![]() Drives: RC yRs LB Join Date: Jul 2007
a ez way to just adjust the rear drum is drive in reverse and then press on the brakes. then you might notice the parking brake will click less. down to 4.
![]() ![]() ![]() Drives: 2009 yaris 2 door Join Date: Feb 2013
something new
Hey does this actually work? anybody tried it already? How fast do you go? how far? how hard do you apply the brakes?
![]() Drives: 2007 Toyota Yaris Join Date: Mar 2017
slapping drums
I did the rear drums on my 07 Yaris, with all brand new equipment. Drums, shoes, springs etc. Greased the contact points, put back together the way it should be. Now there is a weird slapping when I apply the brakes. Any ideas. Thank you.
The Beautification of Car
geez i wish i see this thread earlier so i don't have to pay Big 10 $40 bucks to adjust my handbrake, and clean my drums break... my hand brake now only click twice-max, i can't pull it up anymore. Before it's like 10 clicks.
Learn to Relax
Drives: 2007, Meteorite, LB Join Date: Dec 2008
Sticky?
I do use the 2 smaller holes a lot of times when i have trouble removing brakes. Only thing is in the DIY i dont expect someone to have 2 spare bolts that are the correct size laying around. And usually if the drum is out of adjustment it should jsut come off very easily. Otherwise a large rubber mallet does wonders as well =).
As for lube if you have never done it before i dont reccomend it because if you get any on the brake pad it will create hotspots on the brake drum. Which is why i only reccomend water to clean out the dust cause any harsh chemical like brake cleaner has the possibility of removing the lube that is already there. Although i use about 2 cans of brake cleaner on a daily basis. I always use brake clean to clean drums. |
yarissedan: good writeup, i think i'll do it this afternoon when i get home hehe.
btw, did you ever reedit your post? just do it for twwards :P |
oh.. cleaned and adjusted the rear brakes. That was easy. Handbrake pulls ~5 clicks now :)
All i have to do next is fix the front calipers... take them apart, turn the discs, lub the calipers and put everything back... |
![]() ![]() Drives: Hatch Join Date: May 2009
Very nice DIY. Thanks for the effort you went to!
![]() Drives: Yaris Sedan Join Date: Dec 2008
Did it on yesterday, it was so exhausted man..haha.. Well now my e-brake only need 3-clicks but I have found my car now have more friction, engine performance dropped, means need more acceleration to move the car. Is that because the brake adjustment makes the car more frictions?
I have double checked the brake shoes have not rubbed with the drum after it adjusted, and the drum on both side with no overheating or burn smell after a day of driving.. |
Olive Green Metallic
Drives: 2008 Yaris Sedan Join Date: Aug 2009
Just performed this procedure. A rubber mallet works well to loosen the drum without any damage to the drum or backing plate. The primary objective is to loosen the light rust bond between the axle and center of the drum.
![]() ![]() Drives: 2007 LB Join Date: Jan 2009
Just wondering does anyone have the size for those "little bolts" to drive the drum off? I've always used the rubber mallet in the past but just wondering.
![]() ![]() ![]() ![]() ![]() Drives: 2013 Chevy Spark 1LT 5-speed Join Date: Oct 2008
Don't quote me, but seems like the size I usually use is 8mm x 1.25
#14 |
You can apply some hi temp grease where the hub and drum meet that will make taking apart much easier the next time
#15 |
![]() ![]() Drives: Red Yaris Join Date: May 2009
There are a few parts that are missing to this. When you adjust the brakes you're going to want to take out the actual adjuster and clean that with brake cleaner because alot of gunk builds up on it aswell. When you do this, it will free up the self adjusting process and when you back up and stomp on the brakes it will work to some extent. This doesn't have to be done, but its a good thing to do and only will take like 2 extra mins to clean up the adjuster.
-Phil |
#16 |
![]() ![]() Drives: 2007 Silver Toyota Yaris Sedan Join Date: Jan 2007
how often do you need to change brake shoes?
#17 |
![]() ![]() Drives: 07SedanS06Taco Join Date: Oct 2008
YarisSedan...What happen to the pictures? Was going to do this today. Can you please repost. Thanks.
Got it done. Thanks Last edited by othater; 10-18-2009 at 09:35 PM. |
#18 |
If anyone happens to have images for this in thier cache still could you please email them to me at jasonlabar@gmail.com I switch servers for my web hosting and forgot to save some of the files. So all the files got whiped.
| When will the Yaris hit the showrooms at dealers? | Petrolhead | New YARIS Purchase Forum | 181 | 11-28-2011 08:03 AM |
| Rotated tires and adjusted rear brakes today PICS | auxmike | DIY / Maintenance / Service | 11 | 11-14-2008 09:24 AM |
| Yaris/Echo Rear Brake Question | pdarnell | DIY / Maintenance / Service | 2 | 08-21-2007 02:15 PM |
| DIY: Painting Factory Brake Calipers | redyaris | DIY / Maintenance / Service | 38 | 05-26-2007 09:47 AM |
| Rear brake proportioning valve??? | PetersRedYaris | DIY / Maintenance / Service | 16 | 03-26-2007 12:10 AM |
