![]() ![]() ![]() ![]() Drives: 2005 Toyota Echo Join Date: Aug 2010
Here's another thought; since 13:1 *may* be on the high side... are there thicker head gaskets we can use?
2006 Saturn Ion Redline 2005 Toyota Echo RS 4dr hatch - Cyl #3 bad - sold 2000 Toyota Echo 2dr coupe - The track car - rusty & scrapped |
![]() ![]() ![]() Drives: '08G2T Prius Join Date: Oct 2012
For a decent EMS...Still haven't found much info on whether or not I can get by with the AEM F/IC or if I'll have to step all the way into the AEM EMS2 $$$$ :( Tuning is my biggest concern at this point. Just not looking to drop $2k just yet on EMS.
#3 | |
0-60 in slow
Drives: light blue liftback Join Date: Aug 2009
Here is a comment from someone I know who used to tune cars for AEM, about using it for tuning my car.
#4 | ||
I am not sure if garm commented earlier in this thread but you can get pistons from him in a variety of thicknesses (compression ratios) so the big reason to use the prius pistons would be to save money.
I can't remember exactly what he said he had but it seems like he had 9:1, 11:1 and a 12:1. I may be a bit off on that one but you could ask him directly. |
#6 | |
Basically I just need the Cams and Cam gear with EMS...and I can test out this "prius Pistons" theory - not only will I get a bump from swapping cams from 1NZ-FXE to 1NZ-FE (stock 78hp to 108hp) ..but I should get a small boost from the 10:5 to 11:1 CR increase. I am sourcing a full 1NZ head now. |
^ Or CP pistons, or a couple of other brands. All available in whatever size/compression ratio you want. I wouldn't pay the premium just for the Arias name, but that's up to each customer; they do make great products.
I don't see any baffling in the large picture that xnamerx posted. The inside of the cutout intake manifold is shown in blue, right? Looks pretty smooth and open.
What's the purpose of a different manifold? off-topic. How difficult would it be to transplant my motor/trans into a Prius?
#9 | |
The 1NZ-FXE manifold was tuned for for a specific RPM range with most efficient MPG... I'm not concerned about MPG but more looking to increase HP. Most N/A motors w/o going ITBs have longer intake runners - not like the Prius's 1NZ-FXE manifold. Are you speaking of your 1NZ-FE? The Motor transplant shouldn't be difficult and was done by the Bonneville Landspeed Prius. They swapped the Otto Cycle 1NZ-FE from an Toyota Echo in but didn't do the Prius pistons swap. I'm looking to do both. Besides the MG1/MG2 and tranny the engine itself (mounting points) are exactly the same as the 1NZ-FXE Transmission transplant - hmm...depends on if you want to keep the hybrid system or not. |
#10 | |
0-60 in slow
I don't think the transmission bolts up to the 1nz-fxe, it would be far simpler to get an electric engine/generator and attach it to the crank snout like a supercharger to get some extra assist that way. That kinda the way honda currently does it with the CRZ/Insite
#11 | |
0-60 in slow
I can almost guarantee you, you'd be doing more harm then good by swapping to otto cycle cams in your engine. The prius is mainly powered by the electric engine, so to make that as efficient as possible the torque output on the gas engine needs remain a constant. The numbers I listed were WAG and so probably not accurate. Remember your gas engine isn't directly connected to the wheels, so its RPM's are also not a contant
Here is a website that explains how the HSD powersplit device works. Website Upping the power on the gas engine doesn't help as much as you'd think since only torque at certain rpms provides assist. Since the engine only revs to 5k you'll be throwing away all the constant torque of the fxe to gain the peak torque of the fe all with major loss and no benefits. You have to think of the gas engine as a electricity generator/backup power unit rather than a PU. You can rev the nuts off the Prius engine and the car won't move unless the electric motor is moving. |
#13 | ||
#14 |
![]() ![]() Drives: Gen 1 XB Join Date: Nov 2012
Now if someone just rips open a Prius and magically finds Carillo, Pauter, or even Molnar rods attached to these pistons. In that case, key up the Mission Impossible theme music as I put on the black spandex from my early spy days. Into the local junkyard all night long to harvest the jewels.....hey, this spandex used to fit.
![]() C'mon! I can dream!!!!!!
Why strive for a JDM BB, when you can promote the Scion badge? |
#15 |
justdidit, were you looking for a head?
#16 |
Technically still need one. Found a awesome deal on a 2012 1NZ-FE but I haven't heard back if they will ship it to me or if I need to drive up to the LA area to pick it up. Not so much ur neck of the 'woods' but more east LA. Either way I am still needing one.
#17 |
Don't know if it's in here, but this site sells Toyota OEM Prius pistons for $51 a piece:
http://www.trademotion.com/parts/200...mponent=PISTON
| 2010 Prius | tuckevalastin | Off-topic / Other Cars / Everything else Discussions | 60 | 01-13-2009 12:24 PM |
| Stupid prius | KSIbucky | Tracking, Racing, Auto-X Forum | 11 | 09-25-2007 11:07 PM |
| ZPIracing Turbo Pistons | ZPIracing | Forced Induction Forum | 22 | 05-29-2007 03:39 PM |
| And You Thought the Prius Was Expensive! | redyaris | Off-topic / Other Cars / Everything else Discussions | 5 | 05-18-2007 05:11 PM |
| Toyot Prius | YamilR | Photo-Video-Media Gallery | 4 | 02-14-2007 06:54 PM |
