Old 05-10-2011, 08:49 PM   #1
Chaldon
Drives: 08 Yaris 3d
My favorite post:
Originally Posted by eric81 View Post
The rear bumper snaps into place. The car weighs 2200 lbs. The stock muffler comes in and goes out on the same side. The max RPM is 6500. The car stops at 117 MPH. The stock air box has a 1" inlet for air, 2 air filters that are super restraining, and weighs far too much. The engine gets hot after it's been running for awhile. USA Yarii seem to have a cross threaded A/F sensor in the exhaust manifold. The stock header is only 1" in diameter at the smallest point. The rear wiper has a clip-on it that can be broken off or cut off to allow you to change and clean it easier. Some cars do not have a cabin air filter. The stock oil is Synthetic, but the extended warranty only covers regular oil, so you have to pay $8 to get the right oil put in your car. The low jack system really does work. The correct place to plug in a Tach is at the OBD port (where the dealership plugs their thing in to read what your car is doing). The engine travels over 5" when you rev it up. The catalytic convertor acts as a resonator as well as a catalytic convertor. You can change the look of your car simply by scratching it with rocks (I have great kids, and luckily they are still alive... barely). The stock auto can go from 0-60 in 11.6 seconds. The highest recommended speed for the Yaris is 68 MPH. I will post more stuff later. Drive On!
Now I want to swap in better engine air filter and look into a better air box as well. How the hell do I get LowJack to work?
- Cabin filters are under $20 at Kragen.
- 2008 Yaris uses the same high-beam bulbs as a 2008 Prius
- The rear wheels don't need alignments- just the front. and stock suspension isn't very adjustable anyway.
- Half a quart of Marvel Mystery Oil can be added to a full crank case
- With concerns of a hydroplaning incident I've moved up to 50k mile 185/65/15 from Firestone (meant for a Prius in wet weather) with no problems... w/ regular hard driving and no rubbing on bounces with max turn. I checked ;)
- With the seat folded down flat the car sleeps 4 midgets sideways in the back. 3 in sleeping bags and 2 if you can't find the fitted kind in their size
- The cigarette lighter won't work with the key in OFF
- I'm about the add a police horn to a buttin next to the emergency light switch.
- LED day time running headlights can be mounted in the fog light cups without removing them. But you still have to figure out wiring lol
- I have cheap pop off hubcaps that stick out from the tires. I use silver Hammered spray paint after sanding to fix the scratches and it looks cooler and cooler with every coat. Some bastard better not steal them
- Aftermarket window tinting looks checkered with polarized glasses on
- The front windows including the little corner glass is already factory tinted a little bit. Like %8 or somthing.
- It's hard to find your Yaris in a crowded parking lot and you've forgotten exactly where you parked because it was hiding behind that SUV all this time
- I get 32mpg because I average 80mph and I'm fine with that
- Ive run out with randoms for now
Chaldon is offline   Reply With Quote
Old 11-18-2008, 09:33 PM   #2
eric81
eric81's Avatar
Drives: Toyota Salesman
I guess mine is special. I will have to put that in myt car description. 1.5L LB Special.
eric81 is offline   Reply With Quote
Old 11-19-2008, 04:36 PM   #3
Latka
Drives: 0x Yaris Hatchback
I thought there was a switch in the seat - I know there is for airbags in some cars where it won't set the airbag off unless there's something like 40 pounds on the seat.
Latka is offline   Reply With Quote
Old 11-19-2008, 04:44 PM   #4
slvryaris
slvryaris's Avatar
Drives: 2007 Yaris Sedan S
I just want to know where the crank is for the jack. Its not in the place shown in the manual unless i am blind.
slvryaris is offline   Reply With Quote
Old 11-22-2010, 07:09 PM   #5
swidd
Drives: Yaris HB
Wait, there's two filters in the air filter box? I've only seen one filter, and replace it regularly. Should I be looking for a 2nd filter as well? 80,000 adventurous miles...
swidd is offline   Reply With Quote
Old 11-22-2010, 08:07 PM   #6
gabriel2012
Drives: 2011 Base Sedan
the second filter is behind the glovebox, look at page 165 of your manual, this is a cabin air filter which just makes sure clean air comes out from the a/c instead of dust and other stuff.
gabriel2012 is offline   Reply With Quote
Old 11-23-2010, 09:43 AM   #7
djct_watt
Drives: 2010 NCP91 5spd
It works!!!!!! Awesome!!!!! I always hated not being able to adjust the dash brightness... I swear, adjusting it is about as clear as a super contra cheat code, but I'm glad it's there!!! Thanks Bella!
