this may sound out there but there was an article in turbo mag a year or 2 back and it had an equation that you could use. dont quote me exactly but if i remember right you could plug in displacement,horsepower goal, and a few other factors and it would get you a good estimate of what cc injector you needed.
![]() ![]() ![]() ![]() Drives: Vitz RS Turbo Join Date: Nov 2008
Finally we decided what injectors will suit best and we chose the Siemens Deka 4 630cc.
These injectors flow 220 lbs/hr at 43.5 PSI ( 3 BAR ) and more at higher PSI! These units are low-impedance and require peak and hold injector drivers or additional resistors for saturation drivers. Despite the high flow rate, they are linear and controllable at low pulse widths compared to other extreme flow injectors! These injectors are sometimes referred to as 212lb/hr or 225lb/hr injectors Any has experience on these? |
#3 | |
I love momentum.
Well that's good news since that increase the probability of being ones of the very best racing injectors one could own.
I hope they are efficient as advertised as these will probably be a good indeed upgrade. Bye Bye tuning probs :) |
Some pictures of the rear mounting. Sorry about the blured image but the camera sucks at close ups!
UPDATES:
UPGRADED INTERCOOLER HOSES TO SAMCO RED :) SHOWING CUSTOM BLUE WATER HOSES ASWELL TRD CAP |
cool, very colorful -- what throttle body is that?
Learn to Relax
Drives: 2007, Meteorite, LB Join Date: Dec 2008
Sexy engine! You need a pink dip stick to set it off!
OR >>> Garm's Intake Mainfold
![]() I'm waiting . . . BTW just found this on my pc > http://www.youtube.com/watch?v=u0wage2LBdM
This week we installed Siemens Deka 4 630cc injectors. Since the Siemens housing length is slightly different from original toyota injectors they needed to be "modified" to match the fuel rail.
Now needs tuning from scratch, I hope it makes real power with these on
ooh man can't wait for new results!! I have great hopes for this project!
#13 | |
Guess what? ..... if all goes well I think I will be the one to trial the Gude Performance Head package on our 1NZ. I already send him an e-mail to get some more details on cams.... Stay tuned! |
#14 |
You're drag racing tomorrow? or tuning tomorrow, or both... ?
#15 |
#16 |
oh "street tuning", gotcha.
#17 |
Some bad news....
![]() Yesterday we done a compression test since we are still having trouble idle and slow runing the engine. Well it result that 2 cyclinders are loosing compression and probably some valves not sealing properly... There is also a problem to convert the engine with the authorities (due to some changes in law) since there is a fine difference due to bigger displacement (probably within $2000 range ) So we are now intending to modify the 2NZFE 1.3L engine block to match the 1NZFE rods and in the meantime solving aswell the problem of the compression. We have to measure all the necessary points of the block in order to make this happen....This will cost lots of money & time and since I am out of cash it will be a while to update my status.... |
#18 |
aw, so sorry to hear this. Do you think the motor came to you with these problems?
Is this your first compression test on it???
| Motor Longevity | Pavel Olavich | DIY / Maintenance / Service | 10 | 03-17-2012 11:43 AM |
| cali yaris built motor | cali yaris | Performance Modifications | 83 | 09-03-2009 11:08 PM |
| Fan motor noise... | 500snakz | General Yaris / Vitz Discussion | 10 | 12-01-2008 02:43 AM |
| Motor oil debate - interesting info but a long read. | mikeukrainetz | General Yaris / Vitz Discussion | 6 | 12-10-2006 08:16 PM |
| Exchanging Motor on a Liftback 1.3 Lt | weckjuan | Performance Modifications | 8 | 11-12-2006 10:58 AM |
