Old 10-22-2008, 03:08 PM   #1
BailOut
Steals terrorist's lunch
BailOut's Avatar
but bailout, wouldnt that same issue effect those of us living in warm climates much less if any at all? the coldest it really gets here is like 60 degrees...
Correct. Anywhere that doesn't see the colder temperatures won't notice this issue except when the car is warming up from a cold start. It's more an issue for the northern latitudes and/or higher altitudes.
- Brian
Share the Road
Old 10-22-2008, 03:10 PM   #2
dvlnblkdrs
Shush!
dvlnblkdrs's Avatar
Drives: 2007 toyota yaris
yay i got one right! lol
Old 10-22-2008, 04:22 PM   #3
natethegreat38
Party like a Barack star
natethegreat38's Avatar
Drives: '08 LB MT
I guess Bailout is pretty much the MPG authority here on the forum...
i don't feel like creating another signature, yet. Give it another week...
natethegreat38 is offline   Reply With Quote
Old 10-22-2008, 04:34 PM   #4
Sodium Duck
╚══════════RN
Sodium Duck's Avatar
Drives: 2008 Liftback
Yes. That took me about 3 hours to figure out, lol.
Old 10-22-2008, 06:26 PM   #5
dvlnblkdrs
Shush!
dvlnblkdrs's Avatar
indeed.. hes the enviornmental guru if you will..
Old 10-22-2008, 08:36 PM   #6
eco
eco's Avatar
Drives: 2007 Black Yaris sedan
I have several things to add,bailout is well known around here for exactly that,but there are some problems.I have a low pressure thermostat cap,and a low temp thermostat,(I have scanguage2)my old driving temp was 183-186,now its 159-163,I have had no effect in fuel milage,I swear.
And we have talked about turning off the engine at a light,all it does is piss people off behind you,these lights are already to short in my state,GA,to try and always look at the light,turn your engine on,put it into gear,and then go,that takes about 3-5 seconds if your fast,10 seconds if your slow,now imagine if everyone in the line tryed this,maybe 3-4 cars would get past the light,this is a big waste of time,unless your a die hard hypermiler.
eco is offline   Reply With Quote
Old 10-23-2008, 12:43 AM   #7
BailOut
BailOut's Avatar
I'm not sure what to make of that as when my temps are that low all of the rich mixture signs are there (low MPG, high idle, etc.). Perhaps your ECU has relearned the temperature zone you've forced it into? Or perhaps your mileage was already low due to aggressive driving so the dip with the lower coolant temperature wasn't so noticeable? It'll be hard to tell without having your mileage logs from both before and after the thermostat changes available.
Whoa. Even with an AT-equipped vehicle that sounds slow, especially if your starting in Neutral. With the MT I've never caused a delay for anyone as if I'm in front I watch the lights to know when to restart and am quite often the first one off the line (albeit at a moderate acceleration pace), or even if I miss the timing most folk's reaction times are so slow that I end up taking off at the same time as the other vehicles. If I'm back in the pack I wait until the car 2 ahead of mine starts moving before I start up and it works out just fine.
- Brian
Share the Road
Old 10-22-2008, 08:52 PM   #8
dvlnblkdrs
Shush!
dvlnblkdrs's Avatar
indeed, but there is nothing saying that you must do this.. it is worth it to some, not worth it to most. there are so many other ways, most have been mentioned that have a greater effect on ur mpg. utilize those and you will be green and others will envy ur mpg
Old 10-23-2008, 02:08 AM   #9
AznGouki
Metsu
Drives: NCP91 ; E36
BailOut, you got some amazing mpg marks by far!! Good tips too. I may try this vent blocking method.
AznGouki is offline   Reply With Quote
Old 10-23-2008, 03:53 AM   #10
yarswiss
Albino truck smasher
yarswiss's Avatar
Drives: '07 Yaris LB Auto
Here are my two cents with regards to what you posted:
-Coast as much as possible (DFCO)
-If you are going downhill, go into N to build up speed so when you hit an uphill segment, you can bleed off more speed. In fact, even on small downgrades I prefer N over DFCO as DFCO slows the car down much faster. While in N, I get between 50-100 mpg depending on the speed I am going, whereas in DFCO you get infinite MPG, but you will need to accelerate more at the end of the hill, and from my experience, gaining speed in N gets better MPG.
-Drive 55MPH on the highway
-I find 50-53mph is the sweet spot when it comes to MPG figures. While it may be hard to drive this "slow" due to majority of drivers ignoring the speed limit, with a bit of "sang froid" and awareness, you can do this.
