Old 03-31-2010, 04:54 PM   #1
Stock valve springs are designed to work with the stock rev limit and the stock lift and ramp angles on the cams.
Correct. Although I will say we are doing fine up to 7200 so far, all valve parts are stock.
Old 03-31-2010, 05:23 PM   #2
rob323
Don't drive it, RALLY it!
Drives: 1999 echo PRC rally car
That's good to know there's some head room left in the valve train, thanks Garm.
rob323 is offline   Reply With Quote
Old 03-31-2010, 06:10 PM   #3
Parmas
Parmas's Avatar
Drives: Vitz RS Turbo
I thought you rev limit to 6500? Can you give more info on the 7200?
Does it increase power or remain constant between 6.5-7.2?
Old 03-31-2010, 05:52 PM   #4
don't worry if they float, I'll post it!
Old 03-31-2010, 05:56 PM   #5
rob323
Do they float/ bounce?
Old 04-01-2010, 11:10 AM   #6
we wanted to increase the rev limit to at least 8,000 rpm or above.
Looking forward to your dynos, that will be really cool!
@ Parmas: we have the limiter at 7200 but if you've looked at my dynos, it quits making power about 6500.
It MIGHT make power up higher with the new custom intake manifold. Next tuning session will tell us a lot more.
Old 04-01-2010, 12:27 PM   #7
Parmas
Parmas's Avatar
Yes I saw that before but I thought you got it making power till 7200 after that.
BTW I heard some ppl saying that water injection reduces power output when used. I mean if you run the same setup with for example 16psi with water injection and dyno compare it without, it will result to a slight power decrease. Is this true?
Old 04-01-2010, 12:30 PM   #8
possibly, any volume taken up by water vapor is not filled with air/fuel mixture... Not sure how big of a difference it would make, but it's a small compromise to be able to run on pump gas!
Old 04-01-2010, 12:52 PM   #9
"some people saying" means nothing to me. Show me some results and I will be very interested, although I'm not trading away the ability to run high boost on pump gas - that is way too much fun to give up!
Old 04-01-2010, 01:39 PM   #10
Parmas
Parmas's Avatar
In my opinion Water Injection is used to cool mixture and to be able to run higher boost values but with that said, doesn't mean it gives you power by itself. Is that right?
I happen to be in a forum to discuss these things before commiting myself into it. I am not saying they are right or wrong, I just want your opinions like Etimago commented and I am sure all good things have their bad things.
I don't carry lots of cash to try these things, I am here to knowledge myself more and prevent disappointment for future upgrades..
Old 04-01-2010, 02:11 PM   #11
^ I'm here for that too, have learned a lot. Yes, I would agree that water doesn't add power by itself. But at cooler intake/cylinder temperatures (which is what the water does), more fuel is in the available air, and that makes more power. This would be true whether or not there is boost.
A good example of this is that a Cold Air Intake adds power to a stock car (n/a), simply by cooling down the incoming air. Water injection does the same thing, to my understanding.
What I meant was "some people saying" doesn't help any of us. Doesn't it depend on who said it, when they said it, and what they were talking about? So my request, respectfully is to be more specific in that regard.
Old 04-01-2010, 03:41 PM   #12
Parmas
Parmas's Avatar
I understand your thought so I ask what is the better?
- Having a very good intercooler that keeps the air as cold as possible
OR
- Cooling Mixture with water injection
In my opinion cooling the air without water injection by having a better intercooler is the point were you will see power gains without compensating with extra boost (less wear and tear). What are your opinions on this guys?
Old 04-01-2010, 04:06 PM   #13
It's just as easy to do water/meth injection and get the octane boost from the alcohol. I wouldn't bother with all the effort for just water.
Old 04-02-2010, 08:17 AM   #14
Parmas
Parmas's Avatar
Can you tell us by how much the water injection on your setup lowered the intake temps ?
Old 04-02-2010, 10:50 AM   #15
No, (1) because we changed the manifold too and (2) we haven't tuned on the dyno yet (wastegate failed last time).
Hoping for a new appointment next week!
Old 04-04-2010, 04:50 AM   #16
changchewsoon
Drives: Vios Turbo
Send a message via MSN to changchewsoon Send a message via Yahoo to changchewsoon
thanks a lot garm and parmas, it is because of people like you guys all over the world inspires people like to me to want to push the 1nz-fe further! :)
i too can't wait to see garm's latest update and also parmas's build....man just thinking about them gives me goosebumps!
i've learnt a lot just by reading both your threads.
454 whp, 1.7 bar boost, pump gas, water/meth.
501 whp, 2.2 bar boost, pump gas + avgas, no water/meth.
www.viosturbo.com - World's first 500 WHP 1NZ-FE
changchewsoon is offline   Reply With Quote
Old 04-04-2010, 10:49 AM   #17
Parmas
Parmas's Avatar
That is why we post here my friend !
Of course we are many here and I think there are more than just us building the ultimate 1NZ so please contribute your info
Old 06-10-2010, 04:04 AM   #18
Parmas
Parmas's Avatar
Update:
Let me revise the situation.... During the last months I had my tuner claiming that the problem of the tune up was coming from a loss of compression. Since there were too much money to repair and buy the extra parts I decided to hold the project until I had further cash in my hands.
During the time, I came accross one of my friends who is an expert on this and decided to help me out on this. Of course we began by checking the compression again and duhhh it came out that it is good on all 4 cyclinders. We retried again the test and still no problems.
Seeing this out he told me to change the tuner and retry the tune again. I went to talk with the new tuner and he told me that we need to check all the necessary wiring in case the previous tuner messed up something. We indeed found some wiring not matching with the ecu instruction manual regarding VVT connection so this might be the problem.
The other thing that might mess up with the tune is that the ECU supports VVT but not VVTi. There is an option to activate the VVT at a certain rpm and switch it off at another rpm. I contacted the ecu company for more info on this and he said that the ecu was tested and tuned succesfully on a 1ZZFE VVTi engine.
I booked a tuning session for next week so until then crossed fingers
Motor Longevity Pavel Olavich DIY / Maintenance / Service 10 03-17-2012 11:43 AM
cali yaris built motor cali yaris Performance Modifications 83 09-03-2009 11:08 PM
Fan motor noise... 500snakz General Yaris / Vitz Discussion 10 12-01-2008 02:43 AM
Motor oil debate - interesting info but a long read. mikeukrainetz General Yaris / Vitz Discussion 6 12-10-2006 08:16 PM
Exchanging Motor on a Liftback 1.3 Lt weckjuan Performance Modifications 8 11-12-2006 10:58 AM
