Your mom goes to college
Drives: 08 Vitz Join Date: Oct 2008
sale pending from another Yw member on this custom intake manifold set-up for direct port nitrous right now , will post pictures of it installed this weekend !
![]() ![]() Drives: 2007 Yaris Join Date: Aug 2014
hey i was just curious what you guys are running in the 1/4mile
Dobbiedoo
Drives: 2009 5 door Hb Yaris Join Date: Aug 2010
Nitrous Use
I had a zex kit on my 94 Altima, lots of fun beating up on a lot of cars.When using the system it is reccommended not to use over 12 seconds. Zex has a kit out there for almost any car. This is a dry system with one fogger that goes in your intake plenum, close to your throttle body.The kit has a bottle, a long braided line, a Zex distribution solenoid, a switch, and pills for how much of a shot you need. The kit goes from 50 to 100 shot. Depending on where you live you may need a bottle warmer, I never used one. I have never used a purge kit, if your system is leak tight why would you need to purge? The system also require you to use one step colder plugs.
It's almost like the one on my picture, but this one does TPS as well... Thanks for the find!
Now I need to find an activator switch that fits... I'm getting close!
--[ FORUM RULES ]--[ SEARCHING TIPS ]--[ EYELIDS PICS ]--[ RBK SPOILER ]--[ BEST/WORST INVESTMENTS ]--
![]() ![]() Drives: Toyota Vitz Join Date: Sep 2010
i'm running nos on 1szfe, 55 dry shots, its good
![]() Drives: yaris hatch back Join Date: Oct 2010
can i use nitrous on stock intake manifold spraying a 50shot direct inject into each port?
I don't think the mani would take it TBH... You may be interested in the upcoming offering from MicroImage, which will have optional nitrous ports.
Be prepared to wait a while for that, however...
I ain't even mad
Yaris bodys can actually handle nos holy crap
will the manifold handle direct inject for each port using 4 wet foggers
if i fab a steel intake manifold up with nitrous ports are people interested to buy them cheaper then the weapon type r intake
^ yes, but only if you do the math so it makes power.
Drives: "Burning It Down GTX2860RS XB" Join Date: Sep 2010
Yeah, you better do the math and it can't look like that ragged piece of crap on the previous page if you intend on selling them.
By the time you get it all figured out and have one as nice as the weapon-R you'll be at the same price. The purge is a must. It's used to releave bottle pressure. Anything over a 1000 psi your starting to look for trouble. So if it's a hot day and your bottles in the car and it's lets say 1400 psi you gotta purge, other wise it would be like hitting your car with a 200 shot and boom it's over. I know this first hand, I've done it. direct port is the best, it allows for even spray across all the cylinders. A fogger kit will not. Most of your NO2 will end up in cylinders 1 and 2 , which in a small shot is not so bad but not so good either. You want a wet kit, this will be a whole lot safer. If you want to go direct port than just look at my post and you'll see the weapon-R manifold with the bungs I had welded in, not to mention it's a proven manifold. Good Building XBG |
#14 | |
Garm is permanently high because he is the king of smokin' deals! |
#15 |
oh, shit..thats yours....
I wasn't trying to completly run you over but, well.......it is pretty ugly and I don't think your making any exra power with that design. But don't worry we'll change that. XBG |
#16 |
^^ Its all good lol . I got it from the 2007 sema NOS car with all the nitrous nozzles/jets/lines/seloniods for a price I couldn't pass up . As for power mabey picked up a few hp on top-end only and the low end power sucks now. Or I guess I should say "for now"...
#17 |
![]() ![]() Drives: 2005 Echo Rs Join Date: Sep 2010
I know this is an old post but I thought it better than posting in the general section;
Has anyone hooked up a water/methanol pump to the fuel side of a wet nitrous nozzle? Seems to me that would take care of a lot of the knocking issues and concerns with using lower grades of fuel. (premium fuel is 10cents a litre more where I come from) I was thinking of making a water meth injection system like this: http://www.turbomirage.com/water-alc...tructions.html to use in conjunction with a nitrous setup. Then it occurred to me it would be simpler just to hook the water pump up directly to the nitrous system's fuel solenoid. |
#18 |
how much of a shot do you need before the yaris starts knocking?
I'd like the idea of doing an 80 shot direct port injection on the stock engine, then when the car's mileage gets up there most likely in 3-4 years i'll rebuild the bottom end and would like to run much higher shot 200-240hp (50-60hp per cylinder). i just prefer to use nitrous to have a 12 second yaris then boost cause i like the the idea of having a grocery getter with great MPG 99.9% of the time, and at a flip of a switch have a beast. |
| Expressions and Explanations thread. | *MAD DOG* | Off-topic / Other Cars / Everything else Discussions | 0 | 11-09-2008 05:55 PM |
| The Official "Bambo the Yarisworld Traveler" thread (V1) | nemesisz | Off-topic / Other Cars / Everything else Discussions | 3 | 11-08-2008 10:24 PM |
| Is there a thread about..... | Letsrock | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 7 | 11-01-2008 12:25 PM |
| Post Whores-aka Yaris chat thread | Black Yaris | Off-topic / Other Cars / Everything else Discussions | 21 | 07-12-2007 05:37 PM |
| Thread request - Yaris is new in the US | makaluch | Cosmetic Modifications (Exterior/Interior) | 1 | 08-13-2006 12:16 AM |
