Drives: Vios 2014 Join Date: Feb 2015
hey guys i just registered. im from the philippines and got a 2014 vios which is sort of a sibling of the yaris. found this thread due to a squeak in shifting gears (manual). so anyway thanks to the thread starter my problem got a quick fix instead of lining up in the dealership. i used an ordinary oil lubricant with paintbrush and glazed the joints.
the cause of the squeak, as recalled, was by engine wash. some newbie overdid it using a pressure wash. so a tip out there for squeaking shift gears after an engine wash, the grease from the shift joints inside the engine bay must have absorbed some water and in the process pushed away some of the lunricants. hope this reply helps. super thanks to this thread! |
![]() ![]() Drives: Yaris Join Date: Feb 2013
Can this work in an automatic gearbox?
Is this engine-dependent?
My Yaris 2007 uses 2SZ-FE engine and I am not able to find this part in the engine compartment...
2ZR swap. DO IT! Ask how!
No, the auto gearbox does not have the clutch lever. Must be something else.
![]() ![]() Drives: 2015 yaris le Join Date: Feb 2015
What about the automatic? I get a squeaking sound shifting into d or taking off most times
could be a bad motor mount
squeak
Anybody figure out how to lube the inside of the Clutch release fork boot pivot point? blue arrow in this picture.
squeak noise no more
I just recently replaced my Clutch/pressure plate/throw-bearing ........and in fact i replaced the whole transmission gear box in my car. The squeak is coming from the fork pivot point and also the throw-bearing when it pushes the fingers of the pressure plate. Just put a little coating of grease on those parts and ........problem solved- NO MORE SQUEAK.
I just stuck a straw in there from a can of lithium grease and sprayed. I also sprayed it on all the shift linkages on top of the transmission. My squeak went away and has been for a couple months now.
FWIW I had a squeak when i'd depress the clutch pedal
ok
oh okay, I was skeptical about doing that cause you don't want to spray the clutch disc or something that'll cause more harm or start slipping. I was thinking if maybe I can get a camera probe in there to see what specific parts to lube or not.
I just made sure I didn't direct the straw directly in the direction of the clutch. Haven't had any issues since.
When I swap out my flywheel and clutch this summer i'll be adding a lot of grease to that area to ensure no sqeaking happens again.
Drives: 2007 Steel blue yaris sedan Join Date: Apr 2015
This is a definite fix!!! I've been looking everywhere for an answer and am so glad I stumbled upon this forum. So many useful guides!! Thank you again for the fix!
![]() Drives: Yaris NCP91R 1.5 Man 5d Hatch Join Date: Oct 2016
I had this little annoyance too (little squeak noise moving gears)
A couple of sprays of RP7 solved this for me, 2 1 second sprays once, leave 5 mins, then repeat with a 1 second spray on the area in the original posters pic, (thanks). Yay! My first post, Hi people nice to meet ya :) Last edited by yarisgc; 10-11-2016 at 12:13 AM. Reason: add greeting |
![]() Drives: 2010 hatch Join Date: Aug 2017
Wow!
I've got that ,too. I can't believe it's so common. I haven't gotten around to addressing it because i didn't know it could be so easily reached. Thanks!! |
Thanks!
I used some product called Zep S 2000 It's clingier/stickier than WD40. And shouldn't just wash off. The squeak is gone. since I only heard it shifting into 2nd gear, I was affraid it was coming from the tranny. |
![]() Drives: 2006 Yaris 2dr hb manual Join Date: Oct 2021
Everyone, please be very careful using lithium grease on the shifter linkages and bushings if your Yaris is older like mine. I have a 2006 2dr hatch with manual trans. I just had a linkage bushing failure on the highway and my car would only shift into 3rd gear. For the past year, I've been using lithium grease to keep the squeaking away as I was getting an annoying squeak shifting into 2nd gear after finding this thread. Last night while coming back into Toronto traffic from Ottawa, I downshifted and when I went to shift back into a higher gear, I could only get 3rd gear no matter what gear I tried to shift into. I limped the car home in 3rd gear (very annoying at stop/starts), thankfully have a new exedy clutch in the car cause I had to ride the clutch to get moving at red lights in 3rd gear. The lithium grease deteriorated the bushing to the point that it slipped off the lever and over the cotter pin that holds it on (I only used the lithium grease on this particular bushing as it was the one squeaking, the other bushings are fine and in tact). Lithium grease and really any oil based products will eat away at plastic/rubber materials, even higher end poly-eurethane bushings. Do not, I repeat, do not use this hack if you don't plan to replace the bushing anytime in the near future or if you plan to keep the car for longer than a year without replacing the bushing. If I didn't fix it myself this morning and/or have a trustworthy mechanic, this is something that could land you a hefty repair bill cause I thought my transmission died on me and sleezy mechanics will try to make you pay for unnecessary repairs. I almost scrapped my car over this so beware that using this hack will ultimately lead to worse problems in the future if you keep your car long enough afterwards.
| Urgent! How to use auto transmission? | hans_fh | General Yaris / Vitz Discussion | 55 | 04-16-2010 01:45 PM |
| 2009 Yaris "S" - no 5MT Hatchback? | Latka | New YARIS Purchase Forum | 21 | 11-07-2008 04:16 PM |
| New transmission at 8.5K miles! | d2dailly | DIY / Maintenance / Service | 17 | 09-22-2007 11:41 AM |
| Want opinions automatic vs. manual transmission | anik | New YARIS Purchase Forum | 84 | 07-10-2007 04:25 PM |
| Synthetic oil for transmission | mrrock | DIY / Maintenance / Service | 7 | 04-26-2007 03:51 PM |
