#1 | |
Ecurie Snoopy Lives
Everyone who's had it dyno'd always say that the engine runs lean. Of course the VVTI is something else and then it turns into another animal altogether.
Sponsors and Organizations: Toyota Rally Canada Yokohama Tire Canada Western Canada Rally Association Ecurie (Team) Snoopy Canada, racing since 1966 ![]() |
![]() Drives: Black NCP91R Join Date: Oct 2008
and I thought catch tank is for dry sump system... lol
Parallel Parking Pro
On the graph I saw, the AFR went to around 10. I've not seen that many AFR charts, so I don't know if you consider that as relatively lean compared to other engines.
Leong's NCP91 Toyota Yaris E Hankook V12 Evo 195/55/15 on Buddy Club P1 replicas 15x7 ET +38 Stebel horns, Philips Silvervision turn indicator bulbs TTE Lowering Springs, Camber bolts TRD Blue brake pads Fujitsubo Super Wagolis axleback exhaust DC Sports header |
#4 | |
Break'em off some.
13:1 across the board is fine on a WOT pull. A good tune with timing and fueling adjustments should pick up about 10% on these cars. |
In a previous post I said it went very rich at high rpms but mojoyaris said that it was relatively lean. Hence the question I asked.
I knew I ran into this in a recent magazine. I went home and found the article. It's a section called Fact or Fiction in Import Tuner Magazine.
This is NOT my opinion, my own findings, nor my theory As quoted from the October 2008 issue: "Traditionally added to keep cylinder heads and intake tracts vented and clean, rather than to increase horsepower..." They tested an oil catch can on a SR20DET-swapped 240sx. Both an oil catch can and a breather filter (from Autozone) were tested, which included some dyno pulls. Their findings: "Not only did the catch can make pwer; we could actually see how it worked." They included a dyno graph. The bigger gains were between 2500 and about 3000 RPM, then again starting around 5200 RPM. The average whp with the breather filter was 242.8, while the average whp with the catch can was 244.3. Hope this helps. |
Ecurie Snoopy Lives
so I wonder if it's the vvti that makes it run rich at high Rpms, but lean at low to mid rpms. I'm happy with the catch tank n the engine, but wouldn't mind entertaining a piggy back system to tune it to run richer at mid range.
Break'em off some.
No, it is the engine mapping that dictates the fueling. VVTi has nothing to do with it.
![]() ![]() Drives: yaris Join Date: Nov 2008
oil catch tank improve engine bay cosmetic. not add performance..
multimakmurperformance.com |
#10 | |
Ecurie Snoopy Lives
Racing community would beg to differ. I've made these out of pop bottles and tubes in past cars. So it's not about cosmetics for me
#11 | |
Break'em off some.
Look into one if you run a forced induction setup. |
El Huevo
Drives: 2007 Liftback Join Date: Aug 2006
Oil Catch Cans are just eye candy in the yaris.
| The Yaris Performance Primer | eTiMaGo | Performance Modifications | 30 | 01-24-2024 04:26 AM |
| DIY: CHANGE MANUAL TRANNY OIL | ttufrosty | DIY / Maintenance / Service | 157 | 09-07-2018 01:43 PM |
| $30 Oil Catch Can, DIY | Ogredude | DIY / Maintenance / Service | 79 | 05-13-2011 11:05 AM |
| Compiled 1NZFE Used Oil Analysis | craigq | DIY / Maintenance / Service | 7 | 09-10-2007 04:27 PM |
