Old 12-05-2006, 11:53 AM   #1
Violin
Violin's Avatar
Drives: 2007 Yaris LB Auto
Just flipped on to the parking light position. I wonder if you guys could get away with them as DRL's - they are pretty bright. If you wired them up so they came on with the ignition switch, you could remove the DRL module.
Old 12-05-2006, 08:41 PM   #2
Chris07LB
Chris07LB's Avatar
Drives: Yaris Liftback
Glad you like 'em V.
Old 12-06-2006, 07:28 AM   #3
Violin
Violin's Avatar
They also look better than the PIAAs. The Piaas have two side-by-side LEDs:
These don't look like two points but are more diffuse.
Old 12-28-2006, 12:08 AM   #4
Blenjar
Blenjar's Avatar
Drives: Black Yaris 07 HB
Sorry for been a nub..what a parking light? the orange?
-- Blen
Old 12-28-2006, 06:24 AM   #5
vodkalush
I drive a yarrrris
vodkalush's Avatar
Drives: 07 Sedan Polar White
Send a message via AIM to vodkalush
-- Blen
the white light in the middle of the headlight (pics 5 post up)
Docotrs say all the drikning has mesesd up my seplilng and radieng
will work for parts
vodkalush is offline   Reply With Quote
Old 12-28-2006, 06:42 AM   #6
Chris07LB
Chris07LB's Avatar
-- Blen
The original post shows exactly where and what it is.
Old 12-28-2006, 08:42 PM   #7
Blenjar
Blenjar's Avatar
1- Is that the DLR too?
2- Can you have baby blue color? (at momenti t looks white but its blue) but want it to be as bright as the stock one..catch my drift?
-- Blen
Old 12-29-2006, 06:19 AM   #8
Chris07LB
Chris07LB's Avatar
DRL is part of your H4 high/low, has nothing to do with this parking light, nor is it a seperate light all its own.
Original post shows the product packaging, and the avaliable colors listed.
Old 04-07-2007, 11:23 PM   #9
IsLNdbOi
IsLNdbOi's Avatar
I just got two 194s from HiLEDs for my parking lights. Do we really have to remove the front bumper to install these?
Old 04-08-2007, 12:47 AM   #10
brickhardmeat
Lonesome Cowboy
brickhardmeat's Avatar
Drives: 2007 WHITE HATCHBACK
huh???
NO
SPONSORED BY
Old 04-08-2007, 06:37 AM   #11
Chris07LB
Chris07LB's Avatar
Why in the world would you think that????
Open your owners manual, it even shows there.
Pop your hood, and you will see the bulb socket right there.. twist it, and replace.
Old 04-08-2007, 02:13 PM   #12
IsLNdbOi
IsLNdbOi's Avatar
See post #51 and then #56.
Old 04-08-2007, 03:03 PM   #13
Chris07LB
Chris07LB's Avatar
Sometimes all it takes is a little motivation to look for yourself.. see how simple it was, after poping the hood and looking?
Glad you got them in.. night and day difference huh?
Old 04-08-2007, 12:51 AM   #14
IsLNdbOi
IsLNdbOi's Avatar
How do you install them then?
I have the Yaris Service Manual that someone posted up some time ago and the instructions in it for getting to the parking lights say to remove the front bumper.
Old 04-08-2007, 12:54 AM   #15
brickhardmeat
Lonesome Cowboy
Open your hood, twist and pull, then pull the old wedge out and pop the new one in, you may have to turn the new one if it does not light up (polarity), if you go out to your car and pop the hood and take a look I think it will become rather obvious, this is a 2 minute install
changing the actual h-4 bulbs is a pain for me and some prefer to remove the whole assembly for that but for these it is totally easy
SPONSORED BY
Old 04-08-2007, 12:59 AM   #16
brickhardmeat
Lonesome Cowboy
by the way the repair manual shows pictures and explains how to change every bulb in/on the car
http://www.etimago.com/yaris/repairmanual/
SPONSORED BY
Old 04-08-2007, 01:04 AM   #17
IsLNdbOi
IsLNdbOi's Avatar
That's the same manual I have. It says you have to take the front bumper off to get to the parking lights.
page LI-97 says:
REMOVAL
HINT:
• Use the same procedure for both the RH and LH sides.
• The procedure described below is for the LH side.
1. DISCONNECT CABLE FROM NEGATIVE BATTERY TERMINAL
2. REMOVE FRONT BUMPER COVER (See page ET-24)
3. REMOVE HEADLIGHT ASSEMBLY
(a) Remove the 3 screws.
(b) Disconnect the 3 connectors, then remove the headlight.
Old 04-08-2007, 01:08 AM   #18
brickhardmeat
Lonesome Cowboy
No you don't, not at all, you also don't have to disconnect the freaking battery. Do me a favor and go out to your car and change your damn bulbs. These are about as easy as it gets. Sometimes the manual gets a little carried away. I guess if you were a Toyota Tech and you did all that you could charge someone an hour for a 2 minute bulb change.
SPONSORED BY
Led taillight bulbs casterqc Cosmetic Modifications (Exterior/Interior) 27 09-15-2007 01:48 AM
