Old 06-21-2010, 05:42 AM   #1
Parmas
Parmas's Avatar
Drives: Vitz RS Turbo
Update:
Today I went to my tuner and we began to check the Stock Crank Trigger in order to configure the ecu accordingly. We found out that the stock toyota crank sensor has a sense config of 37 -3 (Please anyone confirm this) in which the present ecu do not accept this triggering. Infact the ecu is configured to 36 -1 which do not represent my setup....
Please garm or anyone can you confirm this 37-3 triggering?
Parmas is offline   Reply With Quote
Old 06-21-2010, 04:03 PM   #2
rob323
Don't drive it, RALLY it!
Drives: 1999 echo PRC rally car
I can confirm from my Echo manual that it has 34 teeth, so your 37-3 config might be correct.
rob323 is offline   Reply With Quote
Old 06-21-2010, 05:09 PM   #3
Parmas
Parmas's Avatar
Thanks rob that relievs me from doubts!
Anyother who wish to confirm this trigger feel free especially garm
Old 06-21-2010, 09:10 PM   #4
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
It's actually 36 minus 2.
This is info coming from a Toyota Canada Technician Trainer.
Edit: So there should be 34 teeth, but only minus 2, not 3.
Old 06-22-2010, 04:37 AM   #5
Parmas
Parmas's Avatar
As of Bluevitz post we decided to re check again and count the teeth again. I didn't mention before but we have not opened the motor to count it directly but we are counting them from the crank sensor hole so there is a possibility we counted 1 missing tooth more.
It is strange the uneven number of 37 so we conclude that the trigger is effectively 36 -2 as Bluevitz-rs mentioned
Old 08-07-2010, 08:17 AM   #6
Parmas
Parmas's Avatar
I have a problem regarding the IDLE control connection. Do anyone knows where I can find a diagram showing the idle control connector and it's terminal connections.
The connector is 3 wire : Red/Black Yellow/Black Brown
I need this to connect it to the standalone ecu.
Old 08-12-2010, 07:27 AM   #7
Parmas
Parmas's Avatar
UPDATE:
Wiring is almost ready .... the only things remaining is Launch control and Table switches to wire up. Also changing some oil and water braided pipes to some anodized color threads which look awesome for me.
I didn't bother taking pics since you would only see a mess of wiring which still needs to be organized.
Stay tuned!
Old 08-12-2010, 11:21 AM   #8
I want to see the mess of wiring! Pictures always!
Old 08-13-2010, 05:35 AM   #9
Parmas
Parmas's Avatar
YOU WANT PICS HERE THEY ARE
By sequence:
1. 4 x Haltech Igniton modules . 1 Ignitor per coil for maximum energy efficiency
2. Honda CBR600 Coil with custom made rubber cushion at the top. Grommet of a stabilizer link haha
3. Coil Setup. Please note that coils are not tighten, that's way there is a gap!
4. Front View.... still way to go for a clean setup
5. The box of my dreams
6. Ohhh myyy ... a day of work to clean the mess
Cheers
Old 08-13-2010, 11:54 AM   #10
changchewsoon
Drives: Vios Turbo
Send a message via MSN to changchewsoon Send a message via Yahoo to changchewsoon
parmas nice work! and i can see you're running the haltech platinum sport ecu! good choice...
454 whp, 1.7 bar boost, pump gas, water/meth.
501 whp, 2.2 bar boost, pump gas + avgas, no water/meth.
www.viosturbo.com - World's first 500 WHP 1NZ-FE
changchewsoon is offline   Reply With Quote
Old 08-13-2010, 12:10 PM   #11
Focus_Sh1ft
Focus_Sh1ft's Avatar
Tbh, my head exploded looking at that last picture.
Old 08-13-2010, 12:15 PM   #12
LOL, that's the easy part!
Thanks for posting, that makes it fun to check the thread!!
Old 08-13-2010, 04:07 PM   #13
scioncrew
scioncrew's Avatar
Drives: SCION tC
Send a message via AIM to scioncrew
that remines me of your car Garm :)
05 Scion tC allmotor 350+ hp 9.34@144mph
05 Scion tC sfwd 880hp 9.96@147mph
05 Scion xB 280hp 12.97@104mph
07 Toyota Yaris 357hp 12.80@107mph
scioncrew is offline   Reply With Quote
Old 08-13-2010, 04:14 PM   #14
^ YES!! see the influence you've had?
Old 08-13-2010, 04:38 PM   #15
Parmas
Parmas's Avatar
Thanks for the comments I really need to cheer up since the most irritant part is coming..... Organizing all the mess! By the way this time I am doing all my way, no tuner is involved here, it's only my work of art. Then up on the dyno goes to the professionals and I am hoping for some nice numbers.
As a brief all the sensors, idle control, injectors and ignition is wired up. Tomorrow I will begin testing out the setup beginning from the coils. If ignition shows good spark I will give a try to start the engine at least, then tune it on dyno.
Looking into the Haltech software shows much more details... from gauges to 3D graph maps. Main Settings are unlimited which can probably control any type of engine out there. It also support Ivtec or VVTL-I at full setting with fuel and ignition maps only for them. Will take pictures of software as soon as all is done.
Old 08-14-2010, 11:50 AM   #16
Parmas
Parmas's Avatar
Update:
Spent a day working on wiring and on the engine bay part wiring is complete although I need to figure out a nice plate to hide the side wiring.
Also arranged inside wiring but ran out of cable ties so I had to stop
Spark was tested on all 4 coils and ignitors with the help of my gf cranking the engine . All gave a good spark so ignition is ok.
Next.... still need to complete in car wiring and installing launch control toggle switch. If there is more time I will try starting the engine and prays god all goes well
Stay tuned!
Old 08-16-2010, 02:38 PM   #17
changchewsoon
Drives: Vios Turbo
hi parmas, now that you're using the haltech platinum sport ecu may i entice you with this?
it plugs straight to the ecu via a single vnet cable and it displays everything the ecu sees...
Video: http://www.youtube.com/watch?v=QajCrfAmxEU
Link 1: http://www.viosturbo.com/2010/04/sta...ch-iq3_24.html
Link 2: http://www.viosturbo.com/2010/05/sne...play-dash.html
im very sure you'll definitely fall in love with it
Old 08-16-2010, 04:14 PM   #18
mmmm... I'll do a digital dash in the future for sure.
Motor Longevity Pavel Olavich DIY / Maintenance / Service 10 03-17-2012 11:43 AM
cali yaris built motor cali yaris Performance Modifications 83 09-03-2009 11:08 PM
Fan motor noise... 500snakz General Yaris / Vitz Discussion 10 12-01-2008 02:43 AM
Exchanging Motor on a Liftback 1.3 Lt weckjuan Performance Modifications 8 11-12-2006 10:58 AM
