Old 01-14-2011, 04:30 PM   #1
Carrot Top
Carrot Top's Avatar
Drives: 2008 Copper Orange LE HB
[QUOTE='LilRedYaris;547620] He sincerely apologized to me and I paid up and left. Disappointed. $220.35 total out of my pocket. Some of you may know that I bought this car Certified Used last May. My first Toyota, and first newish/modern car. Love it's driveability, reliability, and ease of use. Didn't like this situation too much though. Well, it can only get better, right? I live in a winter wonderland...
So you got it fixed for $220.35?! I was told it is $700.00...thank God I got the extended warranty or I wouldn't get it fix. It is VERY disappointing to have that kind of repair...
The YARIS is the REAL Smart car !
Carrot Top is offline   Reply With Quote
Old 01-14-2011, 01:12 AM   #2
beZzZ
Learning & Upgrading
beZzZ's Avatar
Drives: 2006 Yaris 5 Dr HB Black
Both my abs and battery warning light were on whenever it's raining, it was before I changed my 06 alternator to a used 09 one. And since then, luckily, both of them are never on again. Even now it's snowing almost everyday here.
Just wondering would it be the alternator causing the real problem.
beZzZ is offline   Reply With Quote
Old 01-17-2011, 01:35 PM   #3
devinlamothe
devinlamothe's Avatar
Drives: '07 Yaris HB
That's not the same problem. Our problem is the ABS and parking brake light on, not the battery.
devinlamothe is offline   Reply With Quote
Old 01-22-2011, 10:49 AM   #4
blueswan
Drives: 2007 Yaris
Thanks da1nonly:
I'm going back to the dealership and will ask if each part of the three-part system (wiring, sensor and hub) was examined to find out which part is faulty or if they just plugged into the comp and got the error code: I don't mind paying for necessary repairs but I'm p.o'd with the idea of paying for the whole sensor system unnecessarily.
Can I demand to see the TSB at the dealership? Can I instruct them to do the repairs per the TSB, unless they can prove to me that the whole system needs to be replaced?
Don't laugh, but is there a possibility of getting this done at Canadian Tire? I've gone there for my regular maintenance because they're more woman- friendly than my rather macho dealership. I've had reliable service from my local C.T and I research things very carefully when I take my car in - they've never tried to oversell or con me into doing more than I need and answer my questions fully and in layman's terms. They also stand behind their work as I've already had occasion to find out.
Cheers and thanks for your help.
(edited to add - a scan of the TSB would be great!)
blueswan is offline   Reply With Quote
Old 01-22-2011, 04:19 PM   #5
Dave
Drives: 2007 Yaris Sedan
If you're comfortable poking around under the car, cleaning the crap out of the sensor can help too. Or you could take it to a garage you trust and ask a mechanic to clean the sensor for you. It may be worth a try to save all the money.
I cleaned mine at the end of December and I haven't seen the lights on since (knock on wood).
Dave is offline   Reply With Quote
Old 01-22-2011, 04:21 PM   #6
yaris2010RS
yaris2010RS's Avatar
just to clarify, is the problem with the sensor itself or is it the connector?
Old 01-22-2011, 04:35 PM   #7
Dave
I thought the problem was that a gap in the weather seal around the connector would allow the salt spray from the road to get into the spot where the wire harness connects to the hub. This impedes the electrical signals and causes the warning lights/ABS failure. That's why cleaning the gunk out and then protecting the gap with dielectric grease can help, if the salt hasn't already corroded any of the actual parts.
Anyone please correct me if I'm wrong.
Old 01-26-2011, 08:04 AM   #8
bcolwill
Drives: 2007 Yaris 4DR Hatchback
Possible Resolution
I have a 2007 Yaris which I purchased from my mother-in-law in December 2009 with only 3500 KM on it. Not long after I had the same problem as many here. Brake lights on and disabled ABS when driving in salt & slush. I was able to obtain the code pointing to a rear speed sensor. This past summer I purchased some dielectric grease at CDN Tire, removed the connectors at the rear wheels, filled the stationary end full of the grease and plugged them back in. Since I have done that I have yet to see the problem appear again.
bcolwill is offline   Reply With Quote
Old 02-01-2011, 07:17 PM   #9
shorenetworks
Drives: 2008 Scion Xb
This is Chris checking in from scionlife.com with a 2008 Scion Xb at 109K miles
Was having the same issue as described + TRAC and VSC.
Pulled the connectors of of the rear hubs cleaned and covered in dielectric grease problem solved!!!!
Also on the passengers side connector there was clear signs of corrosion.
Looks like Toyota shared the same parts bin for us.
And I will be filing a complainant with the http://www.nhtsa.gov/
as this is clearly a safety issue and I do believe that I am done buying Toyota!!!!
I will be posting this thread up on scionlife due to the fact that plenty of people just started having the same issue.
Thank you to all who have contributed to this as it has save me at least $800.00 USD
shorenetworks is offline   Reply With Quote
Old 02-01-2011, 11:22 PM   #10
spann1
Drives: 2007 yaris sedan
2007 YARIS ABS FIX
My 2007 Yaris has 41,000km (my kids drive it between University and Home) and I have had zero problems with this vehicle up until last week when I brought it in for the twice yearly oil change.The very next day the ABS light came on!
I googled and found this site and after reading all the Yaris ABS issues with sensors I went back to my local Toyota dealer and had the car hooked to the computer for $59.88+ tax, and Toyota reported the following:
cause: retrieved codes C0210 and C0215 speed sensor malfunctions.
correction: requires both rear speed sensors. $827.00 + tax.
I told the service advisor, I should not be responsible to pay this amount for a known technical fault especially since there is a Toyota Technical Service Bulletin from June 27th 2008 and secondly was not very happy that as a Yaris Owner was not even advised that there was a problem with the ABS sensors.
