1NZ-FE with TD04 turbine, 0.5 bar boost
another 1nz-fe turbo hot from the oven, using e-manage blue as the piggyback.
454 whp, 1.7 bar boost, pump gas, water/meth. 501 whp, 2.2 bar boost, pump gas + avgas, no water/meth. www.viosturbo.com - World's first 500 WHP 1NZ-FE |
Equipped with wet nitrous kit
base timing not altered however
TRIM HUNTER
WHOO HOO
http://rocklandtoyota.com/IFrame.aspx?iFrameID=2388 TOYOTA PARTS AT A DISCOUNT........ Last edited by ROCKLAND TOYOTA; 06-12-2009 at 03:36 PM. |
custom intake, 1zzfe throttle body, megan fart can, NST underdrive crank pulley
**a stock yaris on this dyno pulled 91.3whp**
![]() ![]() ![]() ![]() ![]() Drives: Yaris Sedan Join Date: Sep 2006
This Doesn't count!!
I've just downloaded the "Dynolicious" in my GF's Iphone, so we where having some fun with it. I know it's not accurate but its kinda fun
. Never got to find a decent road . And my GF doesn't help... Me: "should I launch now?" GF: "you should have launched few seconds ago" ![]() 1st Run 2007 Toyota Yaris Sep 27, 2009 11:44 PM Acceleration 0-10 MPH: 1.00 sec 0-20 MPH: 2.39 sec 0-30 MPH: 3.73 sec 0-40 MPH: 5.77 sec 0-50 MPH: 7.95 sec 0-60 MPH: 10.39 sec 0-70 MPH: 14.25 sec Elapsed Time 60': 2.94 sec @ 22.6 MPH 330': 7.75 sec @ 47.8 MPH 1/8 mi: 11.68 sec @ 62.5 MPH 1000': 15.08 sec @ 72.6 MPH 1/4 mi: 17.96 sec @ 78.2 MPH Miscellaneous Max Speed: 79.3 MPH Max Acceleration: 0.47 G's Peak Horsepower: 105 HP 2nd Run Sep 27, 2009 11:48 PM Acceleration 0-10 MPH: 3.30 sec 0-20 MPH: 4.40 sec 0-30 MPH: 6.02 sec 0-40 MPH: 8.04 sec 0-50 MPH: 10.24 sec 0-60 MPH: 13.45 sec 0-70 MPH: 17.05 sec Elapsed Time 60': 5.25 sec @ 25.1 MPH 330': 10.04 sec @ 47.8 MPH 1/8 mi: 14.06 sec @ 61.6 MPH 1000': 17.52 sec @ 71.3 MPH 1/4 mi: 20.42 sec @ 78.2 MPH Miscellaneous Max Speed: 78.4 MPH Max Acceleration: 0.49 G's Peak Horsepower: 107 HP
I Drive a 129whp Yaris ;) |
Reluctantly Crouched...
OK, got some hard data for y'all. Frownonfun and I both did a dyno day this morning, and the conditions were nice. We did this on a Mustang AWD dyno, so the tech told us we're probably a few percent higher than this dyno shows, but close enough.
I'll post the scans of the sheets later. OZMDD - 107 WHP / 106 TQ, AFR -12.6. Also, 76 deg F air temp (at the intake, according to the SGII) [TRD CAI w/ bypass fitting removed and replaced with coupler, Thunder axle-back exhaust, NST 10% UD Lyte pulley.] FROWNONFUN had 145 WHP from the S/C setup we installed a few weeks ago, and that's with stock tuning (piggyback) and no other mods besides axle-back and NST Alt pulley!! I believe that's around 6 lbs boost.
nice!
looking forward to the graphs
Slowy getting there
ozmdd that alt pulley cam with the s/c so you can run the belt for the s/c. I believe frownonfun's afr was around 11.3 and the guys running the dyno did the math and said the HP number should be around 147-150hp and no CEL's
145whp is impressive on the rotrex
i still want dyno charts though!
niceeeeee! i'm jealous
i knew it had more power than the blitz when i saw the video of it taking off with a passenger inside. can't you put an intercooler on that kit too and get an advertised 150whp with it. Since he's getting 145whp as of now, that intercooler could maybe take him to 155 + whp. I believe the kit only advertised that it puts down 140whp; so you already have a good thing going! Now get a headerback exhaust setup. ;) |
#11 | ||
![]() ![]() ![]() ![]() ![]() Drives: 09 Yaris HB, 08 SR5 Tundra Join Date: Jan 2009
also i'll put an intercooler in when garm finishes that hood from the contest. and if garm still has a few dc sports headers in stock on friday i'll be picking one of those up too.
![]() I crush you like tiny clown car, because you are clown, yes? |
Slowy getting there
He has a custom axle back. but thats it for exhaust when I was talking with him today and tole him he needs to get a header and showed him where he could cut for to put in an intercooler. Also this kit can be used with the intake mani that Garm is developing. I also told him that after he gets an intercooler he could talk to Mike at NST and have him make a smaller pulley to get some more boost out of the kit. The guy also just bought some 2zz injectors just to be on the safe side.
Slowy getting there
Hey Peter one of the first times I went to Mike's shop I was talking with him about the Blitz kit and if he could make a pulley for the kit and he said he had a few options and after looking around some he ruled out one of them.
1.) make an overdrive pulley for the crank (ruled out pulley would be to close to another) 2.) make a fixed pulley for the blitz and probably through a cel and take away the option of turning the s/c off and on. 3.) make a clutched pulley and and still be able to run the s/c like normal. I think he said he could do this for about $500 or so price but worth it if you want to use you the on/off function
#14 | |
2. Garm is looking into making a smaller fixed pulley without the option of turning on/off 3. Yah, this is the most expensive option, however might be worth it. PM me more about that.. |
Slowy getting there
Just ask Mike at NST. He also makes one off pulleys that why they are so much too. The reason they won't develpoe it is because there is not a big enough market for it you know?
#16 | |
I am aware of this and I ALREADY have spoken to him. The overdrive crank pulley and smaller water pulley would have been custom made for me and I would have paid for the expense to make them. However, he seems to not want the business, so screw it. So why bother him with a clutch pulley when he won't make me the overdrive crank and smaller water pulley. Know what i'm saying? |
#17 | |
Slowy getting there
I'm sure if you seemed really interested he would make them for you call him and ask no harm in asking again
| News : 2007 Toyota Yaris - the little Euro's official arrival | VitzBoy | General Yaris / Vitz Discussion | 9 | 06-06-2017 12:51 AM |
| WR Yaris Intake Picture & Dyno. | WRLEO | Performance Modifications | 37 | 04-05-2007 07:02 PM |
| WR INTAKE SYSTEM : YOU GET $100 FOR DYNO RESULTS ! | WRLEO | Sponsors Classifieds Area | 0 | 02-22-2007 10:14 AM |
