Old 01-28-2009, 11:02 PM   #1
YarisSedan
Drives: 08 Yaris Sedan
Originally Posted by markitect View Post
Here EGR refers to exhaust gas recirculation. This is now done by the VVT-i on our cars. where as regular cams had a special valve that opens up and air passage from the exhaust back to the head. Because our cars are VVT-i there is no EGR, unless they are using that to signal some problem with the VVT-i, or maybe your version of the car doesn't have VVT-i
I was wondering that too. I was assuming either 2 things 1 is that since his is a 05 vitz its older and maybe utilizes a egr system.
or 2 the mechanic who is working on his car is a idiot and just made up some code. Most mechanics know that when a egr code pops up you simply test the egr with a vacuum pump if egr tests good then its a solinoid if its electronic operated if not then the egr pintle is stuck or the pipe is severely crudded up restricting flow. Either way it can usually be fixed by cleaning the egr system.
Old 01-28-2009, 10:52 PM   #2
firemachine69
School'er of hard knocks
Drives: Silver Yaris 4dr. HB
Interesting you mention that, but wasn't an EGR pipe mentioned in the recent recall?
firemachine69 is offline   Reply With Quote
Old 01-29-2009, 02:18 PM   #3
gid
Drives: '08 Yaris sedan , '08 Liftback
this could be the culprit . The defective E.G.R. unit being recalled . Do you happen to smell any exhaust fumes in the car ? If so , most likely the E.G.R. pipe has broke . Get it to dealer service soon as possible .
gid is offline   Reply With Quote
Old 02-11-2009, 09:27 AM   #4
aliraja
aliraja's Avatar
Drives: Yaris(vitz) 2005
Send a message via MSN to aliraja
Hi,
I finally got the codes. Its;
p0403
p1589
p1605
Upon clearing the codes from the OBD-II scanner the 2nd and 3rd codes disappears but the first one i.e. P0403 remains uncleared.
What should be done ????
Where I Stand I Stand Alone
aliraja is offline   Reply With Quote
Old 02-11-2009, 09:46 AM   #5
LtNoogie
LtNoogie's Avatar
Drives: '08 Bayou Blue LB AT
P0403 - Exhaust Gas Recirculation Circuit Malfunction
http://www.obd-codes.com/p0403
I cannot find a Toyota code of P1589
P1605 Knock Control CPU
Old 02-11-2009, 11:07 AM   #6
aliraja
aliraja's Avatar
Thanks.
Will keep you posted when I go with it.
Old 02-15-2009, 08:32 AM   #7
id3379
§†ęĄ¶‡Ћ-NCP96
id3379's Avatar
"mechanic did add oil through air intake pipe. "
WTF ? He put oil in your intake pipe ??? WTF no wonder your having problems.
id3379 is offline   Reply With Quote
Old 04-14-2009, 02:03 PM   #8
aliraja
aliraja's Avatar
Hi to all.
I finally change my car's EGR thing. Cost me around 100$.
P0403 and P1605 are gone.
Error code P1589 is still active and so is the ML (CHK engine light)
In the scanner the code this code is describe as;
"Acceleration sensor learning value"
The scanner is X431.
any ideas about it.
help needed again.
Old 04-21-2009, 09:04 AM   #9
Ahmad
Drives: Vitz 06
hi ali. im from lahore and i own an 05 vitz and am having the exact same problem as yours. how/where did u get the new egr from?
Ahmad is offline   Reply With Quote
Old 04-29-2009, 07:59 AM   #10
aliraja
aliraja's Avatar
Dear Friend.
I got the egr thing from sher shah karachi. please further tell me that what kinda of problems are you facing with this error and i will share mine. Secondly are you car still on CNG or on Petrol.
Test Car needed for BlueBat overlays Turbo&Auto General Yaris / Vitz Discussion 12 07-24-2009 02:35 AM
Rear skirt needed Danish Yaris Cosmetic Modifications (Exterior/Interior) 6 01-09-2009 04:54 PM
What is needed for coilovers justinparadise21 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 8 01-03-2009 12:53 AM
Feedback needed on wheels kimona Wheels, Tires and Suspension Forum sponsored by The Tire Rack 21 06-09-2007 02:22 PM
opinion needed uncleyaris Cosmetic Modifications (Exterior/Interior) 9 01-12-2007 07:12 AM