The Service Advisor agreed to contact Toyota Canada for a possible "Good Will Jesture" on the repair costs.
Toyota Canada agreed to pay 60% of estimated costs, my local Toyota dealer said since I serviced the vehicle always at the dealer, the low mileage & age of vehicle, they would also kick in 20% so I am left paying 20% for the fix.
Not exactly satisfied that this is free but I am happy to have this resolved
for $165.40 versus $827.00!
The car is being repaired in next few days.
Thanks to all the Yaris owners who made this information known.
Other than the ABS sensor this is a very reliable car, the best I have ever owned.
P.S. The car will still brake without the ABS just will not have the ABS function, some owners I read would not drive the car until fixed, I found that really funny.
spann1 is offline   Reply With Quote
Old 02-03-2011, 11:26 AM   #11
bqsantos
Drives: Toyota Yaris 2007
First attempt at DIY fix
Hello:
Just before snowmaggedon here in T.O. I tried the DIY fix as recommended in the thread.
I removed the tire to get to the connector, but I could not get the cover off. I'm not sure if I had my screw driver in the proper spot to remove the cover.
Does anyone have any pics/video of what things will look like after you get the cover off. Trying to figure out how the cover opens.
Any help would be appreciated.
Thanks...
bqsantos is offline   Reply With Quote
Old 02-07-2011, 10:06 PM   #12
dwrf6
Drives: 2007 Yaris hatchback
Wow, glad to find this board.
I've got a 2007 Yaris 32 000km.
I had the brakes fixed in '09, dealer in Toronto covered it, with a list of clever question for me.
Had 14 000km at the time.
Year later, same issue, insufficient use of the vehicle caused the brakes to need repair again.
Full kit, pads, rotors(rusted and pitted too bad) and whatever else. 20 000km
I had to pay this time $750.
Well a good morning to me, started the car to the two board lights show up.
Not on when parked day prior.
"ABS" and "EMERG Brake", I personally prefer no ABS, obviously not working now.
Thanks for the info SPANN1 on the dealer visit.
What's my options? Can I use it without causing anymore issues?
Will the dealer find out that I disregarded the issue and then try to turn it on me.
Is this still covered under warranty?
Thanks
dwrf6 is offline   Reply With Quote
Old 02-08-2011, 05:26 PM   #13
005
Drives: 07 Yaris
Hi ,
I got the same problem with my 07 Yaris. It happened to me last year and this year again. I am expecting to see this problem every winter. First Canadian insurance company is not covered because tech found the water in harness. Yes you will. I am driving in the snow.
Yaris is not good for snowy drive. Toyota shouldn't sell the yaris in some province in Canada. AB, SK, MB, OT and QC.
If they want to, they should make it water proof or something for sensor and harness.
I believe Toyota Canada should take responsibility for this. We Canadians are less protected by Consumer Law. We don't have Lemon law and we never complaint like Lexus in states.
I will see what I can do about it. I will spread this message through all of my social network, face book, tweeter and so on. My trust on Toyota is eventually going down.
Mr. Toyota your name is on my car you should be taking care of this.
From Canada
005 is offline   Reply With Quote
Old 02-09-2011, 10:24 AM   #14
N9QGS
N9QGS's Avatar
Send a message via AIM to N9QGS Send a message via Yahoo to N9QGS
I started having this problem for the first time this winter at 160K mi. and I appreciate the forum here to allow me to get it looked at, I am hoping its just limited to the harness and not both, but I am having an independent shop look at it right now for free, they said they would have to get the parts from toyota and there would probably be no difference in cost. But they will see if its anything they can clean up and put a temp fix in the meantime. I have a sedan 2007
198K Miles
N9QGS is offline   Reply With Quote
Old 02-09-2011, 10:38 AM   #15
devinlamothe
lol, I've been driving with the lights on for over a year now ... I can't for the life of me notice a difference with ABS on or off.
I just hope this isn't an insurance issue - when I have time this summer I will take the tires off and clean the sensors, but no way am I paying $800+ to get them fixed at the dealer.
Old 02-15-2011, 09:37 PM   #16
Gman
Drives: 2008 yaris
Reading all these post all the way from 2008 has made me sick to my stomach, especially since there has been no recall after all this time. I also have the same problem, with the warning lights going on and off all winter. I can be driving and they will go on, and then 15min later as I continue to drive they go off. Two times this winter, I have also experienced my Yaris not slowing down at all when breaking on snow, even though it sounded like the abs was working, and both times I came extremely close to smashing into the car in front of me. This has lead me to not trust my brakes at all in slippery conditions.
I am hoping it will get warm enough this week-end so I can try the cleaning idea. Thanks to all who have posted in this thread with advice.
Gman is offline   Reply With Quote
Old 02-15-2011, 10:11 PM   #17
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
Sorry, but this problem with the wheel speed sensors will have no effect on you brakes not working. So if you're that concerned about the safety of your vehicle, why haven't you taken it to the dealer?
Old 12-29-2012, 08:44 PM   #18
falconati
Drives: 2007 Yaris Hatchback
I'm having the exact, EXACT problem as others. So frustrating. I have not yet tried any remedies; however I'm frustrated that this is such a widely known issue....yet no official fix from Toyota. Having folks fix this at cost is awful. It's a safety issue, not a maintenance issue.
I'm hoping Toyota will do the right thing here, otherwise it'll be harder to look at another Toyota model down the road.
If you're a US resident, please submit a formal complaint to the NHTSA - it only takes 3 minutes of your time and could help us all get a formal, free fix from Toyota: https://www-odi.nhtsa.dot.gov/ivoq/
falconati is offline   Reply With Quote
