He used to use the handle "grumpyfromNH". He's relabeled himself. Same guy, same TIRED old rant....
Until I bought my Yaris and learned a LOT here about oil filters, I ALWAYS used orange Fram brand filters. Guess what? Never lost an engine. ALSO, I would buy the cheap PepBoys Pro Line oil! Go figure... Welcome back , Grumpy
#2 | |
![]() ![]() ![]() ![]() Drives: 2008 Yaris RS 4-Door LB Join Date: Oct 2008
Busted!
Benggolf2 |
#3 | |
'07 to '12:2 wipers to 1?
Drives: '12 5-door LE & '14 5-door LE Join Date: Apr 2007
they are a good group as long as you don't get them started on lubrication.....hehe |
Carless in Chicago
when my car was stock, the engine was super quiet. i've never had a problem. not sure what could be causing the rough run.
Wanted: Forced Induction Some say that he is the secret love child of Ferrari and Porsche, and others say that he would lap James May twice in a 1/4 mile drag race. All we know is that he is called The Stig. |
![]() ![]() ![]() Drives: 2008 Yaris sedan A/T Join Date: Oct 2008
mine is vibrating a little on stops
![]() Drives: 2007 Toyota Yaris Sedan Join Date: Oct 2008
I also get some kind of vibrating when sitting at a stop light with my foot on the brake. If i have it in park then i don't hear it at all. It sounds like something is rattling or loose in the engine area.
Do you guys have lightened or underdrive crank pulleys?
Does the noise stop when you depress the clutch (in case your car is equipped with a manual transmission)?
Benggolf2 |
Mine is all stock and an automatic.
Mine does the same thing when I'm stopped after the motor is warmed up. The idle drops really low and it kind of shudders. I have heard the ECU makes that motor do that intentionally for fueal economy reasons.
![]() ![]() ![]() ![]() Drives: 08 3DR 5M Bayou Blue; 09 Fos Join Date: Oct 2008
Well if you blew over 6 engines in ten years using the "best" american oils and OEM filter how would U feel about the subject. No american major brands labeled synthetic are synthetic. Period. My wifes previously wonderful rav 4 is DEAD in 3 years with only 67K miles using TOYOTA THAI denso filters and genuine toyota oil and Mobil 5000. F this. IDK if you blow you motor. Go ahead. No skin off MY teeth (= <
#11 | |
![]() 6 motors in ten years? Whew.... You're the first person I know who's killed ANY Toyota vehicle in three years flat. Hope you have better luck in the future , sir.
#12 | |
I saved my Yaris from the brink with Motul 8100 and WIX |
#13 | |
#14 | |
Drives: 2007 Yaris Hatchback Join Date: Oct 2008
Grampy, you blew that many motors? This says more about YOU then the oil. There are MILLIONS that have not blown so many oils, and they use the "cheap" American brands too. I would suggest pouring the oil into the valve cover and not the exhaust pipe. It don't get into the engine from the exhaust pipe, I promise! |
![]() ![]() ![]() ![]() ![]() Drives: 2008 Polar White LB Auto Join Date: Oct 2008
Does anyones idle go down a little bit then come back up when they turn on things like the rear defrost, turn the blower on, etc?
^+1
The cars are parked outside and get many a 10 deg F cold start in the Winter. Sometimes -15 F. That can't help.
