Old 03-13-2012, 01:07 AM   #1
yaris4062007
Drives: 07 BB yaris / 06 Mustang Gt
2007 blue yaris hatchback
automatic
83k miles on it...
40k miles tires replaced, 59k miles water pump and serptine belt replaced by warranty.
wipers replaced at ?? k miles.
average 31-32mpg full tank.
yaris4062007 is offline   Reply With Quote
Old 03-13-2012, 07:28 AM   #2
Qmobile
that's right I went there
Qmobile's Avatar
Drives: '08 Blazin' Blue,'10 Dark Red
Just hit 95k yesturday
Mods: 15" SSC rims, TRD Exhaust, TRD Sway bar, TRD oil filler, TRD rad. cap, TYC tails, Debadged, Painted engine cover, Stock spoiler, Stock mud gaurds, OBX pedals.
suggestions always welcome
Qmobile is offline   Reply With Quote
Old 03-13-2012, 11:12 AM   #3
enviri
enviri's Avatar
Drives: 2010 Yaris
2010 5dr
39k mi
tires replaced twice due to nails on road
replaced control arm bolt from TSB
Dead battery replaced with junkyard yaris battery (FREEBIE!)
Front caliper leaked fluid a bit, my fault for not tightening during bleed after putting in OEM BBK
avg 29-33 mpg
Old 03-13-2012, 02:07 PM   #4
Cutie Pie #2
Drives: 2014 Honda CR-V LX
2008 yaris
Blazing blue
60,000
Running good, still getting around 35 mpg.
Problems: None other then a hood rattle that no one seems to be able to fix tried about ten places. I've just learned to live with it.
Done all required services, been pleased with car so far!
Cutie Pie #2 is offline   Reply With Quote
Old 03-13-2012, 04:50 PM   #5
Perpetuous_Dreamer
Drives: Yaris 2007
2007
Hatchback
Grey
78000
No problem so far, only routine maintenance (oil, transmission fluid and coolant change). Not even brake pads or tires. Once battery died about three years ago due to my fault but steel functions like new)
Perpetuous_Dreamer is offline   Reply With Quote
Old 03-24-2012, 09:58 AM   #6
yarista
Drives: 07 Yaris 3dr, 09 Yaris 4dr
2007 Hatchback
81k
No problems so far
2009 Sedan
37k
No problems so far
yarista is offline   Reply With Quote
Old 03-29-2012, 08:56 AM   #7
pj. olsson
Drives: Toyota Yaris TS 5 Door
2007 Yaris TS
89000 KM
One Problem with ABS Sensor, not terrible! :-P:-P:-P
pj. olsson is offline   Reply With Quote
Old 03-29-2012, 10:00 AM   #8
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
just hit 80k and sometime in the last 10k miles and that flap that is mentioned in some TSB in the neck to the fuel tank went bad so I am throwing a CEL for it.
Old 04-04-2012, 12:04 PM   #9
jerome
Toyota
Drives: '11 5dr/5spd yaris
Checking in for March and April:
March 1: 3,638
April 1: 3,727
On April first I finally filled my tank after not filling it up since December 26th!
So after 43 weeks of ownership, I've averaged out to: 87 miles/wk
Planning on at least a short road trip this month!
jerome is offline   Reply With Quote
Old 04-07-2012, 10:44 AM   #10
Hershey
Someone we know has a little over 100,000 miles on their 2010 3 door . Used for their business . Very few problems . Has only replaced air filter twice that I'm aware of . I cleaned the original and later gave him a used air filter from our Yaris that was in better condition . Imagine it's still in use . Have to check it again . Gets oil changes every 4 > 5,000 miles at Toyota service center , so likely to be conventional .
Old 04-07-2012, 10:50 AM   #11
Twistoffate0817
My Little Blue Egg :)
Twistoffate0817's Avatar
Drives: '09 3 door Yaris
2009 hatchback
23,000 miles on it.
Replaced waterpump at 21,000 miles.
Twistoffate0817 is offline   Reply With Quote
Old 04-07-2012, 01:53 PM   #12
Kal-El
Kal-El's Avatar
Took this a couple weeks ago.
Old 04-09-2012, 11:13 AM   #13
clubcrasher71
Drives: Toyota Yaris 2010
2010 White
40500 miles
still running with OEM tires. wondering when to change, I guess when tires have no threads left. LOL.
clubcrasher71 is offline   Reply With Quote
Old 04-09-2012, 11:39 AM   #14
33OH
Drives: '08 Yaris
^ Welcome!
And you change tires when the tread is even with the tread depth indicators on the tires.
Old 04-09-2012, 03:49 PM   #15
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
i'd change out the oem tires as soon as you feel comfortable spending the cash. They're terrible.
Colin Chapman disciple
Old 04-09-2012, 10:58 PM   #16
Hershey
Got that right . The Continental Pro Contact w/ Eco Plus made a big improvement in the ride , handling ( especially ran soaked roads ) , and noise level inside . Gas mileage remains about the same as with the Potenza RE 92s . Keep tires at 35 > 37 p.s.i..
Old 04-10-2012, 10:11 AM   #17
746watts
Drives: 2014 yaris hybrid
Year: 2008
Model: 1.4 D4D
Odometer: 201900 kms
Problem: Rear left wheel bearing starting to hum, no play on wheel when jacked up but spinning the wheel by hand reveals the unhappy bearing noise. It's an ABS model, sealed unit (what muppet designed this?). Have to price a replacement today from Toyota dealer, got a price from autoparts (generic) of €140 or so.
746watts is offline   Reply With Quote
Old 04-12-2012, 03:40 AM   #18
carolinablue
Drives: 2012
Yesterday I drove about 40 miles: 30 percent country roads at 55 and 70 percent on 4 lane highway at just under 60. Before I left home I reset my factory fuel gauge. I drove with an extremely light foot. I was pleasantly astounded when I checked my MPG gauge just before I exited the highway to discover that it had recorded 46 MPG.
carolinablue is offline   Reply With Quote
excessive sulfur odor on 2007 model year Yaris tomjasz General Yaris / Vitz Discussion 121 03-13-2010 06:49 PM
TSB's WD-40 General Yaris / Vitz Discussion 27 06-06-2007 01:11 AM
