Go Back   Toyota Yaris Forums - Ultimate Yaris Enthusiast Site > Marketplace > Sponsors Classifieds Area > Micro Image
Old 03-23-2009, 02:46 PM   #1
mrbond
mrbond's Avatar
whooh! I'd be up for that 23mm!!
- A Toyota Yaris
- A whut Yaris?
Old 03-23-2009, 05:28 PM   #2
Treyz
~ ambient one ~
Treyz's Avatar
lol .. it never ends !
AMBIENTLIFESTYLE
Tri-State Sport Compact EZine
Micro Image
Store - Network - Online
Old 03-23-2009, 05:48 PM   #3
BLAZINBLUEVITZ
BLAZINBLUEVITZ's Avatar
Drives: 2007 YARIS 3DOOR
is that 1mm gonna make a difference?
Old 03-23-2009, 06:32 PM   #4
RagnaCaT
HacKers WanTed!
RagnaCaT's Avatar
Drives: Yaris S HB & Yaris S SD
Well against the TRD I don't think so we have to see the Price that would be the major difference but 19mm and 23mm should be noticible slightly.
Garm is the 19mm still going to be available when 23mm comes in?? I'd like the 19mm for SD and 23mm for the HB
R-CaT
Project Yar 2ZR
RagnaCaT is offline   Reply With Quote
Old 03-24-2009, 12:08 AM   #5
CASTREX
Who said Yaris was slow?
CASTREX's Avatar
Drives: Yaris T-Sport 2008
I remeber an explanation that Loren gave about this... IIRC the difference in thicknes is exponential...
So every +/- mm actually made for a large variation on the overall stifness that the bar provided...
Old 03-23-2009, 07:51 PM   #6
Shroomster
'07 to '12:2 wipers to 1?
Shroomster's Avatar
shoot I'd like to mod the 23 mm bar to fit my civic.... rep the old school Jordan on my 'vic yo....
MicroImageonline forums - Shroomster
Xda Forums - Shroomster
Androidforums - Shroomster
I'm noticing a pattern......
Old 03-24-2009, 01:20 AM   #7
^ correct again. You are on a roll today, man...
Old 03-24-2009, 02:26 AM   #8
Ryu
I just saw this and want to share with you guys about how sway bar work from wiki.
http://en.wikipedia.org/wiki/Sway_bar
The stiffness of an anti-roll bar is based on the fourth power of its radius, the stiffness of the material, the inverse of the length of the lever arms (i.e., the shorter the lever arm, the stiffer the bar), the geometry of the mounting points, and the rigidity of the bar's mounting points.
The stiffer the bar, the more force required to move the left and right wheels relative to each other. This increases the amount of force required to make the body roll.
I am not sure is the meaning of power of its radius means the thickness of the bar?
If so, I should have went for thicker version 23mm.
Old 03-24-2009, 03:46 AM   #9
m911gt
Carless in Chicago
m911gt's Avatar
Drives: 08 Blk LB
It says the fourth power of it's radius because the formula takes into account the bar's polar moment of inertia (J=(pi*d^4)/32) I believe.
Wanted: Forced Induction
Old 03-24-2009, 03:49 AM   #10
Ryu
Now I got it, thanks for the explaination. That makes 23mm version even more tempting lol.
Old 03-24-2009, 03:51 AM   #11
m911gt
Carless in Chicago
m911gt's Avatar
Drives: 08 Blk LB
yes sir! since our vehicles aren't super light, the slight weight addition when going with a thicker bar is not much of an issue...so in this case, bigger is more beneficial. the only question is, do we really need it?
Old 03-24-2009, 11:13 AM   #12
Shroomster
Shroomster's Avatar
Well I stand corrected. Garm is ordering a 23 mm sway bar...1 mm larger than the TRD....If only I had known this three weeks ago....
sorry about the mis-information Garm, I honestly thought you were joking
Old 03-25-2009, 06:15 PM   #13
RagnaCaT
HacKers WanTed!
RagnaCaT's Avatar
I HOPE YOU ALL KNOW GARM WAS JOKING ABOUT A "MICRO IMAGE ONLY 23mm EDITION" OF THE U.R. BAR...
WHAT!!! GARM!!!
R-CaT
Project Yar 2ZR
Old 03-26-2009, 02:47 PM   #14
Shroomster
Shroomster's Avatar
just so you all know^^^^
Old 03-24-2009, 01:19 PM   #15
Sabretooth
37HSSV
Sabretooth's Avatar
Drives: '11 Mazdaspeed 3
Well it might not be a MicroImage only thing, I remember when researching UR, they made 2 variations of the Sway bar...not sure what diameters, but we can pray..lol
Either way, some is better than none, the TRD bar is sufficient, and the UR bar is pretty much the same deal, I just dont see the difference between the two being drastic enough.
If you wrapped your car around a pole due to the rear coming around while going to fast around a corner, your not going to get out and wish you had gotten the Ultra Racing bar because you wouldnt have had a stiff rear end that caused the accident.
In other words, the two serve the same function, have similar design, and similar diameter, which shouldnt change the performance of the two to a noticeable degree.
Old 03-24-2009, 06:52 PM   #16
Split
Drives: 2008 Yaris Sedan
Question
hey Garm,
Can i order one of these along with that TRDv4 kit?
Split is offline   Reply With Quote
Old 03-24-2009, 10:20 PM   #17
kustom play
pink wheels are cool
kustom play's Avatar
Drives: 07 liftback
yay white strut bar!
do you have the front in stock still?
Old 03-24-2009, 11:13 PM   #18
darkmoon87
darkmoon87's Avatar
Drives: 08 Yaris
I'd say the safest threshhold for the thickness of swaybar for Yaris is 19mm. If you go anywhere beyond that, the axle may not be able to withstand the G, while the 19mm+ swaybar can. In other words, you need an additional support and this is where the lower tie bar comes in. If you are planning to rock 23mm swaybar and participate in events such as auto-x frequently, I strongly recommend you to invest in tie bar support. The worst possible result you may end up with from 23mm swaybar + no tie bar support setup may be, SNAP, BREAK, FLIP, and CRASH
RIP Yaris, I will miss your superb handling a lot.
darkmoon87's picture thread
http://www.yarisworld.com/forums/showthread.php?t=10013
darkmoon87 is offline   Reply With Quote
Possible Group Buy.. Racing Seats, Intakes? TinyGiant Items for Sale by private party 60 09-11-2009 02:40 PM
Racing Seats Group Buy- New Englanders Only TinyGiant New England 25 02-11-2009 11:13 AM
ultra racing front strut bar installed smurf Performance Modifications 9 03-10-2007 05:58 PM
