Thanx as well, works great!
One problem I encountered was using the tap-splice connectors I didn't get all the way through the wire insulation the first time. Had to strip a small spot of the insulation from the wires to get a connection. The darn wires are so tiny.
'08 3dr HB, Black Sand, AEM, 16x6.6 Mini-Cooper wheels, DynoMax, Cruise, de-TPMS'ed. |
My Box and Her Egg
Drives: 05' Scion xB / 08' Yaris 3dr Join Date: Sep 2006
I just put a piece of black tape over the light when I changed the rims. Didn't feel like cutting wires.
![]() ![]() ![]() ![]() ![]() Drives: Toyota Yaris Sedan 09 STD Join Date: May 2009
CT Scott, is this this the way it's done in an easy to understand pic?
Never take eyes off opponent - Bruce Lee |
Yes.
OK then.
SO, this method does NOT require the the light to be off pre procedure OR that the wheels/sensors to be mounted on or near the car before starting, right? Even if you start out with the light on, it does'nt matter this way. Is this all true? Thanks!
#7 | |
The TPWS is completely independent of all other systems on the car. It actually uses legacy ISO-9141 comm, rather than CAN bus, so the ECM doesn't even have the ability to talk to it.
![]() Drives: 10 yaris Join Date: Mar 2011
CTScott,
Just wanted to say THANK YOU! This is the first thing I did when I bought my new Yaris a few months back. Sure beats taking the inst cluster out and covering the led for the light! so THANKS AGAIN! Kevin |
#9 | |
![]() Drives: as if running for his life. Join Date: Mar 2010
Also, is there any identifier such as a part number on the TPWS ECU? I'm really excited to try this! |
#10 | |
mmm I should get this done! too much time playing with sound system!
D.
. CLA 250, 4MATIC |
Drives: yaris Join Date: Jan 2011
info
I did this mod by opening up the tmps module, pulling the pcb, soldering in 3 wires, cutting one, and using a switch screwed into the face, as in the pics a few posts earlier ---- One note: you can easily pull the tpms pcb by using a small flat blade screwdriver on the small plastic tabs on the gray tpms cover.... there is no need for any tools other than that. the tpms cover pops right off and the pcb slides right out. super easy. Last edited by A-Dingo-Ate-My-Baby; 08-16-2011 at 02:00 PM. |
![]() Drives: 2011 Yaris S 3dr Bayou Blue Join Date: Sep 2011
Thank you, Scott! Did the no switch option mod tonight; bye-bye light that irritated me all weekend driving through VA
#14 |
![]() Drives: White Hatch Join Date: Oct 2008
Thank you for this DIY.
#15 |
![]() Drives: 2008 2 door hatchback Join Date: Aug 2011
Thank you Scott!!!
#16 |
I just did this in about ten minutes. You don't need remove the whole black box, remove the connector plug with the wires in it and then carefully pry the clips up on the cover surrounding the connector and remove it. After that the board slides straight out. I just cut one pin lead and soldered it to the one next to it as pictured above. Lights out now! I've been living with that for over four years......
PS It appears the top of the green PC board is conformal coated to protect against moisture and dust. It looks like it's UR vs. the Humiseal acrylic and it's handbrushed on..
Never take eyes off opponent - Bruce Lee Last edited by auxmike; 04-14-2012 at 01:26 PM. |
#17 |
![]() ![]() Drives: 2010 Liftback Join Date: Sep 2012
Hey, not to hijack such a useful thread but I did want to tell you guys that Costco will reprogram sensors for nothing, according to the tires manager with whom I spoke today. Walmart will do it for $20 for the whole vehicle: http://www.walmart.com/cp/Tires-Services/495845. The dealership charges much, much more, as CTScott mentioned in his original post. Just wanted to throw this out there if anyone is disabling because they swap tires seasonally and considered the price of programming prohibitively expensive.
#18 |
![]() ![]() Drives: '09 Yaris Sedan Join Date: Oct 2009
This thread is all about not having the annoying light on the dash when you don't have wheels with the sensors on your car. They are a needless joke to begin with.
| Tire pressure sensors | Tink1 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 11 | 10-21-2008 05:53 PM |
| Intake Systems Decision Maker.. | Blenjar | Performance Modifications | 25 | 09-15-2007 10:07 PM |
| The Tire inflation debate... | Tankota | General Yaris / Vitz Discussion | 20 | 06-01-2006 07:09 PM |
