Old 12-17-2008, 03:31 AM   #1
msfire671
ONE LOVE...YARiS LOVE!!!
msfire671's Avatar
Drives: Toyota Yaris
Send a message via MSN to msfire671 Send a message via Yahoo to msfire671
do these eyelids come off easily? meaning could someone just go up to your car and yank them off? if so then i think ill go with the vinyl..cheaper and i wouldnt have to worry about getting off work on day and its missing....damn vandals!
msfire671 is offline   Reply With Quote
Old 12-17-2008, 06:27 PM   #2
Treyz
~ ambient one ~
Treyz's Avatar
not really. But then again, I guess it also depends on what version you have. No one really steals these to begin with and most people who modify our cars are on here. I have v2 which still have a base to them. I believe it's v3 that have that part eliminated.
AMBIENTLIFESTYLE
Tri-State Sport Compact EZine
Micro Image
Store - Network - Online
Old 12-17-2008, 06:58 PM   #3
tk-421
tk-421's Avatar
Drives: 5D-07-LB
It is NOT easy to remove the eyelids, as long as you use the 3M tape that I recommend, which is designed to bond with the plastic parts of your car. Then again, if someone tries to pry them off, they may damage the eyelids, which means that at least that idiot won't be able to use them for anything.
The difference between v2 and v3 is essentially just the base, as Treyz correctly mentioned. The base may help a bit on this issue, but not really. The upside of not having the base is that the eyelids are much closer to an OEM look, and there's virtually no rubbing when opening/closing the hood.
So, in essence, the eyelids are as secure as any other "add-on" body part that is attached to your car (be it a spoiler, rocker panels, etc). Obviously those parts will be more secure if they are drilled/bolted in place as well as taped, which is something that cannot be accomplished with the eyelids.
Old 12-18-2008, 10:42 AM   #4
Treyz
~ ambient one ~
Treyz's Avatar
Once I got mine, I test fitted them over and over sanding down what ever was needed. Got the gap even on both sides so that there is no rubbing.
AMBIENTLIFESTYLE
Micro Image
Old 12-18-2008, 06:38 PM   #5
Herbicidal
Just a Herbicidal maniac.
Herbicidal's Avatar
Drives: 2008 Yaris S Sedan Flint Mica
Good tip. I"ll do the same, then paint.
2008 Toyota Yaris (Vios) 'S' sedan, Flint Mica, dropped on TRD springs, TRD anti-sway bar. Tinted rear windows. Lenso Samurai SC02 hyper black 17" x 7" rims, wrapped in 205x40x17 Federal ss595's. Color matched eyelids. Vios badge. Body color trunk trim (was chrome). Lamin-X tint on rear tails. Custom center exit exhaust. Tanabe front strut tower brace.
Herbicidal is offline   Reply With Quote
Old 12-18-2008, 08:06 PM   #6
tk-421
tk-421's Avatar
Drives: 5D-07-LB
Actually, you don't need to do that. You'll be getting v3's.
Old 12-17-2008, 11:07 PM   #7
YAR1S
YAR1S's Avatar
meh as soon as these start coming in colors... let me know and I will be sending money your way for sure.
Old 12-18-2008, 08:10 PM   #8
Treyz
~ ambient one ~
Treyz's Avatar
Yup .. what I did was for Version 2 and probably those that have version 1 could do the same if they wish.
AMBIENTLIFESTYLE
Micro Image
Old 12-18-2008, 08:16 PM   #9
Luna V 2.0
Drives: 2007 Yaris LB Blazing Blue
Send a message via AIM to Luna V 2.0
So if I get these I'll have to probably paint them. Does anyone by any chance know what the color "Blaze Blue" is known outside of Toyota? I don't want to mess up the color and have to repaint it.
Oh and how much would it cost to have these painted?
Edit: Sorry hadn't noticed someone went over price already. Either way, if anyone actually knows what Blazing Blue is known as to the rest of the world, it'll save me some guess work (and possibly some money). heh
Luna V 2.0 is offline   Reply With Quote
Old 12-18-2008, 08:46 PM   #10
tk-421
tk-421's Avatar
Drives: 5D-07-LB
Here are two good links that provide that information:
http://www.automotivetouchup.com/
http://www.toyotareference.com/#YA
Old 12-18-2008, 08:57 PM   #11
Yarisight
Yarisight's Avatar
Drives: 2008 Yaris LB "S" Blazing Blue
USDM Blazing Blue Metallic is 8T0. My local auto body shop had no problems matching my lids and hood dead on.
Yarisight is offline   Reply With Quote
Old 12-18-2008, 08:25 PM   #12
Treyz
~ ambient one ~
Treyz's Avatar
The color code for the paint should be on the door panel.
AMBIENTLIFESTYLE
Micro Image
Old 12-18-2008, 10:58 PM   #13
Treyz
~ ambient one ~
Treyz's Avatar
Only color anyone will have a real problem with is Bayou Blue. It's kind of a PITA to match.
AMBIENTLIFESTYLE
Micro Image
Old 12-20-2008, 10:57 PM   #14
msfire671
msfire671's Avatar
thanks for the info treyz and tk!
that'll be next on my list to go on my yaris!
Old 12-23-2008, 11:13 PM   #15
Herbicidal
Herbicidal's Avatar
Received my eyelids yesterday, thanks Garm! Just waiting for the paint. Looks like that will arrive sometime next week. I'm not sure how quickly I'll get to paint them. May need to wait for drier weather.
Question, those of you with them painted and installed, did you paint the underside too? Any advantage or disadvantage?
Old 12-23-2008, 11:49 PM   #16
Treyz
~ ambient one ~
Treyz's Avatar
Just follow the instructions on the can. I don;t know exactly where Roseville is in Cali, but if you are in southern Cali, should be no problem as long as the weather is over 50 degrees and there is low humidity. If not, then I would suggest indoors then.
AMBIENTLIFESTYLE
Micro Image
Old 12-24-2008, 11:08 PM   #17
Herbicidal
Herbicidal's Avatar
Thanks Treyz. I'm in northern CA, near Sacramento. Did you paint the underside of the eyelids too? It would almost seem that the rough unfinished surface of the eyelid next to the headlight would hold the doublesided sticky tape better then if it were painted.
Old 12-24-2008, 11:20 PM   #18
tk-421
tk-421's Avatar
Drives: 5D-07-LB
There is no need to paint the underside of the eyelids. The 3M tape will be able to stick to both painted or unpainted surfaces just the same, though.
Just make sure to paint the edges in order to make it look like it's painted all over.
OFFICIAL Yaris SEDAN thread SimmZ Photo-Video-Media Gallery 1706 06-22-2025 05:33 AM
I can't seem to find the thread with the pics of the '08 brochure, help? Jailbird General Yaris / Vitz Discussion 1 09-11-2007 08:40 PM
Sterio Pics Thread BlueFlash Off-topic / Other Cars / Everything else Discussions 0 06-08-2007 04:55 PM
