Old 02-23-2009, 12:10 PM   #1
TLyttle
TLyttle's Avatar
Drives: 07 Yaris sedan
What are you guys after, a car or a storage unit?? I've got so many storage spots in my sedan that I lose track of what is in them. Recently, I found a CD that I thought I had lost...
Old 02-23-2009, 12:43 PM   #2
IsLNdbOi
IsLNdbOi's Avatar
I love my driver side glovebox. Here's what I did on mine:
These pics. are from my '07 LB. In my '09 LB, the cigarette lighter / 12V port in the glovebox is almost up against the coin holder on the left side of the glovebox.
Old 03-03-2009, 11:45 AM   #3
Shroomster
'07 to '12:2 wipers to 1?
Shroomster's Avatar
I still don't understand that top left picture.....
Old 02-23-2009, 01:53 PM   #4
mimelio
Drives: NONE
Originally Posted by supmet View Post
So I just recently found out that the liftbacks have two more glove boxes than the sedans. Is it possible to add the two extra glove boxes to the sedan? Is there anything under the dash on the sedan that isn't on the liftback?
I looked over both Liftback and Sedan before I purchased by Liftback. That was one of many points I liked about the Liftback over the Sedan.
mimelio is offline   Reply With Quote
Old 02-23-2009, 02:31 PM   #5
MUSKOKA800
MUSKOKA800's Avatar
The bonus gloveboxes would be nice but I'll take my trunk over them, everyday.
Old 02-23-2009, 03:31 PM   #6
helphelp911
Drives: yaris
glove box on driver side is great. i use it as GPS box.
helphelp911 is offline   Reply With Quote
Old 02-23-2009, 05:37 PM   #7
AlexNet0
AlexNet0's Avatar
Drives: '07 Yaris 3dr
^ wow...
Old 03-03-2009, 12:14 AM   #8
supmet
Drives: 2007 4 Door Yaris
So after a little searching, and some help from CTScott,
The part number for the glove box doors are : 55041-52010-B0 (Door sub-assy, Instrument panel box, No. 1) and 55041-52010-B0 (Door sub-assy, Instrument panel box, No. 2)
TRDSparks sells them for $101 for the driver's side, and $120 for the passenger side.
Now on to stage two of the problem.
The bottom of the two glove boxes I want, are part of the entire dash. So my options are replace the entire dash, or build some sort of custom bottom out of fiberglass or something. I actually think building a bottom will be possible, and I think I remember seeing a metal pillar in behind the dash I could mount it too.. I'll have to go exploring under the dash a little more and see what we can do. I think I'm gonna do the driver's side first so i don't have to worry about the air bag :D
Old 03-03-2009, 02:09 PM   #9
IsLNdbOi
IsLNdbOi's Avatar
What's not to understand? It's a mounting ball for Garmin GPS units screwed into the glovebox lid.
Old 03-03-2009, 03:19 PM   #10
supmet
My tomtom is mounted in the exact same place right now, except its on the sedan dash, not the hatchback glovebox lid. I didn't screw it in, I just epoxied the suction cup attachment to the dash I love having it right there. It is the closest spot, which makes it easy to use, and people can actually hear me on the bluetooth speaker(which they couldn't with it on the windshield)
I'm thinking if I have to custom make a bottom to make the glove box, I'll probably end up making mounting spots for a tomtom, scangauge, and maybe even a TMPS gauge. That way I can just close the glove box and hide all my goodies from prying eyes.
Old 03-04-2009, 02:08 AM   #11
Shroomster
Shroomster's Avatar
well duhr....I meant the 4 notches in the base of the base..... I just don't get how you secured it....
::EDIT::
upon further inspection, can I assume that the base has 4 notches with a metal ring exposed in those notches, to which you used string, and made 4 holes in the dash? (judging also from the second picture) I take it the mount has a 'beauty ring' to hide the mount....
Old 03-04-2009, 02:24 AM   #12
IsLNdbOi
IsLNdbOi's Avatar
::EDIT::
I've replaced the old Garmin in the picture above with a new Garmin Nuvi:
Here's a picture of the mounting ball:
The four notches have "lips" that the head of the screws catch on. This is what holds the mounting ball down.
I simply placed the mounting ball in the spot where I wanted it, traced the four notches then drilled holes where I traced the notches. Then I screwed the mounting ball in and used a washer and nut for each screw on the inside surface / back of the glovebox cover.
My new Garmin Nuvi came with a cradle that snaps onto that ball:
Old 03-03-2009, 03:50 PM   #13
IsLNdbOi
IsLNdbOi's Avatar
It's a great place to put the GPS unit. It prevents you from using it (reaching through the steering wheel to tap the screen, etc.) while you're driving. Makes it easy to see as well since it's directly in front of you.
Old 03-03-2009, 09:53 PM   #14
slothman86
slothman86's Avatar
Drives: 07 Yaris Liftback
I mounted my nuvi to the small window infront of the big window on the drivers side door. Very handy spot.
Maybe the LB dash can fit into the sedan?
or
I'll sell you mine for over 9000 dollars.
Old 03-04-2009, 02:24 AM   #15
PHXDEMON
PHXDEMON's Avatar
Drives: 2007 Red Liftback
My drivers side glovebox works perfect for my ciggarrettes, and garage door opener.
How do you utilize the extra glove compartment? fazali General Yaris / Vitz Discussion 144 05-24-2012 02:04 AM
Rubber plugs in glove box cfiimei DIY / Maintenance / Service 5 01-06-2009 04:48 AM
FS: Glove Box Damper (GTA) Teruyume Items for Sale by private party 1 07-02-2007 01:58 AM
