![]() ![]() ![]() ![]() Drives: 2007 Black Yaris sedan Join Date: Sep 2006
Another reason to buy a torque damper for the engine.
![]() ![]() ![]() Drives: 2008 Yaris Sedan Join Date: Oct 2008
super duper M*******TOR
Drives: 2007 jahPANIS egg(Sarao Phil) Join Date: Oct 2008
^ IT IS LOUD!
![]() if u close ur eyes u wouldn't believe it's the yaris! on idle, bog bog bog bog!
Broke Tuner
that sucks... Hey you had fun with it right?
^ absolutely! i like the 4-2-1 type header but the weld on the o2 sensor where it broke had rust on them...IMO, the weld on the last tube was not primo!
got me a dc header (4-1) from garm for a very reasonable price!
Vroom Vroom Beep Beep
I have thought about this over the last few weeks and I have the answer to why this happened. There is a flaw in Weapons design of the header that Megan and Toyota didn't have. Do you remember the side bolt that was on the bottom of the stock exhaust? That is for this very sort of occurence. It prevents the exhaust from rattling around and reduces vibrations. This is why I haven't had a problem with my megan. Other people who have other headers maybe even the Weapon itself might not have the same issue as you did. But not having that extra anchoring point is likely the culprit.
read the entire thread the reason has already been found.
Just because your theory on what happened is accepted doesn't mean it was the only factor. I'm just offering more into what caused the malfunction. Theres a bunch of things wrong with this set up.
how, it bolts on the same way.if you dont put the springs back on the bolts like it is stock any header will snap with fatigue.
no need to argue boys, weapon r gave me a warranty on this!
![]() yup, only weapon r header doesn't have a side bolt! |
nice of them to do that.
yup, they decided it was their fault and i'm one happy customer!
§†ęĄ¶‡Ћ-NCP96
so do you know if weapon r is going to fix that problem?
They should for future models.
i suppose it could be a problem but i have had know issues for 2 years and 2 cars. the point is you need the springs, they have to be there..
imo, kou has a point here in installing the spring bolt because it would help lessen the vibration but, to say that's the answer to the problem w/o knowing all the factors would be foolish...
i think we should ask someone who has the nitto mid-pipe and weapon r header installed in their car and give us their opinions about it because mine did not fit snugly while installing it with the oem spring bolt! i think weapon r header has it only for less than 2 yrs so i wouldn't know where kou got his 2 headers!... |
| Megan Header Install [pics] | Chris07LB | Performance Modifications | 132 | 09-29-2010 03:41 PM |
| Are We Still Stuck With the 4-1 Headers? | Sabretooth | Performance Modifications | 31 | 02-20-2009 08:57 PM |
| DC sports header installed. | largeorangefont | Performance Modifications | 41 | 09-20-2007 09:14 PM |
| Weapon-R Header (4-2-1) | CASTREX | Performance Modifications | 28 | 02-19-2007 01:57 PM |
| Who got that weapon header? | Galavoxx | Performance Modifications | 1 | 12-04-2006 09:11 PM |
