronto we get 87 octane as standard, 89 and 91 as premiums, and only one gas station offers more than 91, which is Sunoco. They offer "ultra94" which, as you can probably tell, 94 octane. Has anyone ever tried those octane boosters in the yaris? I've seen some from NOS that say they make any pump gas into 113 octane race fuel. Does that stuff really work? what would it do to our engines if used?
#6 | |
Clean and (dis)Functional
Drives: Yaris 2dr--Black Betty Join Date: Mar 2007
Otherwise.....+1 with PK198105
____________ Old School Cobble Jockey
#7 | |
Spool'd
Of course I will only use normal gas for the Yaris, just wanted to know what it would do if used. Haha, I don't see a point of buying a can of this stuff for $20. Just curious. And I know with cars meant for premium, it makes a difference. One of my friends has a 1997 acura TL with the 3.2 engine auto trans, he says he sees a 40km difference between a tank of 87 and a tank of 91. Another friend has an '89 mustang GT cobra, and his engine gets real bad knock if he uses anything except 91 and 94 octanes. Even my own experience when I had my 94 Probe GT 2.5L MTX, I would see about 50kms less on a tank of 87 octane and there would be a noticeable loss in power and the engine would bog down sometimes with 87 if I put 100% throttle from a stop. The one thing I don't like about buying premium is the mark up in price. I was reading an article somewhere saying that 91 only costs the gas stations 2-2.5 cents a litre more than 87, but on average they charge 10 cents a litre more for 91 over 87. But then if 91 was only 3 cents a litre more, I'm sure most people would be buying 91. All in all, from what I've read, cars designed to run on 87 should be used with 87, as the higher octane won't get power worth the cost over 87. |
Steals terrorist's lunch
Drives: 2007 Yaris Liftback Join Date: Mar 2007
It can vary a bit in the U.S., but I'd say that at least 90% of the stations in the country serve 87 (regular), 89 (super) and 93 (premium or supreme) octane, with most vehicles capable of working with the 87.
Like just about every other measurement system, the U.S. uses a screwed up one when it comes to measuring octane. See: http://en.wikipedia.org/wiki/Octane_...rement_methods
- Brian Share the Road I often carry 2 carpool passengers and mountain bikes or snowboards/skis over a 4,500 foot elevation difference. Click the graphic above to see my detailed mileage logs. |
#9 | |
![]() ![]() ![]() ![]() ![]() Drives: 06 3-dr auto RS Join Date: Jan 2006
IMHO, cars need to be designed to take advantage of high octane fuels in order to really benefit from them. As far as I know, the Yaris is not designed to take advantage of very high octane numbers. I have tried a tank of octane 92 which is high but not exceedingly high and have not noticed any significant difference in terms of mpg. Yet admittedly, a short period of experiment in an uncontrolled environment can hardly be regarded as conclusive. Anyhow, the car's computer, aka ECU will take care of any slight change in the octane number of the fuel. Whether high numbers up to, say, 113 are still within or already outside the computers manageable range is beyond my limited knowledge. As many of us have noticed, this is a much debated subject (NB: this is an understatement ) and I would prefer to leave it here. The bottom line is using slightly higher octane fuel will very probably not do harm to the engine of the Yaris. Honestly, though I cannot remember where, I have read articles/posts saying that a car that requires regular fuel may benefit from a higher octane number when its engine is old and under-maintained, or when it is required to work very hard to carry heavy loads or drive up very long and steep slops.In short, I tend to believe the two gentlemen above .Something for further reference:http://en.autos.sympatico.msn.ca/Gui...mentid=5156081 http://articles.moneycentral.msn.com...OnYourCar.aspx |
3,300+ at one point.. >:(
Drives: 2010 Hatchback RS Join Date: Aug 2007
On average, I can get between 620 and 650km per tank...which works out to be in the 40mpg range...give or take, since It's a 42L tank(roughly 11 gallons)
#12 | |
It's pretty good...well, when construction workers aren't working on main highways in the middle of summer! So yeah, it might not be a smooth ride, even in a Yaris. I am going to work on my "lead foot" problem. Quite a few Yaris drivers have told me they can get close to 800km on a tank..which is closer to the 50mpg that toyota lists for the Yaris. For once, I'd like to see my numbers get that high!
#13 | |
. Must be an all highway number. Anyway, I think amongst non-hypermilers, only UncleYaris (a fellow member) has once posted an mpg number exceeding 50 (refers to Imperial gallons). Forgive me Uncle, if you are in fact a hypermiler or if I remember your numbers incorrectly.Cheers! |
#14 | |
Yep, it was 40 for city driving, and 50 for highway driving. Usually, i'm about 70% city, 30% highway. I'm actually leaving PEI and moving to Saint John, New Brunswick tomorrow(Thursday), so I'll drive a little bit slower to get there, to see if I can get any better mileage (The speed limit is 110km/hour, but I usually do 125 or 130...I'll try sticking around 110 and seeing what happens). |
#15 |
Wish you all the best for the move!
Safe and happy and ECONOMICAL motoring! |
#16 |
![]() ![]() ![]() ![]() Drives: Yaris Sedan (auto) Join Date: Jun 2007
I took the Yaris in for an early oil change last week and they lowered my psi from 40 to 32. I put the car to 40 almost right away, so I forgot how much better the ride was at 32. I could tell instantly they had lowered the psi, because the car felt like it was in sand off the start and the cornering was really bad. Tons of sidewall flex. The ride was noticeably better over bumps as well.
I decided to leave the tires at 32psi to see what kind of difference I would get in fuel economy. I'd say it made no difference. I thought for sure it would, because it sure felt like I had to give the car more gas to get going. I put it back to 36psi now as I do not like at all how the car handles around corners at 32psi and I'm also not a fan of the harsh ride at 40psi. I still got: 5.167 l/100km 54.67 imperial mpg Or 45.52 US mpg on over 500kms of driving at 32psi. My overall average is actually worse than this, but that could also be because the car is still breaking in, but I'm averaging 5.254 l/100km, 53.76 imperial mpg or 44.77 us mpg after 8 tanks and about 4400 kms. |
#17 |
![]() Drives: 2007 Yaris TS Join Date: Aug 2007
OK, I know, not representative for the time being, because it the first time I have refuelled it...
http://www.spritmonitor.de/de/detailansicht/197750.html And currently -after 1 1/2 weeks owning the car- my board computer says 7.0l / 100km. But due to the rush hour I mostly drive slow up to 80km/h - just sometimes up to 120km/h. greetz joyts
Donīt drive faster than your guardian angle can fly! |
#18 | |
Thank you joyts! |
