![]() Drives: Black NCP91R Join Date: Oct 2008
Looks great!
Two things though: 1. Did you lift both front tires totally when installing the bar? (common mistake of strut bar installation that leads to "USELESS" bar) 2. Did you adjust the bar (you use Tanabe, it can be turned to put initial tension to suspension geometry) to give you the most initial tension before you tightened all bolts (and finally the gripping bolt)? If you done that correctly, you 'almost' never need to re-tightened those bolts again! P.S.: Actually, the chasis is rigid enough for handling all the weight transfer and suspension flexing (or else the windshield will breaking everytime the car doing hard cornering..), but the point of strut bar is only optimising the outer suspension when cornering. A good set springs and struts (or coilover) will do so much better, and cost more of course.
![]() Drives: '07 Hatchback Join Date: Oct 2008
Is there anyway to install Tanabe strut tower without removing all the wipers and the splash shields? Any tips on installation?
TRIM HUNTER
im not sure with the tanabe but the beatrush/c-one/braille one requires it.
Modded Moderator
Nope, but trust me, it's pretty easy getting those parts on and off. I've done it twice. Once for the tanabe bar and once for the spring install.
There is a DIY here for that specific bar. It was done just taking the wheels off to allow access from underneath. I did mine when I put in my TRD suspension package, removing all the stated BS in the process. My motive for removing was not because of the suspension or access to the nuts securing the top of the struts, it was to clean out debris from trees etc that had accumulated inside. Again, the Tanabe can be done without removing all the BS. The DIY also makes note of the hardware swap. I did that too because the hardware in my opinion also was less than adequate. No comment on the bar itself. I got it cheap and did it all at once. Good luck.
aka Jack Wolfskin
![]() ![]() ![]() ![]() Drives: 08 3DR 5M Bayou Blue; 09 Fos Join Date: Oct 2008
Hey Bike - does that wiring kit help smooth out the engine- My sisters 3 dr is like Jekl and Hyde - some days smooth and other it wont get out of its =way and runs like there is spark scatter or some 'puter problem real buzzy and no pull. Whats up with that?
- S's Bro |
The ground kit made a big difference in the stereo system. It has no hums or buzzes at all. As for the performance, I've never had any problems with sputters. My plugs fire smooth all the time, even in the morning when it's cold. Don't know if it's related to the ground kit.... By the way, your avatar is looks like a heartbreaker !!
#9 | |
![]() ![]() Drives: Jbody Join Date: Oct 2008
Nice addition under the hood!
![]() ![]() ![]() ![]() Drives: Soon to be LFA Join Date: Oct 2008
very nice i want one so bad
![]() ![]() ![]() Drives: 2007 MX5 Join Date: Feb 2009
Would the yaris benefit from a 3-point front strut bar?
If so, why has one not been developed yet? |
I noticed a difference with mine. Especially on hard turns or really quick lane changes. Also was able to install mine without lifting car up but was really cramped fitting hand up there.
![]() ![]() Drives: vitz rs Join Date: Apr 2011
They go shopping using front bar.
They go driving using rear. |
![]() ![]() ![]() Drives: 2011 Yaris RS 5 door 5 spd Join Date: Aug 2012
Just finished installing mine. Nice product with nice fittings and hardware. Simple install. Felt a difference in steering input and it seems as if it let's you enter harder into corners and allows some room for mistakes. Not a huge difference though. Probably would have passed on it and put the money towards getting Garms intake manifold. Definitely looks good though.
#16 | |
![]() ![]() Drives: 06' Yaris 1.3l Join Date: Jul 2014
I'm thinking of getting one but not unsure on how to install. would you mind briefly doing over the details? Thanks |
install
Very easy. Jack up the car and remove the front wheels. Remove the tower brackets from the tanabe bar and and bolt up each bracket on the two strut towers (two bolts per bracket). It gets tight under the wheel well when trying to tighten the bolts up for the brackets but it works if you have the right tools. Then attach the bar to the brackets and adjust and tighten accordingly. Then re install the wheels and drop the car. Then inspect the install and make sure everything is still nice and tight. Then drive and enjoy. Also, after a couple hundred kilometers check everything again and make sure everything is still tight and secure. Its a really easy install with basic tools don't be intimidated by it. But its very important that you do the entire install with the car in the air and the load off of the front wheels.
Good luck! |
Looks good!
| Installed the Tanabe Strut bar but had to remove my ground wire kit.. | vacantj | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 6 | 10-01-2007 01:56 PM |
| **NEW ITEM** Tanabe Sustec Front strut bars | C2AUTOSPL | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 5 | 04-27-2007 09:54 PM |
| C-ONE Front Strut Tower Bar - Installed & Impressions (Pics to Come) | bigsky2 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 20 | 01-10-2007 06:53 PM |
| 2006-2007 Yaris 4 Door Front Strut Bar AEM/DC Sport | KenAEM | Performance Modifications | 2 | 10-07-2006 02:26 AM |
| 2006-2007 Yaris 4 Door Front Strut Bar AEM/DC Sport | KenAEM | General Yaris / Vitz Discussion | 3 | 08-30-2006 09:43 PM |
