School'er of hard knocks
Drives: Silver Yaris 4dr. HB Join Date: Oct 2008
Keep in mind folks, that 1.8TS was NOT designed for fuel economy. It was designed for zippy fun. Add in some very cold city driving, with plenty of stops and starting of the engine, and it becomes exactly like my case.
![]() ![]() ![]() Drives: '09 Yaris LB Join Date: Dec 2008
Kou, privat netz 17 inch wheel weight is 17 lbs and the tires are 19.............17+19= 36
(stock wheels are 15, and eagle LS are 17) that indeed equals 32. Im not sure why some folks hate on larger wheels. Investing in light and/or larger wheels and nice tires has handling benefits especially over the awful stock tires. Its not like im running dubs on the thing. The temp, and conditions were taken into account already in the analysis. something is up other than my wheels and tires ps, thanks for answering my PM's |
#3 | |
ps you have a pm. |
![]() ![]() ![]() ![]() Drives: Yaris '09,GTi '09, BMW 3.30ci Join Date: Oct 2008
20MPG, woah. That sir is not normal. Going to uni everyday, getting stuck in the wort traffic imaginable every day as well, I still get 40+MPG, my best so far was around 52MPG.
Should definitely check with dealer. |
#5 | |
The Netherlands is a cold, cold place... And it would seem the Yaris is extremely sensitive to temperature. The hotter, the better! |
the summer i average 40ish now in the winter its 32-35ish,but there is some extra get up and go in the cold.
![]() ![]() ![]() ![]() Drives: Copper Orange Mica Yaris Join Date: Feb 2006
Are you sure that you do the right calculation to get that 20 MPG?
I am guessing that probably the way you calculate might not be accurate.
![]() My Copper Orange Mica Yaris with 9.3lb Kosei K1 TS http://www.yarisworld.com/forums/showthread.php?t=10951 http://www.yarisworld.com/forums/showthread.php?t=13882 http://www.yarisworld.com/forums/sho...180#post472180 |
miles travelled divided by gallons it took to fill up...off to school, ill do a mini test for this trip.
Joey
Drives: '14 Scion xD 5-speed Join Date: Oct 2008
Was your gas mileage better on stock 15"s?
Formerly owned Met-Met. '07 Yaris LB 5-speed. A forum post should be like a skirt: Long enough to cover the subject but short enough to keep things interesting. "I don't have an anger problem. I have an idiot problem." -Hank Hill |
well, w/ 17's youre pushing all the weight to the outside of the wheel and tire....which increases the rotational mass....3lbs per corner is equaly to like 30lbs when you try to get it rolling....
i know crandall has 18lb 17's w/ 215-40-17's and he gets about 30miles less per tank than i do w/ 14's also consider the cold weather....cold, thick oil is harder to get moving when you first start the car and the idling....just burning gas sitting still what also MAY be a case is if youre still trying to take off fast AND granny shifting at 2000 or 3000rpm.....wide open throttle is wide open throttle no matter what gear youre in and what gear do you cruise at in the city....say at 30mph.....3rd? try 4th
todays report:
39.8 miles, 1.6 gallons of fuel.
yeah, thats 24.8 mpg spare me the wheel hating, thats just plain messed up. I keep reading folks comments that they drive hard and cant get below 30 mpg. I drove my impreza like i stole it (especially in the winter ) and got 25 mpg consistently. I hear what yall are saying about WOT even if its only til 3000rpm. Im not gonna lie, I like to scoot around but i have been curbing my desires in the interest of not killing my car and seeing if the mileage improves. its strange that its running perfectly otherwise. I can make it to a dealer until friday. hope the car lasts that long |
![]() ![]() ![]() ![]() Drives: '08 Yaris sedan , '08 Liftback Join Date: Oct 2008
XYARIS , I take it that it's an automatic ? Do you possibly have it in 3rd GEAR instead of OVERDRIVE ? How's your tire pressure ?
noones hating on the wheels just put your stock ones on and see if you have a change in power and FE.
Ya - bet this is it. I remember another poster drove the auto for months complaining about low mileage and it turned out to be the same issue - driving in 3 instead of D.
or how about leaving the A.C. button on . Noticed I had somehow hit the A.C. button to the ON position ( GREEN lit up ) , is easy to miss , not very bright or large . Seldom use it for warm weather or the defrost mode for windshield , if windows fog up roll down window a bit , fresh air helps that . How long it was on I don't know
. Sign of progressive aging .
or both A.C. on and O.D. off .
![]() ![]() ![]() Drives: 2008 Yaris 3-door Meteorite Join Date: Oct 2008
I wouldn't be TOO embarrassed... As Mark Twain said ("Reports of my death have been greatly exaggerated."), so -- methinks -- have the "great mileage" claims on the Yaris. Toyota advertises it at 29 city/34 highway, or maybe 36 (can't remember), and I imagine that's pretty close to the truth of the matter.
| -Mileage Thread- -Log your mileage, year, model, color, any problems here... | Kal-El | DIY / Maintenance / Service | 322 | 07-20-2016 11:07 AM |
| Sedan better gas mileage than LB? 5 month gas chart included | flint_mica_manual | General Yaris / Vitz Discussion | 24 | 03-09-2009 09:24 AM |
| The Official Having A Bad Day Thread. | *MAD DOG* | Off-topic / Other Cars / Everything else Discussions | 7 | 11-15-2008 09:38 AM |
| Performance mods that won't affect/will hardly affect gas mileage?? | Mr.Yaris | Performance Modifications | 15 | 07-30-2007 01:32 AM |
| Fuel / Temp / Mileage Gauge - Special LED Readings? | bigsky2 | General Yaris / Vitz Discussion | 3 | 05-31-2006 10:04 AM |