-Coast to stop signs and lights
-If you know the behavior of the traffic lights, you can even go into N and turn the engine off while you glide up to the red light. This will take some getting used to.
-Windows cracked open about an inch to prevent fogging
Keeping the air vent open but not on also helps, even if only a little bit.
-Let car idle only for 30 seconds to warm up, otherwise none
I never idle if I can truly avoid it. As soon as my car is on, I am in motion. It is always better to just drive the vehicle, as it will warm up much faster.
Additional things:
Get a Scangauge - you truly cannot maximize your mpg without it.
Visit Cleanmpg.com and read up on their fuel-saving tips.
Pump tires to sidewall max
Remove all unnecessary weight (rear seats, spare tire if you dare)
Partially block upper grill during colder weather, and you can safely block the entire lower grill as well. I will be posting a DIY with a vinyl grill block once I am done to show what I mean.
Sadly, since I have an Auto I am "impaired" by just that much, but my last 6 tanks have been over 48mpg, and my record thus far is 53.7 mpg (440 miles on 8.2 gallons).
yarswiss is offline   Reply With Quote
Old 10-23-2008, 08:03 AM   #11
Klink10
Klink10's Avatar
With automatic?....in my books that's outstanding
Old 10-23-2008, 10:10 AM   #12
BailOut
BailOut's Avatar
yarswiss is rockin' it!
- Brian
Share the Road
Old 10-23-2008, 06:47 PM   #13
yarswiss
yarswiss's Avatar
Thanks Brian My MPG goal has been to reach or surpass you figures. Someday I will beat you!
Old 10-23-2008, 07:38 PM   #14
BailOut
BailOut's Avatar
Now is the time to do it. Gone are my days of solo commutes and light weight, and that shows in my trackable mileage.
What that number doesn't show is how utilitarian my Yaris has become. 2 carpoolers 5 days a week, outings with my Little Brother on the weekend, grocery run and most errands by bicycle instead of car (this used to be one of my high mileage times as it's all on the mostly flat valley floor), much fewer highway trips to Sacramento (which was the whole point of me setting up all of the remote tools and equipment down there), carrying 2 mountain bikes or 2-5 snowboards or pairs of skis roughly 300 days per year, etc.
All of that is much more efficient than solo commuting, and totally more efficient than any of it being done with a larger vehicle, but it does hurt the trackable MPG number.
- Brian
Share the Road
Old 07-29-2010, 04:52 PM   #15
ChrisP
Big man, small car
Drives: 2004 Yaris 1.4D4D T3 3door
Hello I'm brand new to this forum.
I bought my 2004 Yaris D4D (with 110K miles on the clock) six weeks ago and have done about 1800 miles in it. First two tank fulls after I drove the car at "normal" speeds I got 60 and 63mpg. After the third fill up I drove as carefully as I could over a 520 mile range (I couldn't stand driving so slowly any more) and got 75mpg. This was mixed town and motorway with many short journeys. This was just after an oil change, I used Castrol Edge 5W-40 Diesel.
I think it is a brilliant car and I can't believe how you can get such decent performance from such an economical car. Only one little prob, I've had to put some washers and longer bolts on the seat front mounts to tilt it back a bit.
I don't know if I've got a wheel bearing going but there is a very slight "werring" noise which is relative to road speed which gets louder the faster you go. I've jacked up and spun all four wheels but can't find any problems. Any advice about possible causes of this sort of noise would be appreciated.
ChrisP is offline   Reply With Quote
Old 07-30-2010, 02:56 PM   #16
ChrisP
Big man, small car
It seems I've made a mistake! I am in the UK, I now realise this is an American forum, so my mpg figures won't compare!! All the best you guys, I'm off to find a UK forum!
Regards
Chris
Old 07-30-2010, 04:11 PM   #17
daf62757
Nothing beats a Toyota!
daf62757's Avatar
Drives: 2013 Yaris 5 dr liftback
If DFCO actually uses no gas, then if you are running your AC when you are coasting, you are not using any fuel so it can't cost any gas to run it.
The cost difference between running the AC and not running it is so small that you really want to be hot.
Big Dave
Indianapolis, IN
Synthetic Oil....its in my car.....for at least 10,000 miles!
daf62757 is offline   Reply With Quote
Old 08-09-2010, 06:53 PM   #18
bkrownd
bkrownd's Avatar
Drives: 2010 Yaris "5-door"
Depends on the heat/humidity/sunshine in your area. Usually cracking a couple windows and running the fan at 2 is sufficient cooling for my climate.
Another thing you could time with DFCO is when to run the defogger, since it uses the AC.
bkrownd is offline   Reply With Quote
