Old 12-18-2008, 02:22 AM   #1
Lafiro
Drives: 06 Yaris Sedan
Ok, so I will be buying oil in a few hours when I wake up.
But as for Wix and other oil filters, I see two or three part numbers.
Can someone please tell me a few "good/excellent" oil filters for use with probably royal purple on my yaris sedan with the part number next to it.
This way I can buy it and change the oil myself at my friends shop.
Then I will reset the maint Req light and end that for the next few thousand miles.
Thank you everyone.
Old 12-18-2008, 04:48 PM   #2
1stToyota
1stToyota's Avatar
Thank you everyone.
Napa Gold/WIX are really good. PNs are: 1394 for the Napa Gold, 51394 for the WIX
Another good choice, for less money (found @ Napa) Nippon filter. PN: 3612412
1997 Lincoln Town Car - SOLD
2008 Scion xD
(w/ automatic) - SOLD
2008 Yaris HB - SOLD
Old 12-18-2008, 04:57 PM   #3
1stToyota
1stToyota's Avatar
I think we can calm down now, Gid hasn't used 5w-20 for quite some time now. Besides, Toyota's own TSB mentioned its "superiority in terms of fuel economy" ...so maybe fuel economy is improved, but Gid didn't like the extra engine noise and went back to using 5w-30
2008 Scion xD
Old 12-18-2008, 04:42 PM   #4
mikenacarato
SIPNDEW
mikenacarato's Avatar
Drives: 15 STI
chup...he may see a .01 mpg variance... :)
mikenacarato is offline   Reply With Quote
Old 12-19-2008, 01:19 AM   #5
Lafiro
Ok I did the following:
4quarts of Royal Purple 5w30
K&N Oil Filter
I must say, I do feel a slight difference in performance, and smoothness of the engine now.
Im happy.
Old 12-19-2008, 11:42 AM   #6
auxmike
auxmike's Avatar
I'm stickin' with the Toyota OEM filters. Bought a case.
I use whatever synth is on sale at PepBoys.
'nuff said.....
Old 12-30-2008, 01:02 PM   #7
TheSilkySmooth
TheSilkySmooth's Avatar
Drives: 08 3DR 5M Bayou Blue; 09 Fos
My problem with "synthetic oil " in the u.S, it is a marketing term ONLY now and people are paying a lot of extra dough for a "false" product that does not even come close to full synthetic oils Like EUropean ELF (total brand) excellium, Fuchs and Motul E-tech and 300V. Americans have been lulled and fooled into incompetence and Ignorance on the subject and brainwashed by marketing. Fools you all! Almost ALL synthetic you buy in N.A is "fake". Only maybe Mobil 1 EP of various weights + 0W-40 euro formula; then the 0w-30 cult status (not earned) "gold" castrol DE and 0W40 castrol euro formula made in DE. is the real thing. We can ONLY guess since marketing allowances for refined petro oil to be called "synthetic" and the Brands tight lipped about constituents and I.P. Again , the Deutsch makken produit, not Estates Uni creativ, may afford you a real synthetic if you do not wish to scrounge the "gray-market" imports. These Yamaha designed, high specific output engines deserve or even REQUIRE high performance oil. They run HOT and will end up full of varnish with poor performance in under 10K if yo do not run the 'good stuff".
TheSilkySmooth is offline   Reply With Quote
Old 12-30-2008, 01:47 PM   #8
Chupacabra
Drives: 2009 Yaris liftback
So I guess my question to you is....is Mobil 1 Fully Synthetic motor oil not what they say it is? In other words, is it not fully synthetic motor oil?
Chupacabra is offline   Reply With Quote
Old 12-30-2008, 04:25 PM   #9
TheSilkySmooth
What is your understanding of a "fully synthetic" motor oil? What is a synthetic motor oil? Are there differing types of Synthetic lubricant molecules, and, which ones are better suited for which purposes? I would spend some time researching this. Most ALL people are ignorant on this subject and DON'T get your info off a forum.
Old 12-30-2008, 07:50 PM   #10
auxmike
auxmike's Avatar
Exactly.
That's why I'm taking everything you said with a "grain of salt"....
