Old 08-17-2010, 12:34 AM   #1
Parmas
Parmas's Avatar
Drives: Vitz RS Turbo
The display is cool but now I am not in the mood for more expenses.
If the engine reacts well with the combined ecu I will sure invest more on the car.... if not ( and prays god nooo) I have to sell the engine and go back to stock.
Old 08-17-2010, 02:47 PM   #2
changchewsoon
Drives: Vios Turbo
Send a message via MSN to changchewsoon Send a message via Yahoo to changchewsoon
parmas don't give up yet, garm and i and lots of other people have been getting positive outcomes with the 1nz-fe engine.
we're here to help and share if you ever need anything man!
454 whp, 1.7 bar boost, pump gas, water/meth.
501 whp, 2.2 bar boost, pump gas + avgas, no water/meth.
www.viosturbo.com - World's first 500 WHP 1NZ-FE
changchewsoon is offline   Reply With Quote
Old 08-18-2010, 01:14 AM   #3
Parmas
Parmas's Avatar
I appreciate this comment. People like you make me struggle for success
Old 08-17-2010, 06:39 PM   #4
pimp my yaris
C'est la vie
pimp my yaris's Avatar
Drives: 2009 2 door hatchback
Holly heat wrap batman. That looks like an awsome project. Sweet display.
pimp my yaris is offline   Reply With Quote
Old 08-23-2010, 02:25 PM   #5
Parmas
Parmas's Avatar
Today changed engine oil and coolant and installed the "NEW" Teflon braided pipe for the turbo water line. Also all in cabin wiring is finished and arranged it like it never been there .
During the turbo water line installation I came to notice that the idle control on the throttle body has the coolant pipes missing (In and Out). Then I understood that these were being used to feed coolant to the turbo from the beginning. So I ask are these essentially needed for the idle control to work fine also since I changed the engine management? What are the consequences of these removed?
Also I need to know some information on the Idle control like frequency and normal operating conditions. I attached a screenshot of the page of the ecu software to set this up
Old 08-23-2010, 04:28 PM   #6
I know I'm not using those on my TB
Old 08-27-2010, 08:44 AM   #7
Parmas
Parmas's Avatar
Today I tried to start the engine but it seems there is something blocking the startup since it is stopping cranking after only few seconds.
I tried to increase fuel on the rpm range but still no start. After I came across this describtion of the starter on the manual and it says :
"IN CASE THAT THE STARTER BEGINS TO OPERATE, BUT CANNOT DETECT THE ENGINE SPEED SIGNAL, THE ECM WILL STOP THE STARTER OPERATION IMMEDIATELY"
Then I began to think that since I am operating the starter through the stock toyota ecu and I disconnected the engine speed signal (which is the Crank Trigger Sensor) and connected it to the Haltech Ecu, the stock ecu is surely not detecting the crank trigger and is probably stopping startup. I am not sure about this but it could be plausable.
Now I decided to eliminate the starter by using an external relay and a push button.
Although I am not sure about this so Garm or any other that has changed their ecu should tell if this is true or not.
Old 08-28-2010, 07:11 AM   #8
Parmas
Parmas's Avatar
Here is the current setup
Old 08-28-2010, 02:58 PM   #9
Parmas
Parmas's Avatar
I would like the experts to confirm with me about the Triggering of the engine in relation to Camshaft position.
Main needs are:
1. Trigger Angle
2. Tooth Offset between crank trigger and camshaft trigger
3. Trigger / Home Edge
Old 09-15-2010, 01:59 PM   #10
Parmas
Parmas's Avatar
All is ready and prepared for the dyno tune. It is scheduled to be within the next week so cross hands all goes well to jump to some nice numbers.
I think I finally earned this after 2 years owning the engine it has not passed 500miles on it!
The only thing remaining is putting on the bumper in place and we are ready to go.
Old 09-15-2010, 02:58 PM   #11
pimp my yaris
C'est la vie
Looks good. All Business.
Old 09-19-2010, 11:39 AM   #12
changchewsoon
Drives: Vios Turbo
time to make some serious power parmas, can't wait to see the numbers on the dyno!
Old 09-19-2010, 11:59 AM   #13
CLEAN - you are ready!
Old 10-28-2010, 01:08 PM   #14
Parmas
Parmas's Avatar
Car was brought to the tuning facility for tuning.
For a change we had trouble keeping the engine on idle and was misfiring as hell. The tuner said that probably it is something related to the camshafts \ VVti activation position etc...
We brought another standard engine to compare values of crank triggering versus camshaft positions etc... which are still working on it.
Tomorrow will check the intake manifold and throttle body for leaks just in case. Also need to change the oil turbo feed line since the tuner said it is too wide than normal condtions.
I would like to know what happens to the camshaft position if you disconnect the Cam timing plug (near the alternator) . Would it become fully retarded or fully advanced or a certain degree?
This answer will help the tuner much with his issues!
Old 10-28-2010, 03:04 PM   #15
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
^ unplugging the VVTi solenoid leaves the cam at 0°. So no advance.
Old 10-29-2010, 12:48 AM   #16
advocate
Drives: car
Parmas,
That haltech digital dash is absolutely stunning.
I saw one of these in a rally car the other day and figured I would never be able to have anything nearly as cool as that in my car so seeing it in front of your dash has made me really excited to start working on my engine once the funds become available.
Keep going strong man we're rooting for you.
Old 10-29-2010, 08:56 AM   #17
Parmas
Parmas's Avatar
Originally Posted by advocate View Post
Parmas,
I agree with you on the digital dash although you missed that was only an opinion of changchewsoon. I don't own it at this time.
Old 10-29-2010, 09:57 AM   #18
^ Me neither but I would like to do a digital dash, right in front of me (where it belongs? LOL), someday.
Motor Longevity Pavel Olavich DIY / Maintenance / Service 10 03-17-2012 11:43 AM
cali yaris built motor cali yaris Performance Modifications 83 09-03-2009 11:08 PM
Fan motor noise... 500snakz General Yaris / Vitz Discussion 10 12-01-2008 02:43 AM
Motor oil debate - interesting info but a long read. mikeukrainetz General Yaris / Vitz Discussion 6 12-10-2006 08:16 PM
Exchanging Motor on a Liftback 1.3 Lt weckjuan Performance Modifications 8 11-12-2006 10:58 AM