The best modification you can make is between the steering wheel and driver's seat.
djct_watt is offline   Reply With Quote
Old 11-23-2010, 10:48 AM   #8
djct_watt
Old 11-24-2010, 10:00 AM   #9
djct_watt
Oil is usually clear/yellow when new
Old 11-24-2010, 11:29 AM   #10
RedRide
RedRide's Avatar
A Yaris is more fun to drive when it's all paid for... as mine is.
Old 08-15-2012, 02:15 PM   #11
otterhere
Drives: 2008 Yaris 3-door Meteorite
Word. At LEAST I paid cash for mine and not a bunch in interest; that's SOME consolation!
otterhere is offline   Reply With Quote
Old 08-15-2012, 11:54 PM   #12
nookandcrannycar
Ditto. Pay interest = never.
Old 11-25-2010, 05:46 PM   #13
startree
startree's Avatar
Drives: 2009 Yaris YR: 3 dr hatch
hey my first post here, so hi all!
Thanks heaps for the tips, i'm going to spend some quality time with my yaris right now...
my tip, and i'm sure you all know this one: put your warm bottle of water or drink in the holder next to the steering wheel and put the air con on cool and angle the vents at the bottle and voila! ice cold drinks again!!
startree is offline   Reply With Quote
Old 01-07-2011, 07:28 PM   #14
Crash
Drives: 2007 Yaris
The headrest for the back seats go up and down. It took me about an hour to figure that, thinking this seat is really uncomfortable.
The engine trouble light also keeps track of when you need to change the oil. You reset it using the ignition key and the trip button.
Crash is offline   Reply With Quote
Old 01-07-2011, 10:49 PM   #15
alch3miss
alch3miss's Avatar
Drives: Toyota Yaris
A Yaris equipped with TEIN basic damper coilovers delivers impeccable control! Check out my autox results here: https://axwaresystems.com/axorm/file...232009_fin.htm
alch3miss is offline   Reply With Quote
Old 01-08-2011, 12:13 AM   #16
Chuck G
Drives: 2010 Yaris Sedan
The Yaris steering wheel tastes of Peppermint.
Shhhh...........................................
Old 01-08-2011, 08:49 PM   #17
JetfireK
Drives: 2008 3 Dr Liftback
YARIS PLENTIFUL CUP HOLDERS....
ok this thread was lost so lets get it started again....
under the front passenger seat slide handle there is a flap in the carpet
with the VIN on it
Does anyone know how many cup holders are in the Yaris Liftback. The two up front allow the airconditioner to keep the drinks very cold . Then there is one on each front door...and there may be some in the back.
The cup holders are GRAND AND SURPASS OTHER AUTOS COSTING MUCH MORE...
JetfireK is offline   Reply With Quote
Old 01-08-2011, 10:08 PM   #18
R2D2
Crazy Oil Sniffer
R2D2's Avatar
Drives: MM 09 Yaris 5 Dr LB "Click"
2 in front of the vents
2 in the front doors
One in the rear of the center console
2 in the rear doors (on my 09 5 dr that is-not sure about the 3dr)
"The howl was the sound of God’s casting pot, the morphing of my cells into shape, the forming of oceans out of molten premordial plasma. And I could feel it. I could cry for it. I could cry with it."
-The Fitful One
R2D2 is offline   Reply With Quote
Interesting Info on the Yaris from AU mikeukrainetz General Yaris / Vitz Discussion 3 11-24-2006 10:18 PM