Old 12-30-2008, 02:04 PM   #11
gid
Drives: '08 Yaris sedan , '08 Liftback
not a " TRUE SYNTHETIC " like that of AMSOIL , REDLINE , etc..
gid is offline   Reply With Quote
Old 11-19-2009, 09:04 AM   #12
suiller
Drives: Yaris Sol 1.3 dual VVTi 101hp
sorry to bore again... but someone can drive me to a good site/ebay where to buy Amsoil oils? seems almost impossible to "export" a bottle of amsoil outside US. thx
Yaris Sol 1.33 dual VVTi model 09 - 5dr
1. full ZX1 additive treatment: oil + cooler + fuel
2. NB treatment: motor oil
3. K&N panel air filter (part num. 33-2211)
4. Fuchs Silkolene Pro SRG 75 gear oil (the best!)
5. UltraRacing 19mm rear sway bar
suiller is offline   Reply With Quote
Old 11-19-2009, 05:33 PM   #13
Lazerdot
Lazerdot's Avatar
Drives: Blazing Blue 08 liftback
My understanding is that if as little as 10% of the oil is "sysnthetic" it can be called synthetic.
Obviously, as an Amsoil Dealer, I'd like you to consider using Amsoil. We have a Synthetic 0w-30 that can be used for 17,500 miles(or one year) miles under severe conditions. Our Synthetic 5w-30 is good for 15,000 miles(or one year) under severe conditions. Many other oils are good for OEM only drain intervals under these conditions. Check the fine print on the other labels.
Amsoil can save you time, money and create less waste oil due to oil changes and it burns off at a lower rate then other oils.
Check out my dealer page at TruLube.com. for more information
One Year One Oil-AMSOIL at www.Trulube.com TRD Exhaust, Springs and Struts. TRD SSK. NST Underdrive Crank Pulley. Amsoil Dominator 10w-30 Racing Oil, Amsoil DOT4 brake fluid, Amsoil Severe Gear 75w-90 transmission oil, Ultra Racing 23mm Sway Bar, Camber Bolts, R1 Drilled Slotted front Brakes and SS Brake cables from Micro-Image. Orange Konig Daylight 17s, Kumo MXs. Greg@TruLube.com
Lazerdot is offline   Reply With Quote
Old 11-19-2009, 05:55 PM   #14
TheSilkySmooth
No it can be 0% synthetic and be called synthetic due to NAB ruling of Mobil v. BP ( Castrol) in the late 1990's. The Synthetic Amsoils are real synthetic, and the SSO is super special.
Old 11-22-2009, 10:44 AM   #15
Yaris_Fan
Yaris_Fan's Avatar
Drives: Liftback Auto
lol! @ anyone thinking the Yaris engine won't last 200k miles doing 5k OCI's on any modern oil that meets specs
my advice would be to use what's on sale
Yaris_Fan is offline   Reply With Quote
Old 11-24-2009, 11:26 AM   #16
TheSilkySmooth
The yaras 1NZ engine can be hard on the oil due to the inverted bucket tappets and the cam chain drive. Luckily the valve spring pressure is really light - IIRC about 40LBS closed - but you can still get galling of the lobe due to high ramp rates and mass acceleration at high rpm. The problem with PAO based synthetc is its not a good lubricant. That includes most amsoil and Mobil 1 (at least the M1 with majority PAO base), DIesters POE and AN synthetics have much a better inherent lubricity and polarity that PAO based syns lack. Source Motul and Fuchs silkolene for the "best" synthetic oils.
Old 11-24-2009, 11:32 AM   #17
Indianspringsaz
Drives: 07 Bitchin Blue HB
First I have heard of this. Would you post some references? I am interested in oils, and always learning something.
07 Yaris HB
07 Road King
06 Superduty CC
05 Scion TC
01 30' Sleekcraft HP500EFI
Your Local Amsoil Dealer
Indianspringsaz is offline   Reply With Quote
Old 11-25-2009, 12:23 PM   #18
Henry G.
Drives: 2008 Yaris HB
I agree ester synthetics are superior, but I dont think its fair to says PAO synthetics aren't good lubricants. They are. Oil has come a long way in the last 20 or so years.....
Henry G. is offline   Reply With Quote
NEW PRODUCT! SIMOTA DROP-IN REPLACEMENT FILTERS kargoboy YarisUniverse 10 01-21-2009 08:48 AM
Drop in performance air filters which is best? YarisSedan Performance Modifications 14 11-07-2008 09:52 PM
SRI or CAI YogiYaris Performance Modifications 21 05-03-2007 11:28 PM
DIY Oil Change Bassmonkey DIY / Maintenance / Service 42 02-19-2007 08:37 PM
Darn Workplace Internet Filters...! Yaris Revenge Off-topic / Other Cars / Everything else Discussions 18 08-01-2006 08:30 PM
