Old 05-06-2009, 08:15 AM   #1
yarstar
Drives: 2008 Absolute Red HB
Originally Posted by PHXDEMON View Post
I guess ill just run in without the clamp and cross my fingers
No clamp for months now on mine and no problems.
AEM CAI, NST Pulleys/SSK, WR 4-2-1 Header, TRD axelback, R1 Concept Rotors, TRD Sway Bar, Nitto Rear Strut Bar, Cusco GT-Zero Coilovers, 1ZZ-FE 1.8L TB
yarstar is offline   Reply With Quote
Old 05-05-2009, 11:45 PM   #2
mikenacarato
SIPNDEW
mikenacarato's Avatar
Drives: 15 STI
get 3 more bolts like the one lower left bolt and replace the 3 studs.
mikenacarato is offline   Reply With Quote
Old 05-06-2009, 12:16 AM   #3
PHXDEMON
PHXDEMON's Avatar
Drives: 2007 Red Liftback
Just finished the install and holy fucking oscillation form 1000-3000 rpm from a cold start. I tried driving around a little bit and it started jumping up to 4k on idle and a CEL. How long does it typically take for the oscillation to start smoothing out? It's too late here (9:15) to mess around with it more. Don't want to piss off the neighbors. Any suggestions?
Old 05-06-2009, 12:20 AM   #4
MGargano
Drives: 2009 Yaris Hatchback
It took about 2 days or so for the oscillation & CEL to finally go away
MGargano is offline   Reply With Quote
Old 05-06-2009, 12:28 AM   #5
PHXDEMON
PHXDEMON's Avatar
Did the oscillation slowly smoothe out or did it just stop out of nowhere? How much driving did you do in 2 days?
Old 05-06-2009, 12:28 AM   #6
PHXDEMON
PHXDEMON's Avatar
I am doing to leave the battery disconnected overnight incase 2 hours wasnt enough.
Old 05-06-2009, 12:38 AM   #7
MGargano
I got oscillation at cold idle as well as intermittent CEL for the first two days, then both just went away completely. All I get now is the high (3,000 RPM) cold idle and better performance. I only did local driving during those first few days, no highway or any heavy pushing.
Old 05-06-2009, 01:14 AM   #8
PHXDEMON
PHXDEMON's Avatar
Damn I was still gettingm oscillation and my motor was getting pretty warm. Is there an an idiot light that turns on if it starts overheating?
Old 05-06-2009, 01:27 AM   #9
PHXDEMON
PHXDEMON's Avatar
WTF I just hooked the battery back up and started it up again and my idle was perfect with no oscillation Hopefully it stays that way. I didn't want to even take it around the block because I have had about half a beer and their are mad cops out for cinco de mayo. Hopefully I will have a nice drive to work tomorrow
Old 05-06-2009, 08:09 AM   #10
MGargano
Don't be surprised if the oscillation comes and goes for the first couple days. This happened to me and I thought everything was fine, then I got oscillation on the next cold start. Just be patient and give it a few days to work itself out.
Old 05-06-2009, 03:27 PM   #11
PHXDEMON
PHXDEMON's Avatar
Yeah it came back
Old 05-06-2009, 03:31 PM   #12
eii
Rides canyon walls
eii's Avatar
Drives: 1988 RX7 FC 10th AE
Just out of curiousity, are you guys doing the coolant bypass? I was considering doing so unless this changes the way it idles. The 3k cold starts for 1 minute is all I want as far as weird reving goes. Dont want the bypass to screw with my fine idling.
OEM Style Wing Spoiler | TRD Axle-Back Exhaust | Megan Lowering Springs (1.5 f/r) | Simota Carbon Charger Intake | Python 871XP Alarm System | Aluminum Sports Pedal | 17x7 +42mm Enkei J10 Black w/ Silver Lip | 205/40 Falken Ziex-912 | NST Lite Crank Pulley Red | 1ZZ-FE Throttle Body | AMK Racing Header
eii is offline   Reply With Quote
Old 05-06-2009, 05:12 PM   #13
PHXDEMON
PHXDEMON's Avatar
I did do the coolant bypass. Drive to work today was great . I actually don't experience the high cold idle everyone else is. My cold idle is around 2k RPM just like stock. I did hower buy my TB from M911gt on here so he may have fine tuned the idle screw. I think if anything doing the coolant bypass will make it idle better
Old 05-06-2009, 05:19 PM   #14
eii
Rides canyon walls
eii's Avatar
Just to clarify things, the coolant by pass i just just hooking up together the two coolant hoses that connect to the TB, right? You dont do anything to the little metal thingies on the TB the hoses were connected to? Just leave them be?
Old 05-06-2009, 05:25 PM   #15
MGargano
I plugged the tubes on the TB, but I've heard others have left them as-is. And yes, you just have to use a barb union to join the two hoses together.
Old 05-06-2009, 06:07 PM   #16
PHXDEMON
PHXDEMON's Avatar
Correct others have plugged them I just left them as is. Just go down to a lowes/home depot/etc and get a coupler barb for 3/8 inch ID vinyl tubing and you are food to roll. Stock clamps work and everything just need the barb.
Old 05-11-2009, 07:49 PM   #17
eii
Rides canyon walls
eii's Avatar
FYI, I'm always food to roll..always.
Old 05-07-2009, 06:31 PM   #18
eii
Rides canyon walls
eii's Avatar
Cool thanks guys. I'll probably stop by lowes once my paycheck arrives, hazzah!
Also, I'm using the simotoa carbon charger CAI. Buy a 2.5" silicone coupler at your local auto parts store and that should work perfectly.
1.8L Engine Swap, Possible? Yaris T-Sport Performance Modifications 4 05-06-2007 06:57 PM
swap for 2zz-ge???? yarisTOONR82 Performance Modifications 12 03-23-2007 07:15 PM
