Old 03-20-2009, 03:01 AM   #1
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
DIY Fog Light Parts .
When you purchase any after market YARIS fog lights ,ie Sedan or Hatch Back
You should also purchuse or make the following parts
These will allow you to PLUG into the factory wiring (no running wires through firewall) (must have)
PURCHASE FROM Micro Image - cali yaris
The relay goes under the dash as per diagram , (must have)
If you want to use the aftermarket switch supplied you must remove it from the wiring loom supplied
so it looks like the photo, then wire it in as per other diy's (or you can PM me and i wil send you the factory instructions)
Or you can go and buy the factory light stalk and do no wireing in the cabin. just plug it in . (optional )
DIY (08' USDM LB): Interior Light Color Change revnull DIY / Maintenance / Service 37 05-21-2016 12:59 PM
DIY - fog light install kurokoma-kun DIY / Maintenance / Service 3 09-18-2012 12:52 AM
Rav4 and Highlander fog light parts 1NZYaris1 Items for Sale by private party 5 02-13-2009 10:43 PM
DIY:Day time running light Disabled with stock fog light remain function summergxz DIY / Maintenance / Service 12 09-26-2007 10:42 AM
